查看: 849|回复: 5
[STM32H7] 分享一下 自己捣鼓的 mx35lf4ge4a spi nand flash 驱动,不对之处欢迎大神做出批示
发表于 2026-5-21 10:55:11 | 显示全部楼层 |阅读模式
主要是移植 自  st 提供的 w25n01g 驱动作为参考,其中修改了一丢丢来 适配 mx35lf4ge4a 的
目前 基本的读写 成功了
bsp_spi_mx35lf4ge4ad_st.h (24.47 KB, 下载次数: 2)
bsp_spi_mx35lf4ge4ad_st.c (67.04 KB, 下载次数: 2)
static const uint8_t hex_char[] = {"0123456789ABCDEF\0"};
#define NAND_RW_TEST_SIZE    (1024*8)
U1 RX :mx35lf-st-demo
MX35LF_NAND_TestST RW OK !
void MX35LF_NAND_TestST(void)
        mx35lf4ge4xx_status_t  status;
    uint32_t  flash_addr;
        uint32_t  rw_size;
        uint32_t  rx_full_pages;
    uint32_t  trans_len = 0;
    uint32_t  i=0, error_cnt = 0;
    uint16_t  seed = 0;
    uint16_t  col_address = 0;
        uint16_t start_block;
        uint16_t num_blocks;
        uint8_t  page;
        uint8_t   *pTxBuff = 0;
        uint8_t   *pRxBuff = 0;
        if(mx35lf_info.nand_ok != 1)  return ;
        pTxBuff = mymalloc (SDRAMEX, NAND_RW_TEST_SIZE);
        pRxBuff = mymalloc (SDRAMEX, NAND_RW_TEST_SIZE);
        for(i=0;i<NAND_RW_TEST_SIZE; i++) {
                pTxBuff = hex_char[i%16];
                pRxBuff = 0;
        start_block = 2048-2;                // 最后一个块进行读写测试
        num_blocks  = 0;
        rw_size = NAND_RW_TEST_SIZE;
    num_blocks = (rw_size / MX35LF2GE4AD_BLOCK_SIZE) +
                        (((rw_size % MX35LF2GE4AD_BLOCK_SIZE) == 0U) ? 0U : 1U);
        status = mx35lf4ge4xx_erase_blocks(&mx35lf4ge4xx_obj,  start_block,  num_blocks);                // 一个块 == 256KB 大小
        page = 0;
        status = mx35lf4ge4xx_write(&mx35lf4ge4xx_obj, start_block,  page, pTxBuff,   rw_size);
    /* calculate the number of pages to write */
    uint32_t full_pages = (rw_size / MX35LF2GE4AD_PAGE_MEM_SIZE) +
                        (((rw_size % MX35LF2GE4AD_PAGE_MEM_SIZE) == 0U) ? 0U : 1U);
        for(i=0;i<full_pages;i++) {
                status = mx35lf4ge4xx_read(&mx35lf4ge4xx_obj, start_block,  page, &pRxBuff[i*MX35LF2GE4AD_PAGE_MEM_SIZE],   MX35LF2GE4AD_PAGE_MEM_SIZE);
                page ++;
                if(pTxBuff != pRxBuff) {
                        error_cnt = 1;
                        __log("MX35LF_NAND_TestST RW ERROR ..?\r\n");
        if(!error_cnt)
                __log("MX35LF_NAND_TestST RW OK !\r\n");
        myfree (SDRAMEX, pTxBuff);
        myfree (SDRAMEX, pRxBuff);
说明:
mx35lf4ge4xx_write  这个写函数写入数据大小范围 0-(512MB-1)
mx35lf4ge4xx_read   这个读取函数一次最多只能读取 4096 byte, 超过则需要分包读取
后续看看哪位大神把他适配一下 fatfs 后发上来分享一下哈  适配 fatfs 读写建议 使用 512 大小,这样可以兼容 sd 的 fatfs 了
在 st 官方提供的 w25n01g 的块擦除函数里面有个 页地址 最后一字节是 &0xC0  ??  不知道是怎么来的,哪位大佬帮忙看看是怎么回事呀 ??
static w25n01g_status_t  w25n01g_erase_block_cmd(mx35lf4ge4xx_obj_t *pobj, uint16_t block)
  /* Check parameters */
  if ((pobj == NULL) || (block > W25N01G_NUM_OF_BLOCK))
    return W25N01G_ERROR;
  w25n01g_status_t ret =  W25N01G_OK;
  /* Page address calculation to get the block address we want to erase */
  uint16_t page_addr = block * W25N01G_NUM_PAGE_PER_BLOCK ;
  /* Initialize the erase block instructions sequence */
  uint8_t cmd[4] = {W25N01G_CMD_BLOCK_ERASE,                            // w25n01
                   W25N01G_DUMMY_BYTE,
                   (uint8_t)((page_addr & 0xFF00U) >> 8),
                   (uint8_t)(page_addr & 0xC0U)                       // 这个地方怎么会是 0xC0  ??  不应该是 0xFF 吗 ????
发表于 2026-5-21 13:02:36 | 显示全部楼层
谢谢楼主分享,这个价格多少钱一颗
 楼主| 发表于 2026-5-21 14:06:54 | 显示全部楼层
eric2013 发表于 2026-5-21 13:02
谢谢楼主分享,这个价格多少钱一颗
我咸鱼上淘了几颗, 10大洋一颗 , 还是全新没有使用过的
发表于 2026-5-21 14:58:45 | 显示全部楼层
原装的应该挺贵的吧
 楼主| 发表于 2026-5-21 16:40:37 | 显示全部楼层
eric2013 发表于 2026-5-21 14:58
原装的应该挺贵的吧
淘宝上貌似写着全新原装的 不到 20 大洋哟, 这个价格如果为真的那应该也还可以把 ?
发表于 2026-5-22 07:39:27 | 显示全部楼层
那还行。
GMT+8, 2026-10-24 11:02 , Processed in 0.532959 second(s), 27 queries .
