查看: 5307|回复: 1
GPIO_PinAFConfig 函数的疑问,做PWM输出时可能导致GPIO跳动一下
发表于 2016-1-31 16:13:57 | 显示全部楼层 |阅读模式
固件库的函数存在BUG。
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
  uint32_t temp = 0x00;
  uint32_t temp_2 = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource));
  assert_param(IS_GPIO_AF(GPIO_AF));
  temp = ((uint32_t)(GPIO_AF) << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
  GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
  temp_2 = GPIOx->AFR[GPIO_PinSource >> 0x03] | temp;
  GPIOx->AFR[GPIO_PinSource >> 0x03] = temp_2;
两次配置AFR寄存器了。第一次导致GPIO电平改变。
修改为如下解决问题:
void bsp_GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
    uint32_t reg;
    //GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
    //temp_2 = GPIOx->AFR[GPIO_PinSource >> 0x03] | temp;
    reg = GPIOx->AFR[GPIO_PinSource >> 0x03];
    reg &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4));
    temp_2 = reg | temp;
发表于 2016-2-2 14:55:31 | 显示全部楼层
强悍啦,支持[s:151] [s:151] [s:151] [s:151]
GMT+8, 2026-11-22 16:02 , Processed in 0.974841 second(s), 23 queries .
