查看: 841|回复: 12
[LTDC] 发现个问题,sdram+ltdc+seggerRTT导致seggerRTT输出混乱
发表于 2026-9-19 21:25:33 | 显示全部楼层 |阅读模式
实在不好意思,在下用的GD32H7,但考虑到GD32H7与stm32h7高度相似,咱论坛又是国内mcu水平相当顶尖环境,so...
先说现象:只要是gd32h7+tli(也就是LTDC)+exmc(也就是FMC)驱动sdram刷屏,并且启用了seggerRTT用于输出调试信息。不管是freeRTOS、rtt-nano还是裸机环境,只要让seggerRTT在开机时大量输出内容(比如初始化日志),那么随后在开启ltdc后,seggerRTT就会在明明没有软件调用它的前提下,大量输出历史信息,就好像是_SEGGER_RTT的upbuffer的rdOff的值跑飞了一样,大量输出之前已经输出过的内容,且内容长度不定,输出数量不定。sdram为16位宽、32MB、166MHz频率,屏幕是1024*600@RGB565.
比如:“
int main(void)
    sys_cache_enable();                     /* 使能CPU cache */
//    SEGGER_RTT_printf(0, "RTT TEST 0000: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0001: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0002: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0003: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0004: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0005: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0006: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0007: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0008: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0009: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0010: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0011: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0012: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0013: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0014: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0015: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0016: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0017: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0018: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
//    SEGGER_RTT_printf(0, "RTT TEST 0019: 0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz\r\n");
    delay_init(600);                        /* 延时初始化 */
    usart_init(115200);                     /* 初始化串口 */
    usmart_init(300);	                      /* 初始化USMART */
    led_init();							                /* 初始化LED */
    mpu_memory_protection();                /* 保护相关存储区域 */
    sdram_init(EXMC_SDRAM_DEVICE0);         /* 初始化SDRAM */
    lcd_init();                             /* 初始化LCD */
    key_init();                             /* 初始化按键 */
    tp_dev.init();                          /* 触摸屏初始化 */
    timerx_int_init(10 - 1, 30000 - 1);     /* 300 000 000 / 30000 = 10KHz 10KHz的计数频率,计数10次为1ms */
    my_mem_init(SRAMIN);                    /* 初始化内部SRAM内存池 */
    my_mem_init(SRAMEX);                    /* 初始化外部SDRAM内存池 */
    my_mem_init(SRAMDTCM);                  /* 初始化内部DTCM内存池 */
    my_mem_init(SRAMITCM);                  /* 初始化内部ITCM内存池 */
    delay_ms(1000);
    lv_init();			                        /* lvgl系统初始化 */
    lv_port_disp_init();                    /* lvgl显示接口初始化,放在lv_init()的后面 */
    lv_port_indev_init();                   /* lvgl输入接口初始化,放在lv_init()的后面 */
    lv_demo_benchmark();                       /* lvgl例程 */
  	while (1)
//        tp_dev.scan(0);	                      /* 触摸扫描 */
        lv_task_handler();                    /* lvgl的事务处理 */
这是裸机程序,那么看rtt-viewer输出:
0-19行内容被输出不止一次。调整过ltdc频率,当频率下降、swd频率下降时,重复输出的频率会降低,比如ltdc 15MHz、swd 500khz;当ltdc频率上升、swd上升时,重复输出频率增加,但也不是严格相关。
我gd32h7反复测试确认,之前运行好的例程,只要加上seggerRTT,马上复现;之前seggerRTT运行好好的程序,只要启动ltdc(tli),问题马上出现。
deepseek已经技穷,gpt表示他没思路了。群友表示有可能axi总线竞争,但我改了半天axi的QoS也没看到改善:
void bsp_syscfg_axi_config(void) {
    AXI_SPX_RDQOS_CTL(SLAVE_PORT0) |= ((0x0f) & AXI_SPX_RDQOS_CTL_RDQOS); /* 将 CPU 读 QoS 设为最高优先级 0xF */
    AXI_SPX_RDQOS_CTL(SLAVE_PORT1) |= ((0x07) & AXI_SPX_RDQOS_CTL_RDQOS); /* 将 CPU 读 QoS 设为最高优先级 0xF */
    AXI_SPX_RDQOS_CTL(SLAVE_PORT5) |= ((0x00) & AXI_SPX_RDQOS_CTL_RDQOS); /* 将 TLI 读 QoS 设为最低优先级 0x0 */
    // AXI_MPXBM_ISS_CTL(MASTER_PORT4) |= AXI_MPXBM_ISS_CTL_RD_ISSOV;        // 将EXMC的读发起能力限制为1
    /* 限制TLI(MASTER_PORT5)的读发起能力为1 */
    AXI_MPX_ISS_CTL(MASTER_PORT5) |= AXI_MPX_ISS_CTL_RD_ISSOV;
    LOG_DBG_NORECORD("TLI SP5 RDQOS_CTL = 0x%08X\n", AXI_SPX_RDQOS_CTL(SLAVE_PORT5));
    LOG_DBG_NORECORD("TLI SP5 WRQOS_CTL = 0x%08X\n", AXI_SPX_WRQOS_CTL(SLAVE_PORT5));
    LOG_DBG_NORECORD("TLI SP5 ISS_CTL   = 0x%08X\n", AXI_SPX_ISS_CTL(SLAVE_PORT5));
    LOG_DBG_NORECORD("CPU SP1 RDQOS_CTL = 0x%08X\n", AXI_SPX_RDQOS_CTL(SLAVE_PORT1));
    LOG_DBG_NORECORD("CPU SP1 WRQOS_CTL = 0x%08X\n", AXI_SPX_WRQOS_CTL(SLAVE_PORT1));
    LOG_DBG_NORECORD("EXMC TARG4 BM_ISS_CTL     = 0x%08X\n", AXI_MPXBM_ISS_CTL(MASTER_PORT4));
    LOG_DBG_NORECORD("AXI_SRAM TARG6 BM_ISS_CTL = 0x%08X\n", AXI_MPXBM_ISS_CTL(MASTER_PORT6));
    // /* 将 CPU 读 QoS 设为最高优先级 0xF */
    // __AXI_SPX_READ_QOS_SET(SLAVE_PORT1, 0xF);
    // /* 将 TLI 读 QoS 设为最低优先级 0x0 */
    //  __AXI_SPX_READ_QOS_SET(SLAVE_PORT5, 0x0);
我之前尝试降低ltdc频率、sdram频率,降低swd频率,把RTT控制块和上下缓存扔进TCM比如0x20000000,问题依旧出现。菜鸟实在是没招了,遂来论坛求助。
发表于 2026-9-20 09:54:32 | 显示全部楼层
你的xxxx.s启动文件栈空间打开的多少,使用函数SEGGER_RTT_printf,这个空间要够大。
RTT的函数SEGGER_RTT_printf需要较大的栈空间,如果大家移植RTT开辟的空间不足会硬件异常
https://forum.anfulai.cn/forum.p ... 8809&fromuid=58
点评
但就算如此,还是会出现,只要启动tli,也就是ltdc的gd32版本,就会导致seggerRTT无序、偶发输出历史内容,只要关掉tli就没这个问题。不管tli是从sdram搬运数据还是从axi sram搬运数据,都是这样  详情 回复 发表于 2026-9-20 11:17
[mw_shl_code=c,true]Stack_Size EQU 0x00004000 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; Heap Configuration ;  详情 回复 发表于 2026-9-20 11:16
 楼主| 发表于 2026-9-20 11:16:23 | 显示全部楼层
RTT的函数SEGGER_R ...
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x000001000
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
我rtt-nano的栈空间是16kB,
Stack_Size      EQU     0x00001000
__initial_sp
; </h>
Heap_Size       EQU     0x000000800
__heap_base
__heap_limit
freeRTOS和裸机的栈空间是4kB。
我的seggerRTT的printf的数组空间是256B:
#ifndef SEGGER_RTT_PRINTF_BUFFER_SIZE
#define SEGGER_RTT_PRINTF_BUFFER_SIZE (256)// Size of buffer for RTT printf to bulk-send chars via RTT     (Default: 64)
#endif
而且我那个log_dbg_norecord没用printf,直接用的:
    // 通过segger-rtt输出主要内容
    SEGGER_RTT_Write(0, printBuf + sizeof(innerTime), printbuf_datlen - sizeof(innerTime));
其中printBuf是静态的,不是动态的。
 楼主| 发表于 2026-9-20 11:17:39 | 显示全部楼层
RTT的函数SEGGER_R ...
发表于 2026-9-20 11:47:59 | 显示全部楼层
fox0815 发表于 2026-9-20 11:17
但就算如此,还是会出现,只要启动tli,也就是ltdc的gd32版本,就会导致seggerRTT无序、偶发输出历史内容 ...
最关键的你的upbuffer多少。
你FreeRTOS时,调用这个的任务,任务栈多少,FreeRTOS下占用的时任务栈
 楼主| 发表于 2026-9-20 13:58:01 | 显示全部楼层
对于rtt-nano,我的那个线程栈是4096字节;对于freeRTOS,那个任务栈,也就是main任务栈是128字节;upbuffer空间是2048字节
#ifndef BUFFER_SIZE_UP
#define BUFFER_SIZE_UP (2048)// Size of the buffer for terminal output of target, up to host (Default: 1k)
//  #define BUFFER_SIZE_UP                            (1024)  // Size of the buffer for terminal output of target, up to host (Default: 1k)
#endif
#ifndef BUFFER_SIZE_DOWN
#define BUFFER_SIZE_DOWN        \
    (64)// Size of the buffer for terminal input to target from host (Usually keyboard input) (Default: 16)
#endif
#endif
#ifndef SEGGER_RTT_MODE_DEFAULT
// #define SEGGER_RTT_MODE_DEFAULT SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL // Mode for pre-initialized terminal channel (buffer 0)
// #define SEGGER_RTT_MODE_DEFAULT SEGGER_RTT_MODE_NO_BLOCK_SKIP // Mode for pre-initialized terminal channel (buffer 0)
#define SEGGER_RTT_MODE_DEFAULT SEGGER_RTT_MODE_NO_BLOCK_TRIM// Mode for pre-initialized terminal channel (buffer 0)
#endif
 楼主| 发表于 2026-9-20 17:00:13 | 显示全部楼层
然后目前为止,修改了QoS,无效:
修改了AHBSCR,无效:
    uint32_t reg_val;
    reg_val = SCB->AHBSCR;
    LOG_DBG_NORECORD("AHBSCR = 0x%08x.\n", reg_val);
    reg_val &= ~SCB_AHBSCR_CTL_Msk;       // 清空AHBSCR内容
    reg_val |= 0x01 << SCB_AHBSCR_CTL_Pos;// 设置AHBSCR内容为1
    SCB->AHBSCR = reg_val;
    LOG_DBG_NORECORD("after set AHBSCR = 0x%08x.\n", SCB->AHBSCR);
这里修改ctl为1、3均无效;
更改RTT控制块地址到0x20000000、0x24000000,无效。
发表于 2026-9-21 10:14:17 | 显示全部楼层
fox0815 发表于 2026-9-20 13:58
对于rtt-nano,我的那个线程栈是4096字节;对于freeRTOS,那个任务栈,也就是main任务栈是128字节;upbuffe ...
把这个从函数里面拿出来,做成全局变量,排查局部不够问题
点评
我把tli的频率降低到15MHz或者更低,然后把rtt-viewer的swd通信频率降低到500khz,这种重复输出的频率大幅度降低,但是依然存在。  详情 回复 发表于 2026-9-21 15:02
而且我rtt-nano的输出,都是直接用的 SEGGER_RTT_Write(0, printBuf + sizeof(innerTime), printbuf_datlen - sizeof(innerTime));, 没有用vprintf或者别的什么。 但是还是会重复输出旧内容 [mw_shl_code  详情 回复 发表于 2026-9-21 14:23
 楼主| 发表于 2026-9-21 13:47:21 | 显示全部楼层
static char acBuffer[SEGGER_RTT_PRINTF_BUFFER_SIZE];
int SEGGER_RTT_vprintf(unsigned BufferIndex, const char * sFormat, va_list * pParamList) {
  char c;
  SEGGER_RTT_PRINTF_DESC BufferDesc;
  int v;
  unsigned NumDigits;
  unsigned FormatFlags;
  unsigned FieldWidth;
  BufferDesc.pBuffer        = acBuffer;
  BufferDesc.BufferSize     = SEGGER_RTT_PRINTF_BUFFER_SIZE;
  BufferDesc.Cnt            = 0u;
  BufferDesc.RTTBufferIndex = BufferIndex;
  BufferDesc.ReturnValue    = 0;
  do {
    c = *sFormat;
    sFormat++;
    if (c == 0u) {
    if (c == '%') {
      // Filter out flags
      FormatFlags = 0u;
      v = 1;
      do {
确认把这个数组从函数里拿出来了,问题依旧,seggerRTT还是会重复输出。
 楼主| 发表于 2026-9-21 14:23:37 | 显示全部楼层
没有用vprintf或者别的什么。
但是还是会重复输出旧内容
int32_t _log_print(uint8_t lvl, bool recEn, const char *format, ...) {
    // 这里添加日志记录的具体代码
    uint64_t innerTime;
    int32_t timeLen = 0, tempLen = 0;
    size_t printbuf_avalen = PRINT_BUF_SIZE, printbuf_datlen = 0;
    const char *logTypeIdf;
    bool mutexTaken = 0;
#if defined(YT_PROTOCOL)
    if (BAC.RW.LogCtrl.En == 0)
        return 0;
    if (lvl == _LOG_INF && BAC.RW.LogCtrl.InfoEn == 0)
        return 0;
    if (lvl == _LOG_DBG && BAC.RW.LogCtrl.DbgEn == 0)
        return 0;
    if (lvl == _LOG_WARN && BAC.RW.LogCtrl.WarnEn == 0)
        return 0;
    if (lvl == _LOG_ERR && BAC.RW.LogCtrl.ErrEn == 0)
        return 0;
#endif
    if (main_checkRtosReady() == 0) {// RTOS已经就绪
        int32_t err;
        rt_enter_critical();
        if (flag_mutexInit == 0) {
            rt_mutex_init(&log_mutex, name, RT_IPC_FLAG_FIFO);
            flag_mutexInit = 1;
        rt_exit_critical();
        err = rt_mutex_take(&log_mutex, rt_tick_from_millisecond(10));
        if (err != RT_EOK) {
            return -1;
        } else {
            mutexTaken = 1;
    // YT_memset(printBuf, PRINT_BUF_SIZE, 0, PRINT_BUF_SIZE);
    innerTime = bsp_syscfg_getInnerTime();
    tempLen = sizeof(innerTime);
    YT_memcpy(printBuf, PRINT_BUF_SIZE, &innerTime, tempLen);
    printbuf_datlen += tempLen;
    printbuf_avalen -= tempLen;
    // 格式化时间戳(时间戳字符串输出到timebuf)
    int8_t timezone = 8;
#ifdef YT_IS_DEV
    timezone = ADD.RW.TimeZone;
#endif
    timeLen = Yt_UserTime_cvtToStr(Yt_UserTime_cvtFromMsecs(innerTime), (uint8_t *)timeBuf, PRINT_TIME_BUF_SIZE, timezone);
    SEGGER_RTT_Write(0, timeBuf, timeLen);
    // 插入日志类型标识符
    switch (lvl) {
        case _LOG_INF:
            tempLen = snprintf(printBuf + printbuf_datlen, printbuf_avalen, "I->");// 打印日志类型标识符
        case _LOG_DBG:
            tempLen = snprintf(printBuf + printbuf_datlen, printbuf_avalen, "D->");// 打印日志类型标识符
        case _LOG_WARN:
            tempLen = snprintf(printBuf + printbuf_datlen, printbuf_avalen, "W->");// 打印日志类型标识符
        case _LOG_ERR:
            tempLen = snprintf(printBuf + printbuf_datlen, printbuf_avalen, "E->");// 打印日志类型标识符
        default:
            if (mutexTaken) {
                rt_mutex_release(&log_mutex);
            return -1;
    // 获取可变参数内容
    va_list ParaList;
    va_start(ParaList, format);
    tempLen = vsnprintf(printBuf + printbuf_datlen, printbuf_avalen, format, ParaList);
    va_end(ParaList);
    if (recEn && BAC.RW.SyslogCtrl.SaveEn == 1) {
#else
    if (recEn) {
#endif
        bsp_flhoc_SyslogWrite((uint8_t *)printBuf, printbuf_datlen);
    // while (SEGGER_RTT_GetBytesInBuffer(0) != 0) {// 等待RTT缓冲区为空
    //     __NOP();
    if (mutexTaken) {
    return 0;
 楼主| 发表于 2026-9-21 15:02:10 | 显示全部楼层
发表于 2026-9-22 09:57:27 | 显示全部楼层
fox0815 发表于 2026-9-21 15:02
我把tli的频率降低到15MHz或者更低,然后把rtt-viewer的swd通信频率降低到500khz,这种重复输出的频率大 ...
最后一个地方试试
求助: GD32H757ZMT6 仅因 Flash/Load image 布局变化,程序运行稳定性就出现明显差异。
https://forum.anfulai.cn/forum.p ... 1926&fromuid=58
点评
好嘞,没问题,谢谢大佬!  详情 回复 发表于 2026-9-22 13:19
 楼主| 发表于 2026-9-22 13:19:20 | 显示全部楼层
eric2013 发表于 2026-9-22 09:57
最后一个地方试试
求助: GD32H757ZMT6 仅因 Flash/Load image 布局变化,程序运行稳定性就出现明显差 ...
好嘞,没问题,谢谢大佬!
GMT+8, 2026-11-22 12:47 , Processed in 0.264460 second(s), 25 queries .
