查看: 7858|回复: 1
常用的低电压轨到轨运放(LMV358/324,  SGM358/324)
发表于 2012-6-7 17:35:07 | 显示全部楼层 |阅读模式
LMV358 324.pdf (71 KB, 下载次数: 250)
SGM321-358-324.pdf (558 KB, 下载次数: 231)
LMV358和SGM358对比
LMV358
SGM358
电源电压
2.7-5.5V
2.5-5.5V
温度范围
-40~+85℃
-40~+85℃
输入偏置电压
1.7mV
0.8mV
Input bias current
偏置电流
11nA
11pA
Input offset current
失调电流
5nA
10pA
Output Current
18.8mA
23mA
bandwidth
1MHz
1M
CMRR Common-mode rejection ratio
63dB
70 dB
Common-mode input voltage 0 –0.2 VICR range
1.9V
0.1!+5.6V
Supply-voltage rejection ratio
60dB
82dB
Output swing
RL = 10 kΩ to 1.35 V
VCC – 10
60mV
80mV  (10K)
Supply current
140uA
120uA
Equivalent input noise voltage
46nV/√Hz
27 nV/√Hz
发表于 2014-3-11 09:34:47 | 显示全部楼层
谢谢你!  仔细看看~~
GMT+8, 2026-11-23 12:27 , Processed in 1.492267 second(s), 26 queries .
