查看: 904|回复: 0
[脱机烧录] 烧录串行Flash之后自动设置 QE = 1 (启用四线模式)
发表于 2026-1-28 16:28:55 | 显示全部楼层 |阅读模式
添加如下高级脚本即可
[Lua] 纯文本查看 复制代码
function DoAfterProg(void)
        local s0
        local n0, n1
        --新增写状态字 QE = 1
        print("Write QE = 1")
        print_hex(pg_iap("SPI_FLASH", "send_and_recive", "\x9F", 3)) --读flash ID
        pg_iap("SPI_FLASH", "send_and_recive", "\x06", 0)   --允许写
        pg_iap("SPI_FLASH", "send_and_recive", "\x31\x02", 0) --写QE=1  (非易失,掉电会保持)
        s0 = pg_iap("SPI_FLASH", "send_and_recive", "\x05", 1); --读状态字低8位
        n0 = string.byte(s0, 1)
        s0 = pg_iap("SPI_FLASH", "send_and_recive", "\x35", 1); --读状态字高8位
        n1 = string.byte(s0, 1)
        str = string.format("Status Bytes = 0x%02X%02X", n1,n0)
        print(str)
        --烧录完毕的动作【无需修改】
        if (RESET_AFTER_COMPLETE == 0) then
                --不动作
        elseif (RESET_AFTER_COMPLETE == 1) then
                --print("烧录完毕,已执行reset复位")
                pg_reset()
        elseif (RESET_AFTER_COMPLETE == 2) then
                --print("烧录完毕,已执行断电复位")
                set_tvcc(0) delayms(500) set_tvcc(TVCC_VOLT)
        elseif (RESET_AFTER_COMPLETE == 3) then
                --print("烧录完毕,已断电")
                set_tvcc(0)
        end
end
串行Flash状态字QE设置1.lua (1017 Bytes, 下载次数: 1)
GMT+8, 2026-11-28 09:43 , Processed in 0.681800 second(s), 27 queries .
