查看: 22719|回复: 2
STM32F429 DISCOVERY 即将发布(价格24美元)
发表于 2013-9-13 14:18:21 | 显示全部楼层 |阅读模式
The STM32F429 Discovery helps you to discover the high-performance microcontrollers of the STM32 F4 series and to develop your applications easily.
It offers everything required for beginners and experienced users to get started quickly.
Based on the STM32F429ZIT6, it includes an ST-LINK/V2 embedded debug tool, a 2.4" QVGA TFT LCD, an external SDRAM of 64 Mbits,
a gyroscope ST MEMs, a USB OTG micro-AB connector, LEDs and pushbuttons.
Key Features
    [li]STM32F429ZIT6 microcontroller featuring 2 MB of Flash memory, 256 KB of RAM in an LQFP144 package[/li][li]On-board ST-LINK/V2 with selection mode switch to use the kit as a standalone[/li][li]ST-LINK/V2 (with SWD connector for programming and debugging)[/li][li]Board power supply: through the USB bus or from an external 3 V or 5 V supply voltage[/li][li]2.4" QVGA TFT LCD[/li][li]SDRAM 64 Mbits[/li][li]L3GD20, ST MEMS motion sensor, 3-axis digital output gyroscope[/li][li]Six LEDsD1 (red/green) for USB communicationLD2 (red) for 3.3 V power-onTwo user LEDsD3 (green), LD4 (red)Two USB OTG LEDsD5 (green) VBUS and LD6 (red) OC (over-current)[/li][li]Two pushbuttons (user and reset)[/li][li]USB OTG with micro-AB connector[/li][li]Extension header for LQFP144 I/Os for a quick connection to the prototyping board and an easy probing[/li]
brstm32f4.pdf (1.98 MB, 下载次数: 4750)
DM00039672.pdf (204 KB, 下载次数: 3297)
DM00093903.pdf (982 KB, 下载次数: 3520)
DM00094498.pdf (270 KB, 下载次数: 2944)
 楼主| 发表于 2013-9-16 09:51:25 | 显示全部楼层
STMicroelectronics STM32F429I-DISCO 平均价格33美刀
发表于 2013-11-19 10:55:59 | 显示全部楼层
[s:141]  [s:141]  [s:141]
GMT+8, 2026-11-23 07:00 , Processed in 0.894045 second(s), 27 queries .
