查看: 7037|回复: 1
[有问必答] 写了一个矩阵按键程序,为什么不对,求大神
发表于 2015-11-23 10:51:15 | 显示全部楼层 |阅读模式
按键初始化程序:
void KEY_Init(void)
   GPIO_InitTypeDef  GPIO_InitStructure;
     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
   GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4;
   GPIO_Init(GPIOA,&GPIO_InitStructure);
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
按键扫描程序:
int KEY_Scan(void)
u8 KeyVal;
GPIO_Write(GPIOA,(GPIOA->ODR & 0xffec | 0x0013));
if((GPIOA->IDR & 0x0013)==0x0000)
    return 0;
  Delay(0x2710);
   if((GPIOA->IDR & 0x00e0)==0x0000)
   return 0;
   GPIO_Write(GPIOA,(GPIOA->ODR & 0xffec | 0x0001));
    switch(GPIOA->IDR & 0x00e0)
         case 0x1000: KeyVal=1; break;
         case 0x2000: KeyVal=4; break;
         case 0x4000: KeyVal=7; break;
    GPIO_Write(GPIOA,(GPIOA->ODR & 0xffec | 0x0002));
         case 0x1000: KeyVal=2; break;
         case 0x2000: KeyVal=5; break;
         case 0x4000: KeyVal=8; break;
    GPIO_Write(GPIOA,(GPIOA->ODR & 0xffec | 0x0010));
         case 0x1000: KeyVal=3; break;
         case 0x2000: KeyVal=6; break;
         case 0x4000: KeyVal=9; break;
    return KeyVal;
主函数:
while(1)
        key=KEY_Scan();
            switch(key)
                case 1:
                       GPIO_SetBits(GPIOF, GPIO_Pin_6);
                case 4:
                case 7:
发表于 2015-11-23 11:16:29 | 显示全部楼层
你的这个矩阵键盘原理图发个截图看下。
GMT+8, 2026-11-28 13:39 , Processed in 0.206381 second(s), 24 queries .
