查看: 7978|回复: 1
AD8065 AD8066 高速运放 带宽140M 电压5-24V
发表于 2012-6-7 17:41:53 | 显示全部楼层 |阅读模式
AD8065_8066.pdf (405 KB, 下载次数: 238)
Qualified for automotive applications
FET input amplifier
1 pA input bias current
Low cost
High speed: 145 MHz, −3 dB bandwidth (G = +1)
180 V/μs slew rate (G = +2)
Low noise
7 nV/√Hz (f = 10 kHz)
0.6 fA/√Hz (f = 10 kHz)
Wide supply voltage range: 5 V to 24 V
Single-supply and rail-to-rail output
Low offset voltage 1.5 mV maximum
High common-mode rejection ratio: −100 dB
Excellent distortion specifications
SFDR −88 dBc @ 1 MHz
Low power: 6.4 mA/amplifier typical supply current
No phase reversal
Small packaging: SOIC-8, SOT-23-5, and MSOP-8
发表于 2016-6-1 15:51:48 | 显示全部楼层
楼主发帖辛苦了,谢谢分享!!!!!!!!! [s:149]
GMT+8, 2026-11-23 12:04 , Processed in 1.197492 second(s), 27 queries .
