查看: 4121|回复: 1
[emWin] emwin 在已有的窗口添加新的控件,为什么点击新的控件没有反映
发表于 2015-9-16 17:34:38 | 显示全部楼层 |阅读模式
我在已有的窗口,点击一个编辑控件(edit)后,让此edit的值改变,同时又创建了一个新的edit控件。想法是点击新的控件,也想改变新edit的值。但是一直改变不了。调试发现,根本不会进入新的edit的swith里面。下面是代码,请教哪个大神解答,如何实现。
#include "MainTask.h"
#include "bsp.h"
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include "BUTTON.h"
#include "CHECKBOX.h"
#include "DROPDOWN.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include &quotROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
*       Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
    { FRAMEWIN_CreateIndirect,  "armfly",            0,                       0,  0,  480,272,FRAMEWIN_CF_MOVEABLE,0},
    { EDIT_CreateIndirect,      "armfly",            GUI_ID_EDIT0,            239,36, 100,21, 0,0},
    { TEXT_CreateIndirect,      "TextMode",          GUI_ID_TEXT0,            81, 36, 106,24, 0,0},
    { TEXT_CreateIndirect,      "FloatMode",         GUI_ID_TEXT4,            81, 199,118,24, 0,0},
    { TEXT_CreateIndirect,      "DecMode",           GUI_ID_TEXT3,            81, 158,94, 24, 0,0},
    { TEXT_CreateIndirect,      "BinMode",           GUI_ID_TEXT2,            81, 117,94, 24, 0,0},
    { TEXT_CreateIndirect,      "HexMode",           GUI_ID_TEXT1,            81, 73, 94, 24, 0,0},
    { EDIT_CreateIndirect,      "FFFF",              GUI_ID_EDIT1,            239,73, 100,21, 0,0},
    { EDIT_CreateIndirect,      "11110000",          GUI_ID_EDIT2,            239,120,100,21, 0,0},
    { EDIT_CreateIndirect,      "128",               GUI_ID_EDIT3,            239,163,100,21, 0,0},
    { EDIT_CreateIndirect,      "12.123456",         GUI_ID_EDIT4,            239,199,100,21, 0,0}
**      FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_PAINT
    WM_HWIN hWin = pMsg->hWin;
**      FunctionName:void InitDialog(WM_MESSAGE * pMsg)
**      call this function in _cbCallback --> WM_INIT_DIALOG
    //FRAMEWIN
    FRAMEWIN_SetFont(hWin,&GUI_Font32B_ASCII);
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
    FRAMEWIN_SetTitleHeight(hWin,35);
    //GUI_ID_EDIT0
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT0),&GUI_Font16B_ASCII);
    EDIT_SetText(WM_GetDialogItem(hWin,GUI_ID_EDIT0),"armfly");
    //GUI_ID_TEXT0
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT0),&GUI_Font24B_ASCII);
    //GUI_ID_TEXT4
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT4),&GUI_Font24B_ASCII);
    //GUI_ID_TEXT3
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT3),&GUI_Font24B_ASCII);
    //GUI_ID_TEXT2
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT2),&GUI_Font24B_ASCII);
    //GUI_ID_TEXT1
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT1),&GUI_Font24B_ASCII);
    //GUI_ID_EDIT1
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT1),&GUI_Font16B_ASCII);
    EDIT_SetHexMode(WM_GetDialogItem(hWin,GUI_ID_EDIT1),65535,0,255);
    //GUI_ID_EDIT2
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT2),&GUI_Font16B_ASCII);
    EDIT_SetBinMode(WM_GetDialogItem(hWin,GUI_ID_EDIT2),240,0,255);
    //GUI_ID_EDIT3
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT3),&GUI_Font16B_ASCII);
    EDIT_SetDecMode(WM_GetDialogItem(hWin,GUI_ID_EDIT3),128,0,10000,0,0);
    //GUI_ID_EDIT4
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT4),&GUI_Font16B_ASCII);
    EDIT_SetFloatMode(WM_GetDialogItem(hWin,GUI_ID_EDIT4),12.12346,0,255,6,0);
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                case GUI_ID_CANCEL:
                                case GUI_ID_EDIT3: // Notifications sent by 'Edit'
                                        switch(NCode) {
                                                    EDIT_SetValue(WM_GetDialogItem(pMsg->hWin, GUI_ID_EDIT3), 800);
                                                EDIT_CreateEx(345,163,100,21,pMsg->hWin,WM_CF_SHOW,0,GUI_ID_EDIT5,5);
                                                EDIT_SetFont(WM_GetDialogItem(pMsg->hWin,GUI_ID_EDIT5),&GUI_Font16B_ASCII);
                                                EDIT_SetDecMode(WM_GetDialogItem(pMsg->hWin,GUI_ID_EDIT5),900,0,999,0,0);
                                case GUI_ID_EDIT5: // Notifications sent by 'Edit'
                                        switch(NCode) {
                                                    EDIT_SetValue(WM_GetDialogItem(pMsg->hWin, GUI_ID_EDIT5), 700);
        default:
            WM_DefaultProc(pMsg);
*       MainTask
void MainTask(void)
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
    FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
    BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
    CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
    DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
    SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
    SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
    HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
    RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
    GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
发表于 2015-9-17 09:07:10 | 显示全部楼层
把光标显示出来,确定是否点击到EDIT控件上了。
GMT+8, 2026-11-23 07:53 , Processed in 0.955846 second(s), 24 queries .
