查看: 6767|回复: 1
[FatFs] 最新的0.10版本发布
发表于 2013-10-3 15:50:20 | 显示全部楼层 |阅读模式
Oct 02,'13 R0.10    Added selection of character encoding on the file. (_STRF_ENCODE)
                                 Added f_closedir().
                                 Added forced full FAT scan for f_getfree(). (_FS_NOFSINFO)
                                 Added forced mount feature with changes of f_mount().
                                 Improved behavior of volume auto detection.
                                 Improved write throughput of f_puts() and f_printf().
                                 Changed argument of f_chdrive(), f_mkfs(), disk_read() and disk_write().
                                 Fixed f_write() can be truncated when the file size is close to 4GB.
                                 Fixed f_open(), f_mkdir() and f_setlabel() can return incorrect error code.
ff10.zip (867 KB, 下载次数: 128)
提供的工程例子
ffsample.zip (2.54 MB, 下载次数: 652)
以后想支持FATFS的多任务的时候,要加入这个
 楼主| 发表于 2013-10-3 15:51:32 | 显示全部楼层
官网地址
http://elm-chan.org/
GMT+8, 2026-10-24 18:38 , Processed in 0.126814 second(s), 27 queries .
