查看: 912|回复: 1
[CMSIS-Driver] STM32的新版CMSIS-Driver驱动开头的CubeMX配置参考价值很大
发表于 2025-12-29 02:09:45 | 显示全部楼层 |阅读模式
https://github.com/Open-CMSIS-Pack/CMSIS-Driver_STM32
STM32给所有系列提供的CMSIS-Driver驱动开头都有个CubeMX配置说明可以参考
非常具有参考价值,这个配置主要是方便大家配置GPIO引脚, NVIC等
以以太网为例
/*! \page eth_mac_stm32 Ethernet MAC
# Revision History
- Version 3.0
  - Initial release
# Requirements
This driver requires the STM32 device specific **HAL** and **STM32CubeMX** (CubeMX) initialization code generator.
The driver instance is mapped to hardware as shown in the table below:
  CMSIS Driver Instance | STM32 Hardware Resource
  Driver_ETH_MAC0       | EMAC
# Deviations
This driver has the following deviations from the CMSIS-Driver specification:
__Conceptual__ deviations:
  - CubeMX generated initialization code (function MX_ETH_Init) already configures
    the peripheral. Power, clocks, pins, and interrupts are enabled after execution
    of initialization that executes in `main.c`.
__Functional__ deviations:
  - GetCapabilities:
    - depends on the code generated by CubeMX.
  - Initialize:
    - does not initialize the pins.
  - Uninitialize:
    - does not de-initialize the pins.
  - PowerControl:
    - low-power mode is not supported by HAL.
  - SetAddressFilter:
    - not supported by HAL.
  - GetRxFrameTime:
  - GetTxFrameTime:
  - Control:
    - not supported control codes: ARM_ETH_MAC_CONTROL_TX, ARM_ETH_MAC_FLUSH, and ARM_ETH_MAC_SLEEP.
    - for control code ARM_ETH_MAC_VLAN_FILTER the VLAN filter disable is not supported.
  - ControlTimer:
# CubeMX Configuration
This driver requires the following configuration in CubeMX:
  - **clock**: appropriate **AHB clock** used for clocking Ethernet MAC controller.
  - **peripheral**: **ETH** peripheral configured as **MII** or **RMII** mode
    and **Parameter Settings** configured as desired.
  - **pins**:
    - for **RMII** mode: **ETH_CRS_DV**, **ETH_MDC**, **ETH_MDIO**, **ETH_REF_CLK**, **ETH_RXD0**
      , **ETH_RXD1**, **ETH_TXD0**, **ETH_TXD1** and **ETH_TX_EN pins**.
    - for **MII** mode: **ETH_COL**, **ETH_CRS**, **ETH_MDC**, **ETH_MDIO**, **ETH_RXD0**
      , **ETH_RXD1**, **ETH_RXD2**, **ETH_RXD3**, **ETH_RX_CLK**, **ETH_RX_DV**, **ETH_TXD0**
      , **ETH_TXD1**, **ETH_TXD2**, **ETH_TXD3**, **ETH_TX_CLK** and **ETH_TX_EN pins**.
  - **interrupts**: enabled **Ethernet global interrupt** and **IRQ handlers** that **Call HAL handlers**.
> **Notes**
> - configuration information in the **MX_Device.h** file is based on CubeMX configuration.
> - for devices with cache, ensure that ETH DMA descriptors (**DMARxDscrTab** and **DMATxDscrTab**)
>   are located in **non-cacheable** and **non-shareable device memory**.
> - for devices with cache, ensure that ETH data buffers (**eth_mac0_rx_buf** and **eth_mac0_tx_buf**)
>   are located in **non-cacheable** and **non-shareable normal memory**.
## Example
### Pinout & Configuration tab
  1. In the **Pinout view** window click on a pin and select it's functionality:
       Pin      | Functionality
       PA1      | **ETH_REF_CLK**
       PA2      | **ETH_MDIO**
       PA7      | **ETH_CRS_DV**
       PC1      | **ETH_MDC**
       PC4      | **ETH_RXD0**
       PC5      | **ETH_RXD1**
       PG11     | **ETH_TX_EN**
       PG12     | **ETH_TXD1**
       PG13     | **ETH_TXD0**
     \n
  2. Under **Categories**: **Connectivity** select **ETH**:
     __Mode__:
       - Mode: **RMII**
     __Configuration__:
       - Parameter Settings:
           General: Ethernet Configuration | Value
           Ethernet MAC Address            | unused
           Tx Descriptor Length            | **4**
           First Tx Descriptor Address     | **0x30040060**
           Rx Descriptor Length            | **4**
           First Rx Descriptor Address     | **0x30040000**
           Rx Buffers Length               | **1524**
         \n
       - GPIO Settings:
           Pin Name | Signal on Pin | Pin Context..| GPIO output..| GPIO mode                     | GPIO Pull-up/Pull..| Maximum out..| Fast Mode | User Label
           PA1      | ETH_REF_CLK   | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PA2      | ETH_MDIO      | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PA7      | ETH_CRS_DV    | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PC1      | ETH_MDC       | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PC4      | ETH_RXD0      | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PC5      | ETH_RXD1      | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PG11     | ETH_TX_EN     | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PG12     | ETH_TXD1      | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
           PG13     | ETH_TXD0      | n/a          | n/a          | Alternate Function Push Pull  | No pull-up and no..| **High**     | n/a       |.
         \n
  3. Under **Categories**: **System Core** select **NVIC**:
     __Configuration__:
       - NVIC:
           NVIC Interrupt Table              | Enabled     | Preemption Priority | Sub Priority
           Ethernet global interrupt         | **checked** | 0                   | 0
       - Code generation:
           Enabled interrupt table           | Select for..| Generate Enable in..| Generate IRQ h.. | Call HAL handler
           Ethernet global interrupt         | unchecked   | checked             | checked          | checked
       \n
  4. Under **Categories**: **System Core** select **CORTEX_M7**:
     __Configuration__:
           Speculation default mode Settings               | Value
           Speculation default mode                        | Disabled
         \n
           Cortex Interface Settings                       | Value
           CPU ICache                                      | Enabled
           CPU DCache Length                               | Enabled
         \n
           Cortex Memory Protection Unit Control Settings  | Value
           MPU Control Mode                                | Background Region Privileged accesses only + MPU disabled during hard fault
         \n
           Cortex Memory Protection Unit Region 0 Settings | Value
           MPU Region                                      | **Enabled**
           MPU Region Base Address                         | **0x24000000**
           MPU Region Size                                 | **512kB**
           MPU SubRegion Disable                           | **0x0**
           MPU TEX field level                             | **level 1**
           MPU Access Permission                           | **ALL ACCESS PERMITTED**
           MPU Instruction Access                          | **DISABLE**
           MPU Shareability Permission                     | **DISABLE**
           MPU Cacheable Permission                        | **ENABLE**
           MPU Bufferable Permission                       | **ENABLE**
         \n
           Cortex Memory Protection Unit Region 1 Settings | Value
           MPU Region Base Address                         | **0x30000000**
           MPU Cacheable Permission                        | **DISABLE**
           MPU Bufferable Permission                       | **DISABLE**
         \n
           Cortex Memory Protection Unit Region 2 Settings | Value
           MPU Region Base Address                         | **0x30040000**
           MPU Region Size                                 | **256B**
           MPU TEX field level                             | **level 0**
         \n
### Clock Configuration tab
  1. Configure **To AHB1,2 Peripheral Clocks (MHz)**: **200**
### Project Manager tab
  1. Under **Advanced Settings**:
     __Generated Function Calls__:
       Generate Code | Function Name               | Peripheral Inst..| Do not generate ..| Visibility (Static)
       checked       | MX_ETH_Init                 | ETH              | unchecked         | checked
## Source Code
Add **RxDecripSection**, **TxDecripSection**, <b>.driver.eth_mac0_rx_buf</b> and <b>.driver.eth_mac0_tx_buf</b>
sections to the Scatter file if GNU Compiler or Arm Compiler 6 is used.
Example:
RW_ETH_RX_DESC 0x30040000 0x00000060 {
  *(.RxDecripSection)
RW_ETH_TX_DESC 0x30040060 0x00000060 {
  *(.TxDecripSection)
RW_ETH_RX_BUF  0x30040100 0x00001800 {
  *(.driver.eth_mac0_rx_buf)
RW_ETH_TX_BUF  0x30041900 0x00001800 {
  *(.driver.eth_mac0_tx_buf)
发表于 2025-12-30 14:08:38 | 显示全部楼层
GMT+8, 2026-10-24 10:36 , Processed in 0.269258 second(s), 24 queries .
