查看: 10339|回复: 4
[有问必答] stm32f103定时器中断、外部中断例子
在这个世界上总有一条除了你以外
发表于 2013-7-8 17:12:59 | 显示全部楼层 |阅读模式
刚刚开始学习stm32f103的那个开发板,用的库是3.5的,现在想写一个定时器中断和外部中断的程序,但是历程里面都没有啊,完全没有头绪,有没有大神能解决一下呢。
just connect me
发表于 2013-7-8 17:35:41 | 显示全部楼层
基础例程中应该有
在这个世界上总有一条除了你以外
 楼主| 发表于 2013-7-8 19:57:51 | 显示全部楼层
里面的基础例程都看过:
int main(void)
  RCC_Configuration();
  GPIO_Configuration();
  DMA_Configuration();
  /* TIM1 Peripheral Configuration --------------------------------------------*/
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = 2000-1;//72M/x=frq R*C=0.025 R=100K,c=100000p=0.1uf=0.0000001f
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 2;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* Channel 3 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 50;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 Update DMA Request enable */
  TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  while (1)
void RCC_Configuration(void)
  SystemInit();
  /* TIM1, GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
                         RCC_APB2Periph_GPIOB, ENABLE);
  /* DMA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
void GPIO_Configuration(void)
  /* GPIOA Configuration: Channel 3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* GPIOB Configuration: Channel 3N as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
定时器这样写是什么方式啊,不知道中断的话该怎么写
just connect me
发表于 2013-7-8 20:34:19 | 显示全部楼层
中断服务程序在 sm32f103_it.c 文件可以找到。
在这个世界上总有一条除了你以外
 楼主| 发表于 2013-7-8 21:08:32 | 显示全部楼层
能说说怎么初始化配置吗,或者有个例程最好,灰常感谢
just connect me
GMT+8, 2026-11-22 13:29 , Processed in 0.444816 second(s), 24 queries .
