查看: 1262|回复: 13
[USB] STM32H7 EMMC USBHS(USB3300) MSC速度慢的问题
发表于 2026-1-4 12:10:47 | 显示全部楼层 |阅读模式
近期仿照H7 Tool 实现了一下存储功能部分的设计, 因为项目上有需求要用到传感器的数据存储, 之前都是拿SD卡直接保存的, 但是有可能写入失败或因为震动导致连接不稳定. 准备切换到EMMC方案. 在USB MSC上碰到了不对劲的地方. MSC测速非常慢, 远远达不到正常测速的速度.
使用了STM32H743VI作为主处理器, 三星EMMC KLMBG2JETD-B041, 配合USB3300 做高速USB设备的方式.
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 13;
  RCC_OscInitStruct.PLL.PLLN = 480;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 20;
  RCC_OscInitStruct.PLL.PLLR = 4;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_1;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    Error_Handler();
  /** Enables the Clock Security System
  HAL_RCC_EnableCSS();
外部晶振26M, 主频480M, SDMMC1,2是PLL2R 即200MHZ. 在SDMMC中分频为2, 实际得到的频率      SDMMC_CK frequency = sdmmc_ker_ck / 4 = 50M, 应该已经到外设能够支持最大的上限.
开启对应的硬件流控. 开启CaChe.
使用片内测速代码, 测试得到的速度为:
这个速度跟硬汉哥的测试结果类似, 我的可能偏慢一些.
使能USB MSC, 设置MSC缓冲为32KB
数据读取和写入函数如下:
  * @brief  Reads data from the medium.
  * @param  lun: Logical unit number.
  * @param  buf: data buffer.
  * @param  blk_addr: Logical block address.
  * @param  blk_len: Blocks number.
  * @retval USBD_OK if all operations are OK else USBD_FAIL
int8_t STORAGE_Read_HS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len)
  /* USER CODE BEGIN 13 */
        int8_t ret = USBD_FAIL;
        uint8_t cnt = 0;
        uint32_t timeout = 1000;
        HAL_StatusTypeDef status = HAL_MMC_ReadBlocks(&hmmc1, buf, blk_addr, blk_len, timeout);
        if (status == HAL_OK)
//                printf("[USB MSC] HAL_MMC_ReadBlocks: OK\r\n");
                ret = USBD_OK;
                // 等待卡完成传输
                while (HAL_MMC_GetCardState(&hmmc1) != HAL_MMC_CARD_TRANSFER)
                // 打印失败的状态码
                printf("[USB MSC] HAL_MMC_ReadBlocks: FAIL, status=%d\r\n", status);
                // 获取并打印下卡状态
                printf("[USB MSC] CardState after fail: %d\r\n", HAL_MMC_GetCardState(&hmmc1));
                // 如果有详细错误原因,可以读取错误寄存器
                printf("[USB MSC] ErrorCode: 0x%08lX\r\n", HAL_MMC_GetError(&hmmc1));
        return ret;
  /* USER CODE END 13 */
  * @brief  Writes data into the medium.
int8_t STORAGE_Write_HS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len)
  /* USER CODE BEGIN 14 */
        uint8_t cnt = 0;
        uint32_t timeout = 5000;
        HAL_StatusTypeDef status = HAL_MMC_WriteBlocks(&hmmc1, buf, blk_addr, blk_len, timeout);
                ret = USBD_OK;
                // 等待卡完成传输
                // 打印失败的状态码
                // 获取并打印下卡状态
        return ret;
  /* USER CODE END 14 */
  * @brief  Returns the Max Supported LUNs.
  * @param  None
  * @retval Lun(s) number.
int8_t STORAGE_GetMaxLun_HS(void)
  /* USER CODE BEGIN 15 */
        return (STORAGE_LUN_NBR - 1);
  /* USER CODE END 15 */
实际测试得到的结果
这个速度我感觉太慢了, 请问大家可能在那里出现了问题呢? 是否需要将写入改为DMA模式呢?
我看USB整体的写入和读取调度都是在中断中完成的, 这里启用DMA似乎也没有任何意义, CPU还是需要死等DMA结束. 请大家赐教
发表于 2026-1-4 15:48:27 | 显示全部楼层
图片没上传成功,图片要编辑里面单独上传下才行
 楼主| 发表于 2026-1-4 15:57:24 | 显示全部楼层
已修改, 麻烦硬汉哥重新审核一下
发表于 2026-1-4 23:05:03 | 显示全部楼层
楼主打开USB IP 的 DMA没有?
我画的开发板是STM32H723ZG + USB3300 + 三星64GEVO Plus 4线SD卡,格式化为FAT32,SDMMC 50MHz时钟
用 ThreadX + USBX + FileX,USB IP 打开 DMA,
USB MSC 读写函数都用 DMA API,32KB或64KB请求长度
FileX 用硬汉的测速例子,每次读写BUF也是 32KB (#define BUF_SIZE (32 * 1024))
Os编译优化下,电脑 ATTO 测MSC的速度甚至还比 STM32 本地 FileX 读写更快
本地FileX:
电脑ATTO:(UX_SLAVE_REQUEST_DATA_MAX_LENGTH 分别为 32KB 和 64KB)
UX_SLAVE_REQUEST_DATA_MAX_LENGTH=32768.png UX_SLAVE_REQUEST_DATA_MAX_LENGTH=65536.png
参与人数 1金币 +20 收起 理由
cxrundo_embed + 20 很给力!
发表于 2026-1-5 00:05:06 | 显示全部楼层
Winston 发表于 2026-1-4 15:57
已修改, 麻烦硬汉哥重新审核一下
传输大文件,我看下实际速度多少。
 楼主| 发表于 2026-1-8 12:09:34 | 显示全部楼层
OldGerman 发表于 2026-1-4 23:05
楼主打开USB IP 的 DMA没有?
STM32H7 USB Internal DMA 打开后, 会有D cache的问题, 这个问题你是怎么解决的呢?
发表于 2026-1-9 00:19:26 | 显示全部楼层
1、可以关闭MPU Cache
2、可以手动设置Clean和无效化。
参与人数 1金币 +6 收起 理由
OldGerman + 6 完全OK!
 楼主| 发表于 2026-1-9 16:01:34 | 显示全部楼层
今天抽空测试了下H7Tool的MSC EMMC性能, 我看跟我的似乎差不多. 那么这个问题就已经是整个通讯链路的上限了, ST H7 对比WCH USB HS 的单片机性能还是相差比较多的
发表于 2026-1-9 19:04:58 | 显示全部楼层
我目前是USBX 的32KB缓冲区放在MPU配置的最低性能NORMAL模式的内存区内,
但MSC读函数在DMA读SD卡后还是加了SCB_InvalidateDCache_by_Addr,
写函数在DMA写SD卡之前还是加了SCB_CleanDCache_by_Addr,供以后开cache使能
发表于 2026-1-10 10:16:49 | 显示全部楼层
Winston 发表于 2026-1-9 16:01
今天抽空测试了下H7Tool的MSC EMMC性能, 我看跟我的似乎差不多. 那么这个问题就已经是整个通讯链路的上限了 ...
这个不是USB的限制,H7的USB完全无压力,毕竟500M主频呢,是这个限制:
加上文件系统后,速度相比裸机降低一半,你给SDMMC外接高速PHY,支持 200MB/S就可以了。
 楼主| 发表于 2026-1-11 00:05:05 | 显示全部楼层
加上文件系统后,速度相比裸机 ...
如果我想测试H7 USB 的性能, 我是否能用RAM模拟一个内部闪存, 来测试MSC模式下对应USB速度的上限呢?
另外SDMMC加上PHY之后, 似乎是可以跑1.8V的很多模式, 好像不支持DDR模式, 这个PHY在一般应用下是否有必要呢? 嘿嘿
发表于 2026-1-11 02:14:45 | 显示全部楼层
另 ...
1、RAM太小了,测试的数据太少。
2、HS200足够,USB 2.0高速远达不到这个速度。
 楼主| 发表于 2026-1-11 17:14:58 | 显示全部楼层
eric2013 发表于 2026-1-11 02:14
1、RAM太小了,测试的数据太少。
感谢硬汉哥的回答, 对于这个话题我还是想深入的聊一下.
1. 对于H7 USB HS来说, 是否可以通过其他 比如说HID 或者CDC 模式来测试对应的性能上限呢? 我只想让MSC模式下读写都超过25M来满足我的产品应用.
2. 按照我的理解, 目前裸机直写的性能远远达不到EMMC手册的性能上线, 本质是因为其IO电平问题, 无法协商更高的速度了, 另外H7自身在3.3v IO bank voltage 情况下也有自己的翻转上限. 裸机R:42.16MB/s W:32.53MB/s 已经是在当前PCB布局下的性能上限了, 再加上MSC和文件系统的额外开销, 已经没办法更快了. 或许裸机性能提高后MSC能够更快?
3. 在这个模式下, USB Internal DMA 因为我没有对Cache的操作, 导致其工作不正常. 本质上开启USB DMA是否能增加MSC性能呢?
4. 在MSC回调中断中, 对EMMC操作是一个死等的模式, 似乎这里使用SDMMC的DMA没有必要了, 因为终将是要等待回调, 或许在RTOS中可以单独变成一个线程通知进行操作?
感谢硬汉哥, 期待您的回复
发表于 2026-1-15 08:12:52 | 显示全部楼层
STM32 的USB 是阉割的USB ,完整的INTERL那套USB  是叫什么 ECHI吧,目前绝大部分国产MCU都是用的ST 的那套USB IP,像NXP,和新塘的USB 就是和电脑主板那种差不多USB
GMT+8, 2026-10-24 10:19 , Processed in 0.800673 second(s), 29 queries .
