查看: 595|回复: 3
[其它] Cheap_Flash_FS(High_level_verson-check_disk_fail_HOTPLUG)--Embedded FAT16/32 file system source code for free download
发表于 2026-6-8 09:13:06 | 显示全部楼层 |阅读模式
This code is compatible with FAT16/FAT32 totally 2 formats,compatible with long file name.
compatible with chinese long file name(compatible with GB2312/UNICODE codepage(which can be disable,save the ROM space)).
compatible with subdirectory,in support of file read,write,delete,create ect.. and other related functions.
finally,the code is totally write by the C code,can port to other platforms to achieve the file system module.
this code is released free code, user can free test,research,apply.also allowed used on commercial applications.
if you want to contact with the author,please follow the way below.
e-mail:292942278@qq.com or tony_yang123@sina.com.cn
this version if the driver return FAIL,all fs_api will return disk_fail
this version's function as all same with previous version,except add disk fail function.
full support disk HOTPLUG.
cheap_flash_fs_check_disk_fail_HOTPLUG.rar (2.2 MB, 下载次数: 2)
 楼主| 发表于 2026-6-8 09:13:15 | 显示全部楼层
 楼主| 发表于 2026-6-8 15:54:32 | 显示全部楼层
this is the HOTPLUG unicode version coming.
please use these newest 2 attached source code
code is modified, solve the hole of ALLocate_Number_cluster add check fill_fat_table() status.
cheap_flash_fs_check_disk_fail_HOTPLUG.rar (2.24 MB, 下载次数: 2)
cheap_flash_fs_unicode_version_check_disk_fail_HOTPLUG.rar (2.72 MB, 下载次数: 3)
发表于 2026-6-10 10:13:34 | 显示全部楼层
谢谢楼主分享。
GMT+8, 2026-10-24 17:54 , Processed in 0.245220 second(s), 28 queries .
