查看: 471|回复: 2
[emWin] 关于EDIT如何输入俄语字符
发表于 2026-5-15 16:05:17 | 显示全部楼层 |阅读模式
求助大佬,下面这是项目里设置设备名称的代码,目前只能设置ASCII里的字符,有没有办法添加俄语的一些字符呢?目前只能设置EDIT_MODE_ASCII和EDIT_MODE_HEX这两种模式
void _cbNameInput(WM_MESSAGE * pMsg)
    WM_HWIN hItem;
    LanguageUnLockInput_t sData;
    switch (pMsg->MsgId)
        case WM_PAINT:
                        GUI_RECT Rect;
                        GUI_SetColor(VIEW_TITLE_COLOR);
                        GUI_SetBkColor(VIEW_TITLE_BKCOLOR);
                        WM_GetClientRect(&Rect);
                        Rect.y1 = VIEW_TITLE_YSIZE - 1 - 1;
                        l_snprintf((char *)g_DispBuf,sizeof(g_DispBuf)," < %s",(const char *)GetLanguageString(STR_DEV_NAME));
                        GUI_DispStringInRectFill((char *)g_DispBuf,&Rect,GUI_TA_LEFT | GUI_TA_VCENTER);
                        GUI_SetColor(VIEW_TITLE_LINE_COLOR);
                        GUI_DrawHLine(VIEW_TITLE_YSIZE - 1,0,Rect.x1);
        case WM_INIT_DIALOG:
            // Initialization of 'Edit'
            WINDOW_SetBkColor(pMsg->hWin,VIEW_TITLE_BKCOLOR);
            hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
            memset(&sData,0,sizeof(sData));
            EDITBAR_SetUserData(hItem,&sData,sizeof(sData));
            EDITBAR_SetMode(hItem,EDIT_MODE_ASCII);
            EDITBAR_SetMaxLen(hItem,sizeof(g_GUIPara.DevName) - 1);
            EDITBAR_SetValueBuf(hItem,(char *)&g_GUIPara.DevName[0],sizeof(g_GUIPara.DevName) - 1);
            EDITBAR_SetFont(hItem, &GUI_DEFAULT_FONT);
            EDITBAR_SetBkColor(hItem,VIEW_TITLE_BKCOLOR);
            EDITBAR_SetColor(hItem, GUI_BLUE);
            EDITBAR_SetCursorAtChar(hItem,0);
        case WM_KEY:
            INT32U Key;
            if(((WM_KEY_INFO*)(pMsg->Data.p))->PressedCnt)
                Key = ((WM_KEY_INFO*)(pMsg->Data.p))->Key;
                if(KEY_LOK == Key)
                        char Buf[sizeof(g_GUIPara.DevName)];
                    EDITBAR_GetValueBuf(hItem,(char *)&Buf[0],sizeof(Buf) - 1);
                    Buf[sizeof(Buf) - 1] = '\0';
                                        SetDeviceName(Buf);
                    g_CurPageId = g_PrePageId;
                    TurnToFocus();
                else if(KEY_CH == Key)
                    TurnToFocus();
        default:  WM_DefaultProc(pMsg); break;
发表于 2026-5-16 12:58:10 | 显示全部楼层
使用EDIT的字符串显示模式。
 楼主| 发表于 2026-5-16 13:46:01 | 显示全部楼层
eric2013 发表于 2026-5-16 12:58
使用EDIT的字符串显示模式。
大佬,能不能详细指点一下,谢谢
GMT+8, 2026-7-11 01:15 , Processed in 0.615275 second(s), 25 queries .
