查看: 7650|回复: 6
[音频视频处理] helix官网已经不再提供mp3编码解码的源码的下载了,被国内的一家公司备案
发表于 2016-2-3 13:28:21 | 显示全部楼层 |阅读模式
官网是这几天才被更新过的。
https://helixcommunity.org/
就在前几天还是可以下载源码的,这几天就不行了
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=17183
 楼主| 发表于 2016-12-31 17:32:27 | 显示全部楼层
https://www.helixcommunity.org/projects/datatype/mp3dec
The Helix MP3 Decoder
The Helix MP3 decoder provides MPEG-compliant decoding of MP3 content. Both floating-point and fixed-point decoder implementations are available. The fixed-point decoder is optimized especially for ARM processors but can run on any 32-bit fixed-point processor which can perform a long multiply operation (two 32-bit inputs generating a 64-bit result) and long multiply-accumulate (long multiply with 64-bit accumulator).
Key Features
    [li]Pure 32-bit fixed-point implementation[/li][li]High-quality C reference code for porting to new platforms[/li][li]Optimized for ARM processors[/li][li]Fully reentrant and statically linkable[/li][li]Optional C++ API for compatibility with Helix clients[/li][li]Designed for high performance and low power consumption in handheld and mobile devices[/li][li]Full layer 3 support forMPEG1 layer 3 - sampling frequencies: 48 KHz, 44.1 KHz, 32 KHz[/li][li]MPEG2 layer 3 - sampling frequencies: 24 KHz, 22.05 KHz, 16 KHz[/li][li]MPEG2.5 layer 3 - sampling frequencies: 12 KHz, 11.025 KHz, 8 KHz[/li]
Supports constant bitrate, variable bitrate, and free bitrate modesSupports mono and all stereo modes (normal stereo, joint stereo, dual-mono)Option to use Intel® IPP performance libraries (if available)
    [li]Easy to link in either IPP libraries or Helix code[/li]
Technical Specifications
Average CPU Usage
Sample Rate
Channels
Bit Rate
Processor Model [sup](1)[/sup]
ARM7TDMI
ARM9TDMI-REV2
ARM920T
ARM9E
StrongARM1
XScale
48.0 KHz
320 Kbps
30 MHz
24 MHz
27 MHz
20 MHz
20 MHz
20 MHz
44.1 KHz
128 Kbps
26 MHz
21 MHz
24 MHz
17 MHz
17 MHz
17 MHz
(1) Tested with ARMulator, simulated zero-wait-state memory
Memory Usage
    [li]ROM = 13446 Bytes (const globals)[/li][li]RAM = 23816 Bytes (heap)Total Data Memory = 37262 Bytes[/li]
Code Size = 21000 Bytes (approximately - depends on compiler)
Frequently Asked Questions
Where is the code in CVS?
Where does the build system put the code in my local source tree?
    [li]datatype/mp3/codec/fixpt[/li]
How does the build system decide whether to build the fixed-point or floating-point MP3 decoder?
    [li]If HELIX_CONFIG_FIXEDPOINT is defined in your profile, it will build the fixed-point decoder. Otherwise it will buil[/li]
发表于 2019-7-14 14:33:10 | 显示全部楼层
硬汉, 你有以前下载过的helix源码吗?有的话能分享一下吗?谢谢!
 楼主| 发表于 2019-7-15 06:59:33 | 显示全部楼层
这个帖子里面的音乐播放器里面有
发表于 2019-7-15 09:31:33 | 显示全部楼层
找到个5.1版本,备份下: helix_mp3enc_CVS.zip (506.12 KB, 下载次数: 105)
发表于 2019-7-15 10:03:18 | 显示全部楼层
可以使用这个:
ST终于把MP3编解码库中间件放出来了
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=88772
发表于 2019-7-16 15:29:29 | 显示全部楼层
多谢大家的分享!!!
GMT+8, 2026-11-23 16:31 , Processed in 1.121310 second(s), 27 queries .
