查看: 5683|回复: 6
[emWin] 关于窗口的BUTTON问题
发表于 2016-1-29 14:15:45 | 显示全部楼层 |阅读模式
static void _DrawWindow3(WM_HWIN hWindows3)
    WM_HWIN hItem ;
     hItem = TEXT_CreateEx(0, 0, 180, 70, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_0,TEXT_CF_LEFT, "工艺设置");
     TEXT_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
     TEXT_SetFont(hItem, &GUI_FontYahei);
     TEXT_SetBkColor(hItem,0x800080);
     hItem = EDIT_CreateEx(0, 450, 360, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_0, 10);
     EDIT_SetText(hItem, "");
     EDIT_SetFont(hItem,  &GUI_FontYahei);
     EDIT_SetBkColor(hItem,1,GUI_GRAY);
     hItem = EDIT_CreateEx(360, 450, 200, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_1, 10);
     hItem = EDIT_CreateEx(560, 450, 120, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_2, 10);
     EDIT_SetText(hItem, "软件版本");
     hItem = EDIT_CreateEx(680, 450, 120, 30, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_3, 10);
     EDIT_SetText(hItem, "1.0");
//line--1
     hItem = TEXT_CreateEx(0, 82, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_1,TEXT_CF_LEFT, "加捻方向");
     hItem = EDIT_CreateEx(180, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_4, 10);
     hItem = TEXT_CreateEx(420, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_2,TEXT_CF_LEFT, "纱线支数");
   hItem = BUTTON_CreateEx(540, 82, 60, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_0);
     BUTTON_SetText(hItem, "公制");
     BUTTON_SetFont(hItem,    &GUI_FontYahei);
     hItem = EDIT_CreateEx(600, 82, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_5, 10);
//line2
     hItem = TEXT_CreateEx(0, 134, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_3,TEXT_CF_LEFT, "捻度");
     hItem = EDIT_CreateEx(180, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_6, 10);
     hItem = TEXT_CreateEx(300, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_4,TEXT_CF_LEFT, "T/m");
     hItem = TEXT_CreateEx(420, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_5,TEXT_CF_LEFT, "纱线定长");
     hItem = EDIT_CreateEx(600, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_7, 10);
     hItem = TEXT_CreateEx(720, 134, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_6,TEXT_CF_LEFT, "m");
//line3
     hItem = TEXT_CreateEx(0, 186, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_7,TEXT_CF_LEFT, "锭速");
     hItem = EDIT_CreateEx(180, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_8, 10);
     hItem = TEXT_CreateEx(300, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_8,TEXT_CF_LEFT, "r/min");
     hItem = TEXT_CreateEx(420, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_9,TEXT_CF_LEFT, "长度修正系数");
     hItem = EDIT_CreateEx(600, 186, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_9, 10);
//line4
     hItem = TEXT_CreateEx(0, 238, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_10,TEXT_CF_LEFT, "卷绕速度");
     hItem = EDIT_CreateEx(180, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_10, 10);
     hItem = TEXT_CreateEx(300, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_11,TEXT_CF_LEFT, "r/min");
     hItem = TEXT_CreateEx(420, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_12,TEXT_CF_LEFT, "整车锭数");
     hItem = EDIT_CreateEx(600, 238, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_11, 10);
//line5
     hItem = TEXT_CreateEx(0, 290, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_13,TEXT_CF_LEFT, "卷绕电机频率");
     hItem = EDIT_CreateEx(180, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_12, 10);
     hItem = TEXT_CreateEx(300, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_14,TEXT_CF_LEFT, "Hz");
     hItem = TEXT_CreateEx(420, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_15,TEXT_CF_LEFT, "纱筒重量");
     hItem = EDIT_CreateEx(600, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_13, 10);
     hItem = TEXT_CreateEx(720, 290, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_16,TEXT_CF_LEFT, "kg");
//line6
     hItem = TEXT_CreateEx(0, 342, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_17,TEXT_CF_LEFT, "加捻电机频率");
     hItem = EDIT_CreateEx(180, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_14, 10);
     hItem = TEXT_CreateEx(300, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_18,TEXT_CF_LEFT, "Hz");
     hItem = TEXT_CreateEx(420, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_19,TEXT_CF_LEFT, "台产量");
     hItem = EDIT_CreateEx(600, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_EDIT3_15, 10);
     hItem = TEXT_CreateEx(720, 342, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_20,TEXT_CF_LEFT, "kg/h");
//line7
     hItem = TEXT_CreateEx(0, 394, 180, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_21,TEXT_CF_LEFT, "任务完成后关机");
     hItem = TEXT_CreateEx(180, 394, 120, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV,  ID_TEXT3_22,TEXT_CF_LEFT, "关闭");
   hItem = BUTTON_CreateEx(300, 394, 60, 40, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_1);
     BUTTON_SetText(hItem, "设置");
//button
   hItem = BUTTON_CreateEx(350, 10, 150, 50, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_2);
     BUTTON_SetText(hItem, "导纱机构设置");
   hItem = BUTTON_CreateEx(600, 10, 120, 50, hWindows3, WM_CF_SHOW|WM_CF_MEMDEV, 0, ID_BUTTON3_3);
     BUTTON_SetText(hItem, "返回");
static void _cbWindow3(WM_MESSAGE* pMsg)
    WM_HWIN hItem = pMsg->hWin;
    switch (pMsg->MsgId)
        case WM_CREATE:
            /* 创建后设置聚焦 */
    //        WM_SetFocus(hItem);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hItem, 1);
                case GUI_KEY_TAB:
                    WM_SetFocusOnNextChild(hItem);
        case WM_PAINT:
                GUI_RECT r;
                WM_GetClientRect(&r);
                GUI_SetBkColor(GUI_LIGHTGRAY);
                GUI_Clear();
                _DrawUpRectEx(&WIDGET_Effect_3D2L, &r);
                _DrawWindow3(pMsg->hWin);
        case WM_NOTIFY_PARENT:
            if (pMsg->Data.v == WM_NOTIFICATION_RELEASED)
                int Id = WM_GetId(pMsg->hWinSrc);
                switch (Id)
                case ID_BUTTON3_0:
                    case ID_BUTTON3_1:  //关闭
                    case ID_EDIT3_2:
                    case ID_BUTTON3_3:  //返回
        default:
            WM_DefaultProc(pMsg);
WM_HWIN CreateWindow3(void)
     hWin =WM_CreateWindow(0, 0, 800, 480, WM_CF_SHOW|WM_CF_MEMDEV, _cbWindow3, 0);
  return hWin;
    while(1){
        GUI_Delay(50);
        ii++;
        if(ii>=1000) ii=0;
               for(iii=ID_EDIT3_4;iii<ID_EDIT3_4+12;iii++)
                hMulti = WM_GetDialogItem(WM_GetClientWindow(hWin), iii);
            EDIT_SetFloatMode(hMulti,ii,0,1000,0,GUI_EDIT_SUPPRESS_LEADING_ZEROES);
上面的这个例子我操作的时候,点解任何一个ID_BUTTON3_1的时候,会出现一个现象导致EDIT里面的值都不显示了。是什么原因。
 楼主| 发表于 2016-1-29 15:39:16 | 显示全部楼层
我测试了一下,感觉是我点击了ID_BUTTON3_1,包括任何一个BUTTON,都好像会使得这个窗口重绘导致的这个现象。
 楼主| 发表于 2016-1-29 15:52:19 | 显示全部楼层
但是如果我把_DrawWindow3这个函数不要放置在回调函数里面,就不会出现这个现象,但是不放在里面的话,比如我创造了两个窗口 都用这样的方式创建的,切换的时候使用    WM_DeleteWindow(hWin);和WM_CreateWindow();就发现切换界面比较慢,用隐藏和显示,我试过了的方法应该不对,出现问题,请指教一下这个问题怎么处理。
 楼主| 发表于 2016-1-29 17:04:48 | 显示全部楼层
因为我的窗口控件特别多,界面切换的时候就会出现一点点卡的现象。
 楼主| 发表于 2016-1-29 17:08:36 | 显示全部楼层
把画控件的放到WM_PAINT的话,就发现界面切换的时候显示没有卡的现象,但会存在BUTTON导致EDIT无法显示现象,但如果把画控件的函数放到WM_CREATE,就会有界面切换的时候卡的现象,但BUTTON这个导致EDIT无法显示的现象就不存在了,我猜测是点击BUTTON导致窗口没有删除又重绘了导致的。不知道有没有办法解决,或者有什么方法可以实现两个窗口切换没有卡的现象 我的控件稍微有点多。
发表于 2016-1-29 17:14:59 | 显示全部楼层
这个函数放错位置了,要放在WM_CREATE里面:       _DrawWindow3(pMsg->hWin);
另外建议用资源列表创建,单独麻烦且不容易管理。
 楼主| 发表于 2016-1-29 17:40:02 | 显示全部楼层
确实是的 放在WM_CREATE这个里面就不会这样了,但有另外一个问题就是比如我两个窗口切换的时候,就会有卡的现象。不知道有没有什么好的办法解决
GMT+8, 2026-11-23 08:07 , Processed in 0.925071 second(s), 24 queries .
