查看: 10004|回复: 7
[μCGUI] 版主帮忙,UCGUI 显示问题
发表于 2013-7-12 11:50:45 | 显示全部楼层 |阅读模式
建了一个FRAMEWIN的框架窗体。不能用函数例如GUI_DispString() 在上面显示字符。。是不是要设置透明什么的,,不大懂。。请版主解答下。。
发表于 2013-7-12 11:52:47 | 显示全部楼层
把你的代码贴出来
 楼主| 发表于 2013-7-12 12:00:26 | 显示全部楼层
    { FRAMEWIN_CreateIndirect,   NULL,               0,                       0,  0,  480,272,FRAMEWIN_CF_MOVEABLE,0},
void MainTask(void)
    GUI_Init();
    WM_SetDesktopColor(GUI_BLUE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
   GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
  GUI_DispStringAt("HELLO WORLD",200,200);
就是用ucguibuilt 建立framewin后 在maintask 里写了个显示字符的函数 ,,如果不建立framewin框架 则可以正常显示。。。
 楼主| 发表于 2013-7-12 13:49:49 | 显示全部楼层
eric2013:把你的代码贴出来 (2013-07-12 11:52)
void MainTask(void)
    GUI_Init();
发表于 2013-7-12 17:39:40 | 显示全部楼层
你这种情况是把他显示在了桌面窗口上面,并没有显示到对话框上面
发表于 2013-7-12 17:56:59 | 显示全部楼层
给你写了一个代码,研究一下
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include "BUTTON.h"
#include "CHECKBOX.h"
#include "DROPDOWN.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include &quotROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
//EventsFunctionList
//EndofEventsFunctionList
*       static data
*       Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
    { FRAMEWIN_CreateIndirect,  "Caption",           0,                       0,  0,  480,272,FRAMEWIN_CF_MOVEABLE,0}
**      FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_PAINT
    WM_HWIN hWin = pMsg->hWin;
        GUI_DispStringAt("HELLO WORLD",10,10);
**      FunctionName:void InitDialog(WM_MESSAGE * pMsg)
**      call this function in _cbCallback --> WM_INIT_DIALOG
    //FRAMEWIN
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
    FRAMEWIN_SetTitleHeight(hWin,20);
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                case GUI_ID_CANCEL:
        default:
            WM_DefaultProc(pMsg);
*        函 数 名: MainTask
*        功能说明: GUI主函数
*        形    参:无
*        返 回 值: 无
void MainTask(void)
    GUI_Init();
    GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
    while(1)
        GUI_Delay(100);
 楼主| 发表于 2013-7-13 15:53:00 | 显示全部楼层
eric2013:给你写了一个代码,研究一下
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
....... (2013-07-12 17:56)
3Q 你的方法 解决了 。。。
发表于 2013-7-15 10:56:08 | 显示全部楼层
学习了
GMT+8, 2026-11-23 06:01 , Processed in 0.225880 second(s), 27 queries .
