查看: 4700|回复: 0
[STLink] ST-LINK 仿真器固件升级
发表于 2016-3-3 22:20:50 | 显示全部楼层 |阅读模式
ST-LINK/V2 firmware upgrade
网站:http://www.st.com/web/en/catalog/tools/PF258194#
版本: 2.24.4
st-linkv2_upgrade.zip (937 KB, 下载次数: 253)
Changes in version 2.24.4
On ST-Link/V2 boards, upgrade firmware to the version V2J24S4.
New features:
 Provide a command for JTAG clock frequency selection
 Added support for STM32F746
3 Information about major previous release
3.1 Summary of changes in version 2.23.4
On ST-LINK/V2 boards, upgrade firmware to the version V2J23S4.
Corrections:
 Fix SWV no more working after Stop Debug/Start Debug on ST-LINK/V2 boards
New features:
 Added management of SWCLK switch command
 Added support for Linux and MacOS-X operating systems (see Section 1 for details)
3.2 Summary of changes in version 2.21.4
On ST-LINK/V2, upgrade firmware to V2J21S4.DocID023788 Rev 7 3/5
RN0084 Customer support
Corrections:
 Set NRST pin high, when exiting the firmware update mode
3.3 Summary of changes in version 2.20.4
On ST-LINK/V2, upgrade firmware to V2J20S4.
Corrections:
 Fixed regression appeared in V2J19 in SWV trace management
 Fixed potential lockup condition in SWV trace management
3.4 Summary of changes in version 2.19.4
On ST-LINK/V2, upgrade firmware to V2J19S4.
New features:
 Fixed the issue about the RAM parity check error with some microcontrollers when
reading misaligned RAM contents
 Enhanced the SWV data flow (loosing data at 1024-bytes boundaries more rarely)
 Enhanced the target TNRST signal management for low-powered targets
3.5 Summary of changes in version 2.16.4
 Added command for FPU registers access (STM32F3xxx and STM32F4xxx)
 Firmware compatible for boards with isolation
 Added command for board identification
 Added possibility of hot plug JTAG connection (without target hard reset)
 Fixed the limitation about power not activated in the debug domain during JTAG
initialization sequence
GMT+8, 2026-11-24 07:54 , Processed in 0.155774 second(s), 26 queries .
