查看: 10786|回复: 1
[FreeRTOS教程] FreeRTOS基础知识(三)--------FreeRTOS授权
发表于 2013-9-14 21:00:48 | 显示全部楼层 |阅读模式
       这个就不翻译了,这个翻译不好容易被人误会,直接的贴英文。
       FreeRTOS is licensed under a modified GPL and can be used in commercial applications under this license without
anyrequirement to expose your propriatory source code. An alternative commercial license option is also available in
cases that:
    [li]You cannot fulfill the requirements stated in the "Modified GPL license" column of the table below.[/li][li]You wish to receive direct technical support.[/li][li]You wish to have assistance with your development.[/li][li]You require legal protection or other assurances.[/li]
发表于 2015-5-18 09:58:35 | 显示全部楼层
[s:143]  [s:143]  [s:143]  [s:142]  [s:142]
GMT+8, 2026-11-24 15:36 , Processed in 0.279199 second(s), 27 queries .
