查看: 6753|回复: 0
USB音频类,CDC类,HID类等所有支持类型的规格书汇总
发表于 2015-10-7 09:45:06 | 显示全部楼层 |阅读模式
官方网址:http://www.usb.org/developers/docs/devclass_docs/
Audio Class
Audio Device Class Spec for Basic Audio Devices and Adopters Agreement (.zip format, size 1.33MB)
Audio Device Document 1.0
Audio Data Formats 1.0
Audio Terminal Types 1.0
USB MIDI Devices 1.0
Audio Devices Rev. 2.0 Spec and Adopters Agreement (.zip format, size 1.28 MB)
Audio/Video Device Class
Audio/Video Device Class v1.0 Spec and Adopters Agreement (.zip format, size 11.5 MB)
AVSchema Documentation
AVSchema Files:  http://avschemas.usb.org/v1/avschema.xsd and http://avschemas.usb.org/v1/avtypes.xsd
AVDD Creator User Manual (.pdf format, 472 KB)
AVDD Creator Installer (.zip format, 126 MB)
USB Device Class Definition for Audio/Video Devices Basic Device Profile (BDP) (.pdf format, 1.20 MB)
Battery Charging
Battery Charging v1.2 Spec and Adopters Agreement (.zip format, size 1.30 MB)
Battery Charging v1.1 Spec and Adopters Agreement (.zip format, size 292 KB)
USB Battery Charging 1.2 Compliance Plan (Revision 1.0)
Billboard Device Class
Billboard Device Class Spec Revision 1.1 and Adopters Agreement (.zip format, size 524KB)
Cable and Connector
USB 3.0 Connectors and Cable Assemblies Document Rev. 1.02
Cable and Connector Class 2.0
Series 'A' Plug form factor Guideline 1.0
USB Connector for Mezzanine Applications Guidelines Rev. 1.0
Micro-USB Cables and Connectors v1.01 Spec and Adopters Agreement
USB Thin Card v1.0 and Adopters Agreement
Common Class (CCS)
Common Class Base Specification 1.0
Communications Device Class
Class definitions for Communication Devices 1.2 (.zip file format, size 3.42 MB)
the components of CDC 1.1 have been reorganized as five separate documents and associated errata:
- ATM120.pdf -- CDC Subclass for Asynchronous Transfer Mode Devices
- CDC120-20101103-track.pdf - CDC Subclass for Communications Devices
    - CDC120-Errata1.pdf ECM120.pdf - CDC Subclass for Ethernet Control Model Devices
- ISDN120.pdf -- CDC Subclass for ISDN Devices
- PSTN120.pdf -- CDC Subclass for PSTN devices
- WMC110-20101103-track.pdf - CDC Subclass for Wireless Mobile Communication Devices 1.1
- WMC110-Errata1.pdf and CDC v1.2 WMC v1.1 Errata 1 Adopters Agreement
Errata updates for CDC v1.2 and WMC v1.1 as of DEC-2012 (.zip file format, size 2.5 MB)
    2012-08-02-CDC120_errata.pdf
    2012-08-02-CDCErrata-1.pdf
- CDC Subclass for Wireless Mobile Communications Devices 1.1
    2012-07-31-WMC110_errata.pdf
    2012-07-31-WMCErrata-1.pdf
- CDC v1.2 WMC v1.1 Errata 1 Adopters Agreement
CDC Subclass Specification for Ethernet Emulation Model Devices 1.0
Network Control Model Devices Specification v1.0 and errata and Adopters Agreement (.zip format, size 948 KB)
Mobile Broadband Interface Model v1.0 Errata -1 and Adopters Agreement (.zip format, size 3.62MB)
MBIM Compliance Testing v1.0 (pdf 1.23MB)
Content Security
Device Class Definition for Content Security Devices 2.0
Content Security Method 1 - Basic Authentication Protocol 1.0
Content Security Method 2 - USB Digital Transmission Content Protection Implementation 1.0
Content Security Method 5 - High-bandwidth Digital Content Protection 2.1 (HDCP 2.1) Implementation
Debug Device Class
USB 3.1 Device Class Specification for Debug Devices (included in the USB 3.1 zip file)
Device Firmware Upgrade Group
Device Firmware Upgrade 1.1 (new version 31-Aug-2004)
HID Class
HID Information
Imaging Class
Still Image Capture Device Definition 1.0 and Errata as of 16-Mar-2007 (.zip format, size 200 KB)
IrDA
IrDA Bridge Device Definition 1.0
Mass Storage
Mass Storage Class Specification Overview 1.4
Mass Storage Bulk Only 1.0
Mass Storage Control/Bulk/Interrupt (CBI) Specification 1.1
Mass Storage UFI Command Specification 1.0
Mass Storage Bootability Specification 1.0
Lockable Mass Storage Specification 1.0 and Adopters Agreement (.zip format, size 288 KB)
  - Lockable Mass Storage IP Disclosure
USB Attached SCSI Protocol (UASP) v1.0 and Adopters Agreement (.zip format, size 204 KB)
USB Mass Storage Class Specification for UASP Bootability v1.0 and Adopters Agreement (.zip format, size 503 KB)
Media Agnostic USB
Media Agnostic USB v1.0 Spec and Adopters Agreement (.zip format, size 1.89MB)
Media Transfer Protocol
Media Transfer Protocol v.1.1 Spec and MTP v.1.1 Adopters Agreement (.zip format, size 1.98MB)
Monitor
Monitor Device Document 1.0
OpenUSBDI
OpenUSBDI Specification 1.0
Personal Healthcare
Personal Healthcare Rev. 1.0, Errata for USB Personal Health Care Device Class and Personal Healthcare Adopters Agreement (.zip format, size 386 KB)
Physical Interface Devices
Device Class Definition for PID 1.0
Power
Power Device Class Document 1.0
Printer Class
Printer Device Class Document 1.1
IPP Protocol 1.0 and Adopters Agreement (.zip, 1.32 MB)
Smart Card Class
Smart Card CCID version 1.1
Smart Card ICCD version 1.0
Test & Measurement Class
Test & Measurement Class Specifications
Video Class
Video Class 1.5 document set (.zip format, size 6.58MB)
   UVC 1.5 Class specification.pdf
   USB_Video_Example 1.5.pdf
   USB_Video_FAQ_1.5.pdf
   USB_Video_Payload_DV_15.pdf
   USB_Video_Payload_Frame_Based_1.5.pdf
   USB_Video_Payload_H264_1.5.pdf
   USB_Video_Payload_MPEG-2_TS_1.5.pdf
   USB_Video_Payload_Uncompressed_1.5.pdf
   USB_Video_Payload_VP8_1.5.pdf
   USB_Video_Payload_Stream_Based_1.5.pdf
   USB_Video_Transport_1.5.pdf
   USB_Video_Payload_MJPEG_1.5.pdf
   USB_Video_Temporal_Encoder_Examples_1.5.pdf
Video Class 1.1 document set (.zip format, size 6.78 MB)
    USB_Video_Class_1.1
    USB_Video_Identifiers_1.1
    USB_Video_Payload_DV_1.1
    USB_Video_Payload_Frame_Based_1.1
    USB_Video_Payload_MJPEG_1.1
    USB_Video_Payload_MPEG-2_TS_1.1
    USB_Video_Payload_Uncompressed_1.1
    USB_Video_Payload_Stream_Based_1.1
    USB_Video_Payload_H 264_1.0
    USB_Video_Transport_1.1
    USB_Video_Example_1.1
    USB_Video_FAQ_1.1
    USB_Video_Payload_H264_09Aug2011_errata.pdf
GMT+8, 2026-10-26 01:23 , Processed in 0.112961 second(s), 24 queries .
