查看: 903|回复: 4
[其它] 请教下stm32f030对option byte编程时,需要先擦除吗?
发表于 2026-1-7 22:37:34 | 显示全部楼层 |阅读模式
看了手册上,写的很含糊,
发表于 2026-1-8 08:41:22 | 显示全部楼层
这些东西我觉得实测一下最靠谱,不要听任何人讲,先直接写,再读,看正常不?再重复多次,每次不同的数据,如果正常则不需要擦,否则需要擦除。
 楼主| 发表于 2026-1-8 10:00:37 | 显示全部楼层
fxyc87 发表于 2026-1-8 08:41
这些东西我觉得实测一下最靠谱,不要听任何人讲,先直接写,再读,看正常不?再重复多次,每次不同的数据, ...
我刚试了下,应该是要擦除的,
发表于 2026-1-8 11:05:29 | 显示全部楼层
F0系列需要的,后来的F4等系列,可以写选项字节寄存器时自动擦除。
  * @brief  Erases the FLASH option bytes.
  * @note   This functions erases all option bytes except the Read protection (RDP).
  *         The function @ref HAL_FLASH_Unlock() should be called before to unlock the FLASH interface
  *         The function @ref HAL_FLASH_OB_Unlock() should be called before to unlock the options bytes
  *         The function @ref HAL_FLASH_OB_Launch() should be called after to force the reload of the options bytes
  *         (system reset will occur)
  * @retval HAL status
HAL_StatusTypeDef HAL_FLASHEx_OBErase(void)
  uint8_t rdptmp = OB_RDP_LEVEL_0;
  HAL_StatusTypeDef status = HAL_ERROR;
  /* Get the actual read protection Option Byte value */
  rdptmp = FLASH_OB_GetRDP();
  /* Wait for last operation to be completed */
  status = FLASH_WaitForLastOperation((uint32_t)FLASH_TIMEOUT_VALUE);
  if(status == HAL_OK)
    /* Clean the error context */
    pFlash.ErrorCode = HAL_FLASH_ERROR_NONE;
    /* If the previous operation is completed, proceed to erase the option bytes */
    SET_BIT(FLASH->CR, FLASH_CR_OPTER);
    SET_BIT(FLASH->CR, FLASH_CR_STRT);
    /* If the erase operation is completed, disable the OPTER Bit */
    CLEAR_BIT(FLASH->CR, FLASH_CR_OPTER);
      /* Restore the last read protection Option Byte value */
      status = FLASH_OB_RDP_LevelConfig(rdptmp);
  /* Return the erase status */
  return status;
 楼主| 发表于 2026-1-8 11:11:44 | 显示全部楼层
[mw_shl_code=c,true]/**
是的,F4系列的会自动擦除
GMT+8, 2026-11-24 07:06 , Processed in 3.521886 second(s), 24 queries .
