查看: 11979|回复: 7
[μCGUI] 请教 uCGUI对话框中TEXT显示的问题
发表于 2013-7-11 21:16:30 | 显示全部楼层 |阅读模式
我现在创建了一个对话框用于调整时间: 小时 分钟,小时对应两个按钮 “+” “-” , 分钟对应两个按钮“+” ,“-” ,小时和分钟分别用两个TEXT显示,初始是12 12 ,现在遇到的问题是:
当我先点击分钟的"+"后 分钟变成13,点击小时"+"后按说也应该变成13,但是变成了1313,测试发现,小时的那个TEXT显示的时候总会把分钟的一块显示了,弄不明白了,下面是我的代码,谢谢指教:
#include "includes.h"
u8    timeflag;
char    timeh[2]; //小时
char    timem[2];  //分钟
u8    timehnum=12;
u8    timemnum=12;
TEXT_Handle hText1,hText2;
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
    { FRAMEWIN_CreateIndirect,  "TimeSet",           0,                       0,  0,  320,240,FRAMEWIN_CF_MOVEABLE,0},
    { BUTTON_CreateIndirect,    "+",           GUI_ID_BUTTON27,          51, 17, 40, 33, 0,0},
    { BUTTON_CreateIndirect,    "+",           GUI_ID_BUTTON28,          204,17, 40, 33, 0,0},
    { BUTTON_CreateIndirect,    "-",           GUI_ID_BUTTON29,          51, 120,40, 33, 0,0},
    { BUTTON_CreateIndirect,    "-",           GUI_ID_BUTTON30,          204,120,40, 33, 0,0},
    { BUTTON_CreateIndirect,    "OK",                GUI_ID_BUTTON31,          34, 186,75, 23, 0,0},
    { BUTTON_CreateIndirect,    "Cancel",            GUI_ID_BUTTON32,          192,186,75, 23, 0,0},
    { TEXT_CreateIndirect,      "12",                GUI_ID_TEXT3,            204,78, 73, 23, 0,0},
    { TEXT_CreateIndirect,      "12",                GUI_ID_TEXT4,            51, 78, 73, 23, 0,0}
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
        int Id,NCode;
        WM_HWIN hWin = pMsg->hWin;
        hText2 = WM_GetDialogItem(hWin,GUI_ID_TEXT4);
        hText1 = WM_GetDialogItem(hWin,GUI_ID_TEXT3);
        switch(pMsg -> MsgId)
        case WM_INIT_DIALOG:
                TEXT_SetFont(hText1,&GUI_Font24_1);
                TEXT_SetFont(hText2,&GUI_Font24_1);
          case WM_NOTIFY_PARENT:
                  Id = WM_GetId(pMsg ->hWinSrc);
                  NCode = pMsg ->Data.v;
                  switch(NCode)
                                switch(Id)
                                        case GUI_ID_BUTTON31:
                                                timeflag=1; //ok
                                                GUI_EndDialog(pMsg->hWin, 1);
                                        case GUI_ID_BUTTON32: //cancel
                                                timeflag=2;
                                        case GUI_ID_BUTTON27:  //小时加
                                                timehnum++;
                                                if(timehnum==24)
                                                        timehnum=0;
                                                timeh[0]=(timehnum/10)+0x30;
                                                timeh[1]=(timehnum%10)+0x30;
                                                TEXT_SetText(hText2,timeh);
                                                TEXT_SetFont(hText2,&GUI_Font24_1);    //ucGUI自带
                                        case  GUI_ID_BUTTON29: //小时减
                                                timehnum--;
                                                if(timehnum==0)
                                                        timehnum=23;
                                        case  GUI_ID_BUTTON28: //分钟加
                                                timemnum++;
                                                if(timemnum==60)
                                                        timemnum=0;
                                                timem[0]=(timemnum/10)+0x30;
                                                timem[1]=(timemnum%10)+0x30;
                                                TEXT_SetText(hText1,timem);
                                                TEXT_SetFont(hText1,&GUI_Font24_1);    //ucGUI自带
                                        case  GUI_ID_BUTTON30: //分钟减
                                                timemnum--;
                                                if(timemnum==0)
                                                        timemnum=59;
                          default:
        default:
                  WM_DefaultProc(pMsg);
void Task_Time(void *pdata)
        BUTTON_SetDefaultFont(&GUI_Font24_1);
        GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbCallback, 0, 0, 0);
        while(1)
                if(timeflag==1) //ok
                        timeflag=0;
                        RTC_Configuration();
                        RTC_SetCounter(timehnum*3600+timemnum*60); //设定时间
                        //等待上次写操作完成 才能写操作
                        RTC_WaitForLastTask();
                        BKP_WriteBackupRegister(BKP_DR1,0xa5a5); //做个记号
                        Go_MainMenu(); //进入主菜单
                        OSTaskDel(OS_PRIO_SELF);    //删除自己
                if(timeflag==2)
                OSTimeDlyHMSM(0,0,0,15);
发表于 2013-7-11 22:31:08 | 显示全部楼层
1. 你写的程序有两个语法错误
    case WM_NOTIFICATION_RELEASED:    这个后面没有相应的break
    case WM_NOTIFY_PARENT:                     这个后面也没有相应的break
2.  还有就是不用每次都设置字体,设置一次就可以了
建议以后用uCGUIBulder来做,简单方便。
 楼主| 发表于 2013-7-11 22:54:46 | 显示全部楼层
eric2013:1. 你写的程序有两个语法错误
    case WM_NOTIFY_PARENT:               .. (2013-07-11 22:31)
谢谢,更改了.....不过还是出现那种问题......
发表于 2013-7-11 23:28:42 | 显示全部楼层
回 lhwaizhu 的帖子
lhwaizhu:谢谢,更改了.....不过还是出现那种问题...... (2013-07-11 22:54)
又看了一遍,实在是没找到别的错误了。
发表于 2013-7-12 08:47:52 | 显示全部楼层
你数组没有结束符,字符串应该是以‘\\0’结尾   timeh[2] 改成 timeh[3] ; timem[2] 改成 timem[3];
在你
后面加 timeh[2] = ‘\\0’; 或  timeh[2] = 0;
同样
后面加 timem[2] =‘\\0’; 或  timem[2] = 0;
 楼主| 发表于 2013-7-12 18:03:54 | 显示全部楼层
回 ztzjl2010 的帖子
ztzjl2010:你数组没有结束符,字符串应该是以‘\\0’结尾   timeh[2] 改成 timeh[3] ; timem[2] 改成 timem[3];
在你
....... (2013-07-12 08:47)
谢谢了...问题解决了....是这个原因... timeh[2] 改成 timeh[3] ; timem[2] 改成 timem[3];就行了...
我思故我在
发表于 2013-8-27 00:06:06 | 显示全部楼层
[s:141]
研究生
发表于 2016-1-21 12:14:11 | 显示全部楼层
学习了  刚开始接触emwin
GMT+8, 2026-11-23 08:07 , Processed in 0.664421 second(s), 30 queries .
