查看: 778|回复: 0
[客户分享] S32K14X的选项字节MDK配置向导一键配置
发表于 2026-6-3 10:39:11 | 显示全部楼层 |阅读模式
S32K14x的选项字节也是在内部Flash的,地址从0x400开始,16个字节
xxx.S启动文件设置
; *  @file:    startup_S32K144.s
; *  @purpose: CMSIS Cortex-M4 Core Device Startup File
; *            S32K144
; *  @version: 2.0
; *  @date:    2017-1-10
; *  @build:   b170107
; * Copyright (c) 1997 - 2016 , Freescale Semiconductor, Inc.
; * Copyright 2016-2017 NXP
; * All rights reserved.
; * THIS SOFTWARE IS PROVIDED BY NXP "AS IS" AND ANY EXPRESSED OR
; * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
; * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
; * IN NO EVENT SHALL NXP OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
; * INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
; * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
; * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
; * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
; * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
; * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
; * THE POSSIBILITY OF SUCH DAMAGE.
; *------- <<< Use Configuration Wizard in Context Menu >>> ------------------
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
                IMPORT  |Image$$ARM_LIB_STACK$$ZI$$Limit|
__Vectors       DCD     |Image$$ARM_LIB_STACK$$ZI$$Limit| ; Top of Stack
                DCD     Reset_Handler  ; Reset Handler
                DCD     NMI_Handler                         ;NMI Handler
                DCD     HardFault_Handler                   ;Hard Fault Handler
                DCD     MemManage_Handler                   ;MPU Fault Handler
                DCD     BusFault_Handler                    ;Bus Fault Handler
                DCD     UsageFault_Handler                  ;Usage Fault Handler
                DCD     0                                   ;Reserved
                DCD     0                                   ;Reserved
                DCD     0                                   ;Reserved
                DCD     0                                   ;Reserved
                DCD     SVC_Handler                         ;SVCall Handler
                DCD     DebugMon_Handler                    ;Debug Monitor Handler
                DCD     0                                   ;Reserved
                DCD     PendSV_Handler                      ;PendSV Handler
                DCD     SysTick_Handler                     ;SysTick Handler
                ;External Interrupts
                DCD     DMA0_IRQHandler                     ;DMA channel 0 transfer complete
                DCD     DMA1_IRQHandler                     ;DMA channel 1 transfer complete
                DCD     DMA2_IRQHandler                     ;DMA channel 2 transfer complete
                DCD     DMA3_IRQHandler                     ;DMA channel 3 transfer complete
                DCD     DMA4_IRQHandler                     ;DMA channel 4 transfer complete
                DCD     DMA5_IRQHandler                     ;DMA channel 5 transfer complete
                DCD     DMA6_IRQHandler                     ;DMA channel 6 transfer complete
                DCD     DMA7_IRQHandler                     ;DMA channel 7 transfer complete
                DCD     DMA8_IRQHandler                     ;DMA channel 8 transfer complete
                DCD     DMA9_IRQHandler                     ;DMA channel 9 transfer complete
                DCD     DMA10_IRQHandler                    ;DMA channel 10 transfer complete
                DCD     DMA11_IRQHandler                    ;DMA channel 11 transfer complete
                DCD     DMA12_IRQHandler                    ;DMA channel 12 transfer complete
                DCD     DMA13_IRQHandler                    ;DMA channel 13 transfer complete
                DCD     DMA14_IRQHandler                    ;DMA channel 14 transfer complete
                DCD     DMA15_IRQHandler                    ;DMA channel 15 transfer complete
                DCD     DMA_Error_IRQHandler                ;DMA error interrupt channels 0-15
                DCD     MCM_IRQHandler                      ;FPU sources
                DCD     FTFC_IRQHandler                     ;FTFC Command complete
                DCD     Read_Collision_IRQHandler           ;FTFC Read collision
                DCD     LVD_LVW_IRQHandler                  ;PMC Low voltage detect interrupt
                DCD     FTFC_Fault_IRQHandler               ;FTFC Double bit fault detect
                DCD     WDOG_EWM_IRQHandler                 ;Single interrupt vector for WDOG and EWM
                DCD     RCM_IRQHandler                      ;RCM Asynchronous Interrupt
                DCD     LPI2C0_Master_IRQHandler            ;LPI2C0 Master Interrupt
                DCD     LPI2C0_Slave_IRQHandler             ;LPI2C0 Slave Interrupt
                DCD     LPSPI0_IRQHandler                   ;LPSPI0 Interrupt
                DCD     LPSPI1_IRQHandler                   ;LPSPI1 Interrupt
                DCD     LPSPI2_IRQHandler                   ;LPSPI2 Interrupt
                DCD     Reserved45_IRQHandler               ;Reserved Interrupt 45
                DCD     Reserved46_IRQHandler               ;Reserved Interrupt 46
                DCD     LPUART0_RxTx_IRQHandler             ;LPUART0 Transmit / Receive Interrupt
                DCD     Reserved48_IRQHandler               ;Reserved Interrupt 48
                DCD     LPUART1_RxTx_IRQHandler             ;LPUART1 Transmit / Receive  Interrupt
                DCD     Reserved50_IRQHandler               ;Reserved Interrupt 50
                DCD     LPUART2_RxTx_IRQHandler             ;LPUART2 Transmit / Receive  Interrupt
                DCD     Reserved52_IRQHandler               ;Reserved Interrupt 52
                DCD     Reserved53_IRQHandler               ;Reserved Interrupt 53
                DCD     Reserved54_IRQHandler               ;Reserved Interrupt 54
                DCD     ADC0_IRQHandler                     ;ADC0 interrupt request.
                DCD     ADC1_IRQHandler                     ;ADC1 interrupt request.
                DCD     CMP0_IRQHandler                     ;CMP0 interrupt request
                DCD     Reserved58_IRQHandler               ;Reserved Interrupt 58
                DCD     Reserved59_IRQHandler               ;Reserved Interrupt 59
                DCD     ERM_single_fault_IRQHandler         ;ERM single bit error correction
                DCD     ERM_double_fault_IRQHandler         ;ERM double bit error non-correctable
                DCD     RTC_IRQHandler                      ;RTC alarm interrupt
                DCD     RTC_Seconds_IRQHandler              ;RTC seconds interrupt
                DCD     LPIT0_Ch0_IRQHandler                ;LPIT0 channel 0 overflow interrupt
                DCD     LPIT0_Ch1_IRQHandler                ;LPIT0 channel 1 overflow interrupt
                DCD     LPIT0_Ch2_IRQHandler                ;LPIT0 channel 2 overflow interrupt
                DCD     LPIT0_Ch3_IRQHandler                ;LPIT0 channel 3 overflow interrupt
                DCD     PDB0_IRQHandler                     ;PDB0 interrupt
                DCD     Reserved69_IRQHandler               ;Reserved Interrupt 69
                DCD     Reserved70_IRQHandler               ;Reserved Interrupt 70
                DCD     Reserved71_IRQHandler               ;Reserved Interrupt 71
                DCD     Reserved72_IRQHandler               ;Reserved Interrupt 72
                DCD     SCG_IRQHandler                      ;SCG bus interrupt request
                DCD     LPTMR0_IRQHandler                   ;LPTIMER interrupt request
                DCD     PORTA_IRQHandler                    ;Port A pin detect interrupt
                DCD     PORTB_IRQHandler                    ;Port B pin detect interrupt
                DCD     PORTC_IRQHandler                    ;Port C pin detect interrupt
                DCD     PORTD_IRQHandler                    ;Port D pin detect interrupt
                DCD     PORTE_IRQHandler                    ;Port E pin detect interrupt
                DCD     SWI_IRQHandler                      ;Software interrupt
                DCD     Reserved81_IRQHandler               ;Reserved Interrupt 81
                DCD     Reserved82_IRQHandler               ;Reserved Interrupt 82
                DCD     Reserved83_IRQHandler               ;Reserved Interrupt 83
                DCD     PDB1_IRQHandler                     ;PDB1 interrupt
                DCD     FLEXIO_IRQHandler                   ;FlexIO Interrupt
                DCD     Reserved86_IRQHandler               ;Reserved Interrupt 86
                DCD     Reserved87_IRQHandler               ;Reserved Interrupt 87
                DCD     Reserved88_IRQHandler               ;Reserved Interrupt 88
                DCD     Reserved89_IRQHandler               ;Reserved Interrupt 89
                DCD     Reserved90_IRQHandler               ;Reserved Interrupt 90
                DCD     Reserved91_IRQHandler               ;Reserved Interrupt 91
                DCD     Reserved92_IRQHandler               ;Reserved Interrupt 92
                DCD     Reserved93_IRQHandler               ;Reserved Interrupt 93
                DCD     CAN0_ORed_IRQHandler                ;CAN0 OR'ed [Bus Off OR Transmit Warning OR Receive Warning]
                DCD     CAN0_Error_IRQHandler               ;CAN0 Interrupt indicating that errors were detected on the CAN bus
                DCD     CAN0_Wake_Up_IRQHandler             ;CAN0 Interrupt asserted when Pretended Networking operation is enabled, and a valid message matches the selected filter criteria during Low Power mode
                DCD     CAN0_ORed_0_15_MB_IRQHandler        ;CAN0 OR'ed Message buffer (0-15)
                DCD     CAN0_ORed_16_31_MB_IRQHandler       ;CAN0 OR'ed Message buffer (16-31)
                DCD     Reserved99_IRQHandler               ;Reserved Interrupt 99
                DCD     Reserved100_IRQHandler              ;Reserved Interrupt 100
                DCD     CAN1_ORed_IRQHandler                ;CAN1 OR'ed [Bus Off OR Transmit Warning OR Receive Warning]
                DCD     CAN1_Error_IRQHandler               ;CAN1 Interrupt indicating that errors were detected on the CAN bus
                DCD     Reserved103_IRQHandler              ;Reserved Interrupt 103
                DCD     CAN1_ORed_0_15_MB_IRQHandler        ;CAN1 OR'ed Interrupt for Message buffer (0-15)
                DCD     Reserved105_IRQHandler              ;Reserved Interrupt 105
                DCD     Reserved106_IRQHandler              ;Reserved Interrupt 106
                DCD     Reserved107_IRQHandler              ;Reserved Interrupt 107
                DCD     CAN2_ORed_IRQHandler                ;CAN2 OR'ed [Bus Off OR Transmit Warning OR Receive Warning]
                DCD     CAN2_Error_IRQHandler               ;CAN2 Interrupt indicating that errors were detected on the CAN bus
                DCD     Reserved110_IRQHandler              ;Reserved Interrupt 110
                DCD     CAN2_ORed_0_15_MB_IRQHandler        ;CAN2 OR'ed Message buffer (0-15)
                DCD     Reserved112_IRQHandler              ;Reserved Interrupt 112
                DCD     Reserved113_IRQHandler              ;Reserved Interrupt 113
                DCD     Reserved114_IRQHandler              ;Reserved Interrupt 114
                DCD     FTM0_Ch0_Ch1_IRQHandler             ;FTM0 Channel 0 and 1 interrupt
                DCD     FTM0_Ch2_Ch3_IRQHandler             ;FTM0 Channel 2 and 3 interrupt
                DCD     FTM0_Ch4_Ch5_IRQHandler             ;FTM0 Channel 4 and 5 interrupt
                DCD     FTM0_Ch6_Ch7_IRQHandler             ;FTM0 Channel 6 and 7 interrupt
                DCD     FTM0_Fault_IRQHandler               ;FTM0 Fault interrupt
                DCD     FTM0_Ovf_Reload_IRQHandler          ;FTM0 Counter overflow and Reload interrupt
                DCD     FTM1_Ch0_Ch1_IRQHandler             ;FTM1 Channel 0 and 1 interrupt
                DCD     FTM1_Ch2_Ch3_IRQHandler             ;FTM1 Channel 2 and 3 interrupt
                DCD     FTM1_Ch4_Ch5_IRQHandler             ;FTM1 Channel 4 and 5 interrupt
                DCD     FTM1_Ch6_Ch7_IRQHandler             ;FTM1 Channel 6 and 7 interrupt
                DCD     FTM1_Fault_IRQHandler               ;FTM1 Fault interrupt
                DCD     FTM1_Ovf_Reload_IRQHandler          ;FTM1 Counter overflow and Reload interrupt
                DCD     FTM2_Ch0_Ch1_IRQHandler             ;FTM2 Channel 0 and 1 interrupt
                DCD     FTM2_Ch2_Ch3_IRQHandler             ;FTM2 Channel 2 and 3 interrupt
                DCD     FTM2_Ch4_Ch5_IRQHandler             ;FTM2 Channel 4 and 5 interrupt
                DCD     FTM2_Ch6_Ch7_IRQHandler             ;FTM2 Channel 6 and 7 interrupt
                DCD     FTM2_Fault_IRQHandler               ;FTM2 Fault interrupt
                DCD     FTM2_Ovf_Reload_IRQHandler          ;FTM2 Counter overflow and Reload interrupt
                DCD     FTM3_Ch0_Ch1_IRQHandler             ;FTM3 Channel 0 and 1 interrupt
                DCD     FTM3_Ch2_Ch3_IRQHandler             ;FTM3 Channel 2 and 3 interrupt
                DCD     FTM3_Ch4_Ch5_IRQHandler             ;FTM3 Channel 4 and 5 interrupt
                DCD     FTM3_Ch6_Ch7_IRQHandler             ;FTM3 Channel 6 and 7 interrupt
                DCD     FTM3_Fault_IRQHandler               ;FTM3 Fault interrupt
                DCD     FTM3_Ovf_Reload_IRQHandler          ;FTM3 Counter overflow and Reload interrupt
                DCD     DefaultISR                          ;139
                DCD     DefaultISR                          ;140
                DCD     DefaultISR                          ;141
                DCD     DefaultISR                          ;142
                DCD     DefaultISR                          ;143
                DCD     DefaultISR                          ;144
                DCD     DefaultISR                          ;145
                DCD     DefaultISR                          ;146
                DCD     DefaultISR                          ;147
                DCD     DefaultISR                          ;148
                DCD     DefaultISR                          ;149
                DCD     DefaultISR                          ;150
                DCD     DefaultISR                          ;151
                DCD     DefaultISR                          ;152
                DCD     DefaultISR                          ;153
                DCD     DefaultISR                          ;154
                DCD     DefaultISR                          ;155
                DCD     DefaultISR                          ;156
                DCD     DefaultISR                          ;157
                DCD     DefaultISR                          ;158
                DCD     DefaultISR                          ;159
                DCD     DefaultISR                          ;160
                DCD     DefaultISR                          ;161
                DCD     DefaultISR                          ;162
                DCD     DefaultISR                          ;163
                DCD     DefaultISR                          ;164
                DCD     DefaultISR                          ;165
                DCD     DefaultISR                          ;166
                DCD     DefaultISR                          ;167
                DCD     DefaultISR                          ;168
                DCD     DefaultISR                          ;169
                DCD     DefaultISR                          ;170
                DCD     DefaultISR                          ;171
                DCD     DefaultISR                          ;172
                DCD     DefaultISR                          ;173
                DCD     DefaultISR                          ;174
                DCD     DefaultISR                          ;175
                DCD     DefaultISR                          ;176
                DCD     DefaultISR                          ;177
                DCD     DefaultISR                          ;178
                DCD     DefaultISR                          ;179
                DCD     DefaultISR                          ;180
                DCD     DefaultISR                          ;181
                DCD     DefaultISR                          ;182
                DCD     DefaultISR                          ;183
                DCD     DefaultISR                          ;184
                DCD     DefaultISR                          ;185
                DCD     DefaultISR                          ;186
                DCD     DefaultISR                          ;187
                DCD     DefaultISR                          ;188
                DCD     DefaultISR                          ;189
                DCD     DefaultISR                          ;190
                DCD     DefaultISR                          ;191
                DCD     DefaultISR                          ;192
                DCD     DefaultISR                          ;193
                DCD     DefaultISR                          ;194
                DCD     DefaultISR                          ;195
                DCD     DefaultISR                          ;196
                DCD     DefaultISR                          ;197
                DCD     DefaultISR                          ;198
                DCD     DefaultISR                          ;199
                DCD     DefaultISR                          ;200
                DCD     DefaultISR                          ;201
                DCD     DefaultISR                          ;202
                DCD     DefaultISR                          ;203
                DCD     DefaultISR                          ;204
                DCD     DefaultISR                          ;205
                DCD     DefaultISR                          ;206
                DCD     DefaultISR                          ;207
                DCD     DefaultISR                          ;208
                DCD     DefaultISR                          ;209
                DCD     DefaultISR                          ;210
                DCD     DefaultISR                          ;211
                DCD     DefaultISR                          ;212
                DCD     DefaultISR                          ;213
                DCD     DefaultISR                          ;214
                DCD     DefaultISR                          ;215
                DCD     DefaultISR                          ;216
                DCD     DefaultISR                          ;217
                DCD     DefaultISR                          ;218
                DCD     DefaultISR                          ;219
                DCD     DefaultISR                          ;220
                DCD     DefaultISR                          ;221
                DCD     DefaultISR                          ;222
                DCD     DefaultISR                          ;223
                DCD     DefaultISR                          ;224
                DCD     DefaultISR                          ;225
                DCD     DefaultISR                          ;226
                DCD     DefaultISR                          ;227
                DCD     DefaultISR                          ;228
                DCD     DefaultISR                          ;229
                DCD     DefaultISR                          ;230
                DCD     DefaultISR                          ;231
                DCD     DefaultISR                          ;232
                DCD     DefaultISR                          ;233
                DCD     DefaultISR                          ;234
                DCD     DefaultISR                          ;235
                DCD     DefaultISR                          ;236
                DCD     DefaultISR                          ;237
                DCD     DefaultISR                          ;238
                DCD     DefaultISR                          ;239
                DCD     DefaultISR                          ;240
                DCD     DefaultISR                          ;241
                DCD     DefaultISR                          ;242
                DCD     DefaultISR                          ;243
                DCD     DefaultISR                          ;244
                DCD     DefaultISR                          ;245
                DCD     DefaultISR                          ;246
                DCD     DefaultISR                          ;247
                DCD     DefaultISR                          ;248
                DCD     DefaultISR                          ;249
                DCD     DefaultISR                          ;250
                DCD     DefaultISR                          ;251
                DCD     DefaultISR                          ;252
                DCD     DefaultISR                          ;253
                DCD     DefaultISR                          ;254
                DCD     0xFFFFFFFF                          ;Reserved for user TRIM value
__Vectors_End
__Vectors_Size 	EQU     __Vectors_End - __Vectors
; <h> Flash Configuration
;   <i> 16-byte flash configuration field that stores default protection settings (loaded on reset)
;   <i> and security information that allows the MCU to restrict access to the FTFL module.
;   <h> Backdoor Comparison Key
;     <o0>  Backdoor Comparison Key 0.  <0x0-0xFF:2>
;     <o1>  Backdoor Comparison Key 1.  <0x0-0xFF:2>
;     <o2>  Backdoor Comparison Key 2.  <0x0-0xFF:2>
;     <o3>  Backdoor Comparison Key 3.  <0x0-0xFF:2>
;     <o4>  Backdoor Comparison Key 4.  <0x0-0xFF:2>
;     <o5>  Backdoor Comparison Key 5.  <0x0-0xFF:2>
;     <o6>  Backdoor Comparison Key 6.  <0x0-0xFF:2>
;     <o7>  Backdoor Comparison Key 7.  <0x0-0xFF:2>
BackDoorK0      EQU     0xFF
BackDoorK1      EQU     0xFF
BackDoorK2      EQU     0xFF
BackDoorK3      EQU     0xFF
BackDoorK4      EQU     0xFF
BackDoorK5      EQU     0xFF
BackDoorK6      EQU     0xFF
BackDoorK7      EQU     0xFF
;   </h>
;   <h> Program flash protection bytes (FPROT)
;     <i> Each program flash region can be protected from program and erase operation by setting the associated PROT bit.
;     <i> Each bit protects a 1/32 region of the program flash memory.
;     <h> FPROT0
;       <i> Program Flash Region Protect Register 0
;       <i> 1/32 - 8/32 region
;       <o.0>   FPROT0.0
;       <o.1>   FPROT0.1
;       <o.2>   FPROT0.2
;       <o.3>   FPROT0.3
;       <o.4>   FPROT0.4
;       <o.5>   FPROT0.5
;       <o.6>   FPROT0.6
;       <o.7>   FPROT0.7
nFPROT0         EQU     0x00
FPROT0          EQU     nFPROT0:EOR:0xFF
;     </h>
;     <h> FPROT1
;       <i> Program Flash Region Protect Register 1
;       <i> 9/32 - 16/32 region
;       <o.0>   FPROT1.0
;       <o.1>   FPROT1.1
;       <o.2>   FPROT1.2
;       <o.3>   FPROT1.3
;       <o.4>   FPROT1.4
;       <o.5>   FPROT1.5
;       <o.6>   FPROT1.6
;       <o.7>   FPROT1.7
nFPROT1         EQU     0x00
FPROT1          EQU     nFPROT1:EOR:0xFF
;     </h>
;     <h> FPROT2
;       <i> Program Flash Region Protect Register 2
;       <i> 17/32 - 24/32 region
;       <o.0>   FPROT2.0
;       <o.1>   FPROT2.1
;       <o.2>   FPROT2.2
;       <o.3>   FPROT2.3
;       <o.4>   FPROT2.4
;       <o.5>   FPROT2.5
;       <o.6>   FPROT2.6
;       <o.7>   FPROT2.7
nFPROT2         EQU     0x00
FPROT2          EQU     nFPROT2:EOR:0xFF
;     </h>
;     <h> FPROT3
;       <i> Program Flash Region Protect Register 3
;       <i> 25/32 - 32/32 region
;       <o.0>   FPROT3.0
;       <o.1>   FPROT3.1
;       <o.2>   FPROT3.2
;       <o.3>   FPROT3.3
;       <o.4>   FPROT3.4
;       <o.5>   FPROT3.5
;       <o.6>   FPROT3.6
;       <o.7>   FPROT3.7
nFPROT3         EQU     0x00
FPROT3          EQU     nFPROT3:EOR:0xFF
;     </h>
;   </h>
;   <h> Data flash protection byte (FDPROT)
;     <i> Each bit protects a 1/8 region of the data flash memory.
;     <i> (Program flash only devices: Reserved)
;       <o.0>   FDPROT.0
;       <o.1>   FDPROT.1
;       <o.2>   FDPROT.2
;       <o.3>   FDPROT.3
;       <o.4>   FDPROT.4
;       <o.5>   FDPROT.5
;       <o.6>   FDPROT.6
;       <o.7>   FDPROT.7
nFDPROT         EQU     0x00
FDPROT          EQU     nFDPROT:EOR:0xFF
;   </h>
;   <h> EEPROM protection byte (FEPROT)
;     <i> FlexNVM devices: Each bit protects a 1/8 region of the EEPROM.
;       <o.0>   FEPROT.0
;       <o.1>   FEPROT.1
;       <o.2>   FEPROT.2
;       <o.3>   FEPROT.3
;       <o.4>   FEPROT.4
;       <o.5>   FEPROT.5
;       <o.6>   FEPROT.6
;       <o.7>   FEPROT.7
nFEPROT         EQU     0x00
FEPROT          EQU     nFEPROT:EOR:0xFF
;   </h>
;   <h> Flash nonvolatile option byte (FOPT)
;     <i> Allows the user to customize the operation of the MCU at boot time.
;     <o.0> LPBOOT
;       <0=> Core and system clock divider (OUTDIV1) is 0x1 (divide by 2).
;       <1=> Core and system clock divider (OUTDIV1) is 0x0 (divide by 1).
;     <o.2> NMI_DIS
;       <0=> NMI interrupts are always blocked
;       <1=> NMI_b pin/interrupts reset default to enabled
;     <o.3> RESET_PIN_CFG
;       <0=> RESET pin is disabled following a POR and cannot be enabled as reset function
;       <1=> RESET_b pin is dedicated
FOPT          EQU     0x7F
;   </h>
;   <h> Flash security byte (FSEC)
;     <i> WARNING: If SEC field is configured as "MCU security status is secure" and MEEN field is configured as "Mass erase is disabled",
;     <i> MCU's security status cannot be set back to unsecure state since Mass erase via the debugger is blocked !!!
;     <o.0..1> SEC
;       <2=> MCU security status is unsecure
;       <3=> MCU security status is secure
;         <i> Flash Security
;     <o.2..3> FSLACC
;       <2=> Freescale factory access denied
;       <3=> Freescale factory access granted
;         <i> Freescale Failure Analysis Access Code
;     <o.4..5> MEEN
;       <2=> Mass erase is disabled
;       <3=> Mass erase is enabled
;     <o.6..7> KEYEN
;       <2=> Backdoor key access enabled
;       <3=> Backdoor key access disabled
;         <i> Backdoor Key Security Enable
FSEC          EQU     0xFE
;   </h>
; </h>
                IF      :LNOT::DEF:RAM_TARGET
                AREA    FlashConfig, DATA, READONLY
__FlashConfig
                DCB     BackDoorK0, BackDoorK1, BackDoorK2, BackDoorK3
                DCB     BackDoorK4, BackDoorK5, BackDoorK6, BackDoorK7
                DCB     FPROT0    , FPROT1    , FPROT2    , FPROT3
                DCB     FSEC      , FOPT      , FEPROT    , FDPROT
                ENDIF
                AREA    |.text|, CODE, READONLY
; Reset Handler
Reset_Handler   PROC
                EXPORT  Reset_Handler             [WEAK]
                IMPORT  SystemInit
                IMPORT  init_data_bss
                IMPORT  __main
                LDR R0, =FlashConfig    ; dummy read, workaround for flashConfig
                ENDIF
                CPSID   I               ; Mask interrupts
                LDR     R0, =SystemInit
                BLX     R0
                LDR     R0, =init_data_bss
                BLX     R0
                CPSIE   i               ; Unmask interrupts
                LDR     R0, =__main
                BX      R0
                ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler\
                PROC
                EXPORT  NMI_Handler         [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler         [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler         [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler         [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler\
                PROC
                EXPORT  SVC_Handler         [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler         [WEAK]
                B       .
                ENDP
PendSV_Handler\
                PROC
                EXPORT  PendSV_Handler         [WEAK]
                B       .
                ENDP
SysTick_Handler\
                PROC
                EXPORT  SysTick_Handler         [WEAK]
                B       .
                ENDP
Default_Handler\
                PROC
                EXPORT  DMA0_IRQHandler                     [WEAK]
                EXPORT  DMA1_IRQHandler                     [WEAK]
                EXPORT  DMA2_IRQHandler                     [WEAK]
                EXPORT  DMA3_IRQHandler                     [WEAK]
                EXPORT  DMA4_IRQHandler                     [WEAK]
                EXPORT  DMA5_IRQHandler                     [WEAK]
                EXPORT  DMA6_IRQHandler                     [WEAK]
                EXPORT  DMA7_IRQHandler                     [WEAK]
                EXPORT  DMA8_IRQHandler                     [WEAK]
                EXPORT  DMA9_IRQHandler                     [WEAK]
                EXPORT  DMA10_IRQHandler                    [WEAK]
                EXPORT  DMA11_IRQHandler                    [WEAK]
                EXPORT  DMA12_IRQHandler                    [WEAK]
                EXPORT  DMA13_IRQHandler                    [WEAK]
                EXPORT  DMA14_IRQHandler                    [WEAK]
                EXPORT  DMA15_IRQHandler                    [WEAK]
                EXPORT  DMA_Error_IRQHandler                [WEAK]
                EXPORT  MCM_IRQHandler                      [WEAK]
                EXPORT  FTFC_IRQHandler                     [WEAK]
                EXPORT  Read_Collision_IRQHandler           [WEAK]
                EXPORT  LVD_LVW_IRQHandler                  [WEAK]
                EXPORT  FTFC_Fault_IRQHandler               [WEAK]
                EXPORT  WDOG_EWM_IRQHandler                 [WEAK]
                EXPORT  RCM_IRQHandler                      [WEAK]
                EXPORT  LPI2C0_Master_IRQHandler            [WEAK]
                EXPORT  LPI2C0_Slave_IRQHandler             [WEAK]
                EXPORT  LPSPI0_IRQHandler                   [WEAK]
                EXPORT  LPSPI1_IRQHandler                   [WEAK]
                EXPORT  LPSPI2_IRQHandler                   [WEAK]
                EXPORT  Reserved45_IRQHandler               [WEAK]
                EXPORT  Reserved46_IRQHandler               [WEAK]
                EXPORT  LPUART0_RxTx_IRQHandler             [WEAK]
                EXPORT  Reserved48_IRQHandler               [WEAK]
                EXPORT  LPUART1_RxTx_IRQHandler             [WEAK]
                EXPORT  Reserved50_IRQHandler               [WEAK]
                EXPORT  LPUART2_RxTx_IRQHandler             [WEAK]
                EXPORT  Reserved52_IRQHandler               [WEAK]
                EXPORT  Reserved53_IRQHandler               [WEAK]
                EXPORT  Reserved54_IRQHandler               [WEAK]
                EXPORT  ADC0_IRQHandler                     [WEAK]
                EXPORT  ADC1_IRQHandler                     [WEAK]
                EXPORT  CMP0_IRQHandler                     [WEAK]
                EXPORT  Reserved58_IRQHandler               [WEAK]
                EXPORT  Reserved59_IRQHandler               [WEAK]
                EXPORT  ERM_single_fault_IRQHandler         [WEAK]
                EXPORT  ERM_double_fault_IRQHandler         [WEAK]
                EXPORT  RTC_IRQHandler                      [WEAK]
                EXPORT  RTC_Seconds_IRQHandler              [WEAK]
                EXPORT  LPIT0_Ch0_IRQHandler                [WEAK]
                EXPORT  LPIT0_Ch1_IRQHandler                [WEAK]
                EXPORT  LPIT0_Ch2_IRQHandler                [WEAK]
                EXPORT  LPIT0_Ch3_IRQHandler                [WEAK]
                EXPORT  PDB0_IRQHandler                     [WEAK]
                EXPORT  Reserved69_IRQHandler               [WEAK]
                EXPORT  Reserved70_IRQHandler               [WEAK]
                EXPORT  Reserved71_IRQHandler               [WEAK]
                EXPORT  Reserved72_IRQHandler               [WEAK]
                EXPORT  SCG_IRQHandler                      [WEAK]
                EXPORT  LPTMR0_IRQHandler                   [WEAK]
                EXPORT  PORTA_IRQHandler                    [WEAK]
                EXPORT  PORTB_IRQHandler                    [WEAK]
                EXPORT  PORTC_IRQHandler                    [WEAK]
                EXPORT  PORTD_IRQHandler                    [WEAK]
                EXPORT  PORTE_IRQHandler                    [WEAK]
                EXPORT  SWI_IRQHandler                      [WEAK]
                EXPORT  Reserved81_IRQHandler               [WEAK]
                EXPORT  Reserved82_IRQHandler               [WEAK]
                EXPORT  Reserved83_IRQHandler               [WEAK]
                EXPORT  PDB1_IRQHandler                     [WEAK]
                EXPORT  FLEXIO_IRQHandler                   [WEAK]
                EXPORT  Reserved86_IRQHandler               [WEAK]
                EXPORT  Reserved87_IRQHandler               [WEAK]
                EXPORT  Reserved88_IRQHandler               [WEAK]
                EXPORT  Reserved89_IRQHandler               [WEAK]
                EXPORT  Reserved90_IRQHandler               [WEAK]
                EXPORT  Reserved91_IRQHandler               [WEAK]
                EXPORT  Reserved92_IRQHandler               [WEAK]
                EXPORT  Reserved93_IRQHandler               [WEAK]
                EXPORT  CAN0_ORed_IRQHandler                [WEAK]
                EXPORT  CAN0_Error_IRQHandler               [WEAK]
                EXPORT  CAN0_Wake_Up_IRQHandler             [WEAK]
                EXPORT  CAN0_ORed_0_15_MB_IRQHandler        [WEAK]
                EXPORT  CAN0_ORed_16_31_MB_IRQHandler       [WEAK]
                EXPORT  Reserved99_IRQHandler               [WEAK]
                EXPORT  Reserved100_IRQHandler              [WEAK]
                EXPORT  CAN1_ORed_IRQHandler                [WEAK]
                EXPORT  CAN1_Error_IRQHandler               [WEAK]
                EXPORT  Reserved103_IRQHandler              [WEAK]
                EXPORT  CAN1_ORed_0_15_MB_IRQHandler        [WEAK]
                EXPORT  Reserved105_IRQHandler              [WEAK]
                EXPORT  Reserved106_IRQHandler              [WEAK]
                EXPORT  Reserved107_IRQHandler              [WEAK]
                EXPORT  CAN2_ORed_IRQHandler                [WEAK]
                EXPORT  CAN2_Error_IRQHandler               [WEAK]
                EXPORT  Reserved110_IRQHandler              [WEAK]
                EXPORT  CAN2_ORed_0_15_MB_IRQHandler        [WEAK]
                EXPORT  Reserved112_IRQHandler              [WEAK]
                EXPORT  Reserved113_IRQHandler              [WEAK]
                EXPORT  Reserved114_IRQHandler              [WEAK]
                EXPORT  FTM0_Ch0_Ch1_IRQHandler             [WEAK]
                EXPORT  FTM0_Ch2_Ch3_IRQHandler             [WEAK]
                EXPORT  FTM0_Ch4_Ch5_IRQHandler             [WEAK]
                EXPORT  FTM0_Ch6_Ch7_IRQHandler             [WEAK]
                EXPORT  FTM0_Fault_IRQHandler               [WEAK]
                EXPORT  FTM0_Ovf_Reload_IRQHandler          [WEAK]
                EXPORT  FTM1_Ch0_Ch1_IRQHandler             [WEAK]
                EXPORT  FTM1_Ch2_Ch3_IRQHandler             [WEAK]
                EXPORT  FTM1_Ch4_Ch5_IRQHandler             [WEAK]
                EXPORT  FTM1_Ch6_Ch7_IRQHandler             [WEAK]
                EXPORT  FTM1_Fault_IRQHandler               [WEAK]
                EXPORT  FTM1_Ovf_Reload_IRQHandler          [WEAK]
                EXPORT  FTM2_Ch0_Ch1_IRQHandler             [WEAK]
                EXPORT  FTM2_Ch2_Ch3_IRQHandler             [WEAK]
                EXPORT  FTM2_Ch4_Ch5_IRQHandler             [WEAK]
                EXPORT  FTM2_Ch6_Ch7_IRQHandler             [WEAK]
                EXPORT  FTM2_Fault_IRQHandler               [WEAK]
                EXPORT  FTM2_Ovf_Reload_IRQHandler          [WEAK]
                EXPORT  FTM3_Ch0_Ch1_IRQHandler             [WEAK]
                EXPORT  FTM3_Ch2_Ch3_IRQHandler             [WEAK]
                EXPORT  FTM3_Ch4_Ch5_IRQHandler             [WEAK]
                EXPORT  FTM3_Ch6_Ch7_IRQHandler             [WEAK]
                EXPORT  FTM3_Fault_IRQHandler               [WEAK]
                EXPORT  FTM3_Ovf_Reload_IRQHandler          [WEAK]
                EXPORT  DefaultISR                          [WEAK]
DMA0_IRQHandler
DMA1_IRQHandler
DMA2_IRQHandler
DMA3_IRQHandler
DMA4_IRQHandler
DMA5_IRQHandler
DMA6_IRQHandler
DMA7_IRQHandler
DMA8_IRQHandler
DMA9_IRQHandler
DMA10_IRQHandler
DMA11_IRQHandler
DMA12_IRQHandler
DMA13_IRQHandler
DMA14_IRQHandler
DMA15_IRQHandler
MCM_IRQHandler
FTFC_IRQHandler
LVD_LVW_IRQHandler
WDOG_EWM_IRQHandler
RCM_IRQHandler
LPSPI0_IRQHandler
LPSPI1_IRQHandler
LPSPI2_IRQHandler
ADC0_IRQHandler
ADC1_IRQHandler
CMP0_IRQHandler
RTC_IRQHandler
PDB0_IRQHandler
SCG_IRQHandler
LPTMR0_IRQHandler
PORTA_IRQHandler
PORTB_IRQHandler
PORTC_IRQHandler
PORTD_IRQHandler
PORTE_IRQHandler
SWI_IRQHandler
PDB1_IRQHandler
FLEXIO_IRQHandler
DefaultISR
                B      DefaultISR
                ENDP
                ALIGN
                END
分散加载设置位置:
#! armcc -E
**     Processor:           S32K144 with 64 KB SRAM
**     Compiler:            Keil ARM C/C++ Compiler
**     Abstract:
**         Linker file for the Keil ARM C/C++ Compiler
**     Copyright (c) 2015 Freescale Semiconductor, Inc.
**     All rights reserved.
**     Redistribution and use in source and binary forms, with or without modification,
**     are permitted provided that the following conditions are met:
**     o Redistributions of source code must retain the above copyright notice, this list
**       of conditions and the following disclaimer.
**     o Redistributions in binary form must reproduce the above copyright notice, this
**       list of conditions and the following disclaimer in the documentation and/or
**       other materials provided with the distribution.
**     o Neither the name of Freescale Semiconductor, Inc. nor the names of its
**       contributors may be used to endorse or promote products derived from this
**       software without specific prior written permission.
**     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
**     ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
**     WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
**     DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
**     ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
**     (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
**     LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
**     ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
**     (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
**     SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
**     http:                 [url]www.freescale.com[/url]
**     mail:                 [email]support@freescale.com[/email]
#if (defined(__ram_vector_table__))
  #define __ram_vector_table_size__    0x00000400
#else
  #define __ram_vector_table_size__    0x00000000
#endif
#define m_interrupts_start             0x00000000
#define m_interrupts_size              0x00000400
#define m_flash_config_start           0x00000400
#define m_flash_config_size            0x00000010
#define m_text_start                   0x00000410
#define m_text_size                    0x0007FBF0
#define m_interrupts_ram_start         0x1FFF8000
#define m_interrupts_ram_size          __ram_vector_table_size__
#define m_data_start                   (m_interrupts_ram_start + m_interrupts_ram_size)
#define m_data_size                    (0x00008000 - m_interrupts_ram_size)
#define m_data_2_start                 0x20000000
#define m_data_2_size                  0x00007000
/* Sizes */
#if (defined(__stack_size__))
  #define Stack_Size                   __stack_size__
#else
  #define Stack_Size                   0x1000
#endif
#if (defined(__heap_size__))
  #define Heap_Size                    __heap_size__
#else
  #define Heap_Size                    0x0400
#endif
LR_m_text m_text_start m_text_size {   ; load region size_region
  ER_m_text m_text_start m_text_size { ; load address = execution address
    * (InRoot$$Sections)
    .ANY (+RO)
  RW_m_data m_data_start m_data_size { ; RW data
    .ANY (+RW +ZI)
  RW_m_data_2 m_data_2_start m_data_2_size-Stack_Size-Heap_Size { ; RW data
    .ANY (+RW +ZI)
  ARM_LIB_HEAP ((ImageLimit(RW_m_data_2) == m_data_2_start) ? ImageLimit(RW_m_data) : +0) EMPTY Heap_Size { ; Heap region growing up
  ARM_LIB_STACK m_data_2_start+m_data_2_size EMPTY -Stack_Size { ; Stack region growing down
LR_m_interrupts m_interrupts_start m_interrupts_size {
#if (!defined(__ram_vector_table__))
  VECTOR_RAM m_interrupts_start EMPTY 0 {
#endif
  VECTOR_ROM m_interrupts_start m_interrupts_size { ; load address = execution address
    * (RESET,+FIRST)
LR_m_flash_config m_flash_config_start m_flash_config_size {
  ER_m_flash_config m_flash_config_start m_flash_config_size { ; load address = execution address
    * (FlashConfig)
LR_m_interrupts_ram m_interrupts_ram_start m_interrupts_ram_size {
  VECTOR_RAM m_interrupts_ram_start EMPTY m_interrupts_ram_size {
#endif
GMT+8, 2026-11-22 12:52 , Processed in 0.142650 second(s), 27 queries .
