查看: 4053|回复: 1
[RL-CAN] STM32F1的CAN时钟
发表于 2015-9-25 00:17:51 | 显示全部楼层 |阅读模式
 楼主| 发表于 2015-9-25 00:18:49 | 显示全部楼层
STM32F103的CAN时钟由APB1提供,所有最高36MHz
/************************* CAN Hardware Configuration ************************/
// *** <<< Use Configuration Wizard in Context Menu >>> ***
// <o> CAN Peripheral Clock (in Hz) <1-1000000000>
//     <i> Same as PCLK1
#define CAN_CLK               36000000
// *** <<< End of Configuration section             >>> ***
GMT+8, 2026-11-25 22:11 , Processed in 0.175181 second(s), 27 queries .
