查看: 789|回复: 1
[其它] Cheap_Flash_FS(High_level_verson-Unicode_version)--Embedded FAT16/32 file system source code for free download
发表于 2026-2-5 09:11:35 | 显示全部楼层 |阅读模式
This code is compatible with FAT16/FAT32 totally 2 formats,compatible with long file name.
compatible with chinese long file name(compatible with GB2312/UNICODE codepage(which can be disable,save the ROM space)).
compatible with subdirectory,in support of file read,write,delete,create ect.. and other related functions.
finally,the code is totally write by the C code,can port to other platforms to achieve the file system module.
the file name support unicode, global operation,necessary version
this code is released free code, user can free test,research,apply.also allowed used on commercial applications.
if you want to contact with the author,please follow the way below.
e-mail:292942278@qq.com or tony_yang123@sina.com.cn
cheap_flash_fs.rar (2.17 MB, 下载次数: 1)
cheap_flash_fs_unicode_version.rar (2.69 MB, 下载次数: 1)
发表于 2026-2-5 09:26:01 | 显示全部楼层
谢谢分享。
GMT+8, 2026-10-24 17:53 , Processed in 0.124179 second(s), 27 queries .
