查看: 4730|回复: 8
[emWin] 请教,关于F429配置RGB565模式显示8位位图的问题。。。。
发表于 2016-3-7 12:08:56 | 显示全部楼层 |阅读模式
STM32F429驱动7寸液晶,RGB565显示模式,跑GUI例程,除了显示Micrium Logo 8位Bitmap图片异常外,其它显示都正常。。。。。
我想请教哈。。。。F429配置RGB565显示模式后,如果要显示8位位图,还需怎么配置??我按照官方的配置方法试过,貌似也不行。。。。
正常显示应该是这个样子滴。。。。。。
可实际显示却是这个样子滴。。。。
 楼主| 发表于 2016-3-7 12:11:04 | 显示全部楼层
下面是我的配置,请帮忙看看是不是缺了点么事。。。。。。
static void LTDC_Layers_Init(uint32_t LayerIndex)
  LTDC_InitTypeDef         LTDC_InitStruct;
  LTDC_Layer_InitTypeDef   LTDC_Layer_Init;
  LTDC_CLUT_InitTypeDef    LTDC_CLUT_InitStruct;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_LTDC, ENABLE);
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2D, ENABLE);
    /* Polarity configuration . Initialize the horizontal synchronization polarity as active low */
    LTDC_InitStruct.LTDC_HSPolarity = LTDC_HSPolarity_AL;
    /* Initialize the vertical synchronization polarity as active low */
    LTDC_InitStruct.LTDC_VSPolarity = LTDC_VSPolarity_AL;
    /* Initialize the data enable polarity as active low */
    LTDC_InitStruct.LTDC_DEPolarity = LTDC_DEPolarity_AL;
    /* Initialize the pixel clock polarity as input pixel clock */
    LTDC_InitStruct.LTDC_PCPolarity = LTDC_DEPolarity_AL;
    /* Configure R,G,B component values for LCD background color */
    LTDC_InitStruct.LTDC_BackgroundRedValue = 0;
    LTDC_InitStruct.LTDC_BackgroundGreenValue = 0;
    LTDC_InitStruct.LTDC_BackgroundBlueValue = 0;
    RCC_PLLSAIConfig(192, 7, 4);
    RCC_LTDCCLKDivConfig(RCC_PLLSAIDivR_Div4);
    RCC_PLLSAICmd(ENABLE); /* Enable PLLSAI Clock */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLSAIRDY) == RESET) { }  /* Wait for PLLSAI activation */
    LTDC_InitStruct.LTDC_HorizontalSync = HSW;
    LTDC_InitStruct.LTDC_VerticalSync = VSW; /* Configure vertical synchronization height */
    LTDC_InitStruct.LTDC_AccumulatedHBP = HBP; /* Configure accumulated horizontal back porch */
    LTDC_InitStruct.LTDC_AccumulatedVBP = VBP;  /* Configure accumulated vertical back porch */
    LTDC_InitStruct.LTDC_AccumulatedActiveW = LCD_XSIZE + HBP; /* Configure accumulated active width */
    LTDC_InitStruct.LTDC_AccumulatedActiveH = LCD_YSIZE + VBP; /* Configure accumulated active height */
    LTDC_InitStruct.LTDC_TotalWidth = LCD_XSIZE + HBP + HFP; /* Configure total width (1056)*/
    LTDC_InitStruct.LTDC_TotalHeigh = LCD_YSIZE + VBP + VFP; /* Configure total height (525)*/
    LTDC_Init(&LTDC_InitStruct);
    LTDC_Layer_Init.LTDC_HorizontalStart = HBP + 1;
    LTDC_Layer_Init.LTDC_HorizontalStop = (LCD_XSIZE + HBP);
    LTDC_Layer_Init.LTDC_VerticalStart = VBP + 1;
    LTDC_Layer_Init.LTDC_VerticalStop = (LCD_YSIZE + VBP);
    LTDC_Layer_Init.LTDC_PixelFormat = LTDC_Pixelformat_RGB565;
    LTDC_Layer_Init.LTDC_CFBLineLength = (LCD_XSIZE*2) + 3;
    LTDC_Layer_Init.LTDC_CFBPitch = (LCD_XSIZE*2);
    LTDC_Layer_Init.LTDC_ConstantAlpha = 255;
    LTDC_Layer_Init.LTDC_DefaultColorBlue = 0;
    LTDC_Layer_Init.LTDC_DefaultColorGreen = 0;
    LTDC_Layer_Init.LTDC_DefaultColorRed = 0;
    LTDC_Layer_Init.LTDC_DefaultColorAlpha = 0;
    LTDC_Layer_Init.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_CA;
    LTDC_Layer_Init.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_CA;
    LTDC_Layer_Init.LTDC_CFBLineNumber = LCD_YSIZE;
    LTDC_Layer_Init.LTDC_CFBStartAdress = Layer_Address[LayerIndex];
    LTDC_LayerInit((LayerIndex == 0 ? LTDC_Layer1 : LTDC_Layer2), &LTDC_Layer_Init);
    LTDC_ReloadConfig(LTDC_IMReload); /* LTDC configuration reload */
    LTDC_LayerCmd((LayerIndex == 0 ? LTDC_Layer1 : LTDC_Layer2), ENABLE);/* Enable foreground & background Layers */
    LTDC_Cmd(ENABLE); /* display ON */
    LTDC_DitherCmd(ENABLE);/* dithering activation */
static void DMA_DrawBitmapL8(void * pSrc, void * pDst,  uint32_t OffSrc, uint32_t OffDst, uint32_t PixelFormatDst, uint32_t xSize, uint32_t ySize)
  /* Set up mode */
  DMA2D->CR      = 0x00010000UL;         /* Control Register (Memory to memory with pixel format conversion and TCIE) */
  /* Set up pointers */
  DMA2D->FGMAR   = (uint32_t)pSrc;                       /* Foreground Memory Address Register (Source address) */
  DMA2D->OMAR    = (uint32_t)pDst;                       /* Output Memory Address Register (Destination address) */
  /* Set up offsets */
  DMA2D->FGOR    = OffSrc;                          /* Foreground Offset Register (Source line offset) */
  DMA2D->OOR     = OffDst;                          /* Output Offset Register (Destination line offset) */
  /* Set up pixel format */
  DMA2D->FGPFCCR = LTDC_Pixelformat_L8;             /* Foreground PFC Control Register (Defines the input pixel format) */
  DMA2D->OPFCCR  = PixelFormatDst;                  /* Output PFC Control Register (Defines the output pixel format) */
  /* Set up size */
  DMA2D->NLR     = (uint32_t)(xSize << 16) | ySize;      /* Number of Line Register (Size configuration of area to be transfered) */
  /* Execute operation */
  DMA2D->CR     |= 1;                               /* Start operation */
  /* Wait until transfer is done */
  while (DMA2D->CR & DMA2D_CR_START) {  }
void LCD_DrawBitmap8bpp(int x, int y, int xSize, int ySize, uint8_t const * p, int BytesPerLine)
  uint32_t BufferSize, AddrDst;
  int OffLineSrc, OffLineDst;
  AddrDst = LCD_DISPLAY_BUFFER_ADDRESS  + (y * LCD_XSIZE + x) * BYTES_PER_PIXEL;
  OffLineSrc = BytesPerLine - xSize;
  OffLineDst = LCD_XSIZE - xSize;;
  DMA_DrawBitmapL8((void *)p, (void *)AddrDst, OffLineSrc, OffLineDst, PIXELFORMAT, xSize, ySize);
发表于 2016-3-7 12:58:39 | 显示全部楼层
给我个8位图,我试试。没有什么需要特别配置的。
 楼主| 发表于 2016-3-7 13:11:11 | 显示全部楼层
MicriumLogo.rar (4 KB, 下载次数: 75)
 楼主| 发表于 2016-3-7 13:20:50 | 显示全部楼层
另外。。。。官方例程中的的这个配置和函数是干嘛用的,如果我想把UCGUI配置成8色显示,该如何改??请指点。。。。。
发表于 2016-3-8 15:19:51 | 显示全部楼层
可以正常显示,我在我最近做的收音机界面上面测试了下:
 楼主| 发表于 2016-3-8 17:15:21 | 显示全部楼层
谢谢!我再找找原因。。。。。。
看过你最新开发的界面,确实牛X。。。。。[s:151]
发表于 2016-3-9 00:11:35 | 显示全部楼层
回 天马行空 的帖子
天马行空:谢谢!我再找找原因。。。。。。
看过你最新开发的界面,确实牛X。。。。。[s:151]  (2016-03-08 17:15)
过奖了[s:142]
发表于 2016-4-6 10:15:52 | 显示全部楼层
回 天马行空 的帖子
天马行空:下面是我的配置,请帮忙看看是不是缺了点么事。。。。。。
  LTDC_Layer_InitTypeDef   LTDC_Layer_ .. (2016-03-07 12:11)
你这个问题解决了吗?
GMT+8, 2026-11-23 08:16 , Processed in 1.161393 second(s), 27 queries .
