查看: 1218|回复: 5
[示波器] 测评最新完成的H7-TOOL的250M示波器信号频率估算精度(2025-12-19)
发表于 2025-12-19 00:34:09 | 显示全部楼层 |阅读模式
测试条件:
采样率设置为2MHz,采用点数1024,那么频率是1953Hz时,1024点正好采集1个周期。然后根据奈奎斯特,最高可以采集1MHz
那么我们设置波形起始频率是1953Hz 到 1MHz结束时的精度效果
实测效果:
从991458Hz开始,也就是接近1MHz时,稍微差点,其他时间误差小于1Hz。
信号频率 = 1953Hz,实际估算频率 = 1952.995483
信号频率 = 3952Hz,实际估算频率 = 3952.365479
信号频率 = 5951Hz,实际估算频率 = 5951.314453
信号频率 = 7950Hz,实际估算频率 = 7950.256348
信号频率 = 9949Hz,实际估算频率 = 9949.208984
信号频率 = 11948Hz,实际估算频率 = 11948.170898
信号频率 = 13947Hz,实际估算频率 = 13947.142578
信号频率 = 15946Hz,实际估算频率 = 15946.118164
信号频率 = 17945Hz,实际估算频率 = 17945.097656
信号频率 = 19944Hz,实际估算频率 = 19944.080078
信号频率 = 21943Hz,实际估算频率 = 21943.064453
信号频率 = 23942Hz,实际估算频率 = 23942.050781
信号频率 = 25941Hz,实际估算频率 = 25941.042969
信号频率 = 27940Hz,实际估算频率 = 27940.033203
信号频率 = 29939Hz,实际估算频率 = 29939.025391
信号频率 = 31938Hz,实际估算频率 = 31938.015625
信号频率 = 33937Hz,实际估算频率 = 33937.015625
信号频率 = 35936Hz,实际估算频率 = 35936.007813
信号频率 = 37935Hz,实际估算频率 = 37935.003906
信号频率 = 39934Hz,实际估算频率 = 39934.000000
信号频率 = 41933Hz,实际估算频率 = 41933.000000
信号频率 = 43932Hz,实际估算频率 = 43931.996094
信号频率 = 45931Hz,实际估算频率 = 45930.996094
信号频率 = 47930Hz,实际估算频率 = 47930.000000
信号频率 = 49929Hz,实际估算频率 = 49928.992188
信号频率 = 51928Hz,实际估算频率 = 51927.996094
信号频率 = 53927Hz,实际估算频率 = 53926.988281
信号频率 = 55926Hz,实际估算频率 = 55925.992188
信号频率 = 57925Hz,实际估算频率 = 57924.992188
信号频率 = 59924Hz,实际估算频率 = 59923.992188
信号频率 = 61923Hz,实际估算频率 = 61922.992188
信号频率 = 63922Hz,实际估算频率 = 63921.988281
信号频率 = 65921Hz,实际估算频率 = 65920.992188
信号频率 = 67920Hz,实际估算频率 = 67919.992188
信号频率 = 69919Hz,实际估算频率 = 69918.992188
信号频率 = 71918Hz,实际估算频率 = 71917.992188
信号频率 = 73917Hz,实际估算频率 = 73916.992188
信号频率 = 75916Hz,实际估算频率 = 75915.992188
信号频率 = 77915Hz,实际估算频率 = 77914.992188
信号频率 = 79914Hz,实际估算频率 = 79913.992188
信号频率 = 81913Hz,实际估算频率 = 81912.984375
信号频率 = 83912Hz,实际估算频率 = 83911.992188
信号频率 = 85911Hz,实际估算频率 = 85910.992188
信号频率 = 87910Hz,实际估算频率 = 87909.992188
信号频率 = 89909Hz,实际估算频率 = 89908.992188
信号频率 = 91908Hz,实际估算频率 = 91907.992188
信号频率 = 93907Hz,实际估算频率 = 93906.992188
信号频率 = 95906Hz,实际估算频率 = 95906.000000
信号频率 = 97905Hz,实际估算频率 = 97904.992188
信号频率 = 99904Hz,实际估算频率 = 99903.992188
信号频率 = 101903Hz,实际估算频率 = 101903.000000
信号频率 = 103902Hz,实际估算频率 = 103902.000000
信号频率 = 105901Hz,实际估算频率 = 105900.992188
信号频率 = 107900Hz,实际估算频率 = 107899.992188
信号频率 = 109899Hz,实际估算频率 = 109899.000000
信号频率 = 111898Hz,实际估算频率 = 111898.000000
信号频率 = 113897Hz,实际估算频率 = 113896.992188
信号频率 = 115896Hz,实际估算频率 = 115895.992188
信号频率 = 117895Hz,实际估算频率 = 117894.992188
信号频率 = 119894Hz,实际估算频率 = 119893.992188
信号频率 = 121893Hz,实际估算频率 = 121893.000000
信号频率 = 123892Hz,实际估算频率 = 123891.992188
信号频率 = 125891Hz,实际估算频率 = 125891.000000
信号频率 = 127890Hz,实际估算频率 = 127890.007813
信号频率 = 129889Hz,实际估算频率 = 129889.000000
信号频率 = 131888Hz,实际估算频率 = 131887.984375
信号频率 = 133887Hz,实际估算频率 = 133887.000000
信号频率 = 135886Hz,实际估算频率 = 135886.000000
信号频率 = 137885Hz,实际估算频率 = 137884.984375
信号频率 = 139884Hz,实际估算频率 = 139884.000000
信号频率 = 141883Hz,实际估算频率 = 141883.000000
信号频率 = 143882Hz,实际估算频率 = 143881.984375
信号频率 = 145881Hz,实际估算频率 = 145881.000000
信号频率 = 147880Hz,实际估算频率 = 147880.000000
信号频率 = 149879Hz,实际估算频率 = 149879.000000
信号频率 = 151878Hz,实际估算频率 = 151878.000000
信号频率 = 153877Hz,实际估算频率 = 153876.984375
信号频率 = 155876Hz,实际估算频率 = 155876.000000
信号频率 = 157875Hz,实际估算频率 = 157875.000000
信号频率 = 159874Hz,实际估算频率 = 159874.000000
信号频率 = 161873Hz,实际估算频率 = 161872.984375
信号频率 = 163872Hz,实际估算频率 = 163872.000000
信号频率 = 165871Hz,实际估算频率 = 165871.015625
信号频率 = 167870Hz,实际估算频率 = 167869.984375
信号频率 = 169869Hz,实际估算频率 = 169868.984375
信号频率 = 171868Hz,实际估算频率 = 171868.015625
信号频率 = 173867Hz,实际估算频率 = 173866.984375
信号频率 = 175866Hz,实际估算频率 = 175866.000000
信号频率 = 177865Hz,实际估算频率 = 177865.000000
信号频率 = 179864Hz,实际估算频率 = 179863.984375
信号频率 = 181863Hz,实际估算频率 = 181863.000000
信号频率 = 183862Hz,实际估算频率 = 183862.000000
信号频率 = 185861Hz,实际估算频率 = 185860.984375
信号频率 = 187860Hz,实际估算频率 = 187860.000000
信号频率 = 189859Hz,实际估算频率 = 189858.984375
信号频率 = 191858Hz,实际估算频率 = 191858.000000
信号频率 = 193857Hz,实际估算频率 = 193857.000000
信号频率 = 195856Hz,实际估算频率 = 195855.984375
信号频率 = 197855Hz,实际估算频率 = 197855.000000
信号频率 = 199854Hz,实际估算频率 = 199854.000000
信号频率 = 201853Hz,实际估算频率 = 201852.984375
信号频率 = 203852Hz,实际估算频率 = 203852.000000
信号频率 = 205851Hz,实际估算频率 = 205851.000000
信号频率 = 207850Hz,实际估算频率 = 207850.000000
信号频率 = 209849Hz,实际估算频率 = 209849.000000
信号频率 = 211848Hz,实际估算频率 = 211848.000000
信号频率 = 213847Hz,实际估算频率 = 213847.000000
信号频率 = 215846Hz,实际估算频率 = 215846.000000
信号频率 = 217845Hz,实际估算频率 = 217845.000000
信号频率 = 219844Hz,实际估算频率 = 219844.000000
信号频率 = 221843Hz,实际估算频率 = 221843.000000
信号频率 = 223842Hz,实际估算频率 = 223842.015625
信号频率 = 225841Hz,实际估算频率 = 225841.000000
信号频率 = 227840Hz,实际估算频率 = 227840.000000
信号频率 = 229839Hz,实际估算频率 = 229839.015625
信号频率 = 231838Hz,实际估算频率 = 231838.000000
信号频率 = 233837Hz,实际估算频率 = 233837.015625
信号频率 = 235836Hz,实际估算频率 = 235836.015625
信号频率 = 237835Hz,实际估算频率 = 237835.000000
信号频率 = 239834Hz,实际估算频率 = 239834.015625
信号频率 = 241833Hz,实际估算频率 = 241833.000000
信号频率 = 243832Hz,实际估算频率 = 243832.000000
信号频率 = 245831Hz,实际估算频率 = 245831.015625
信号频率 = 247830Hz,实际估算频率 = 247830.000000
信号频率 = 249829Hz,实际估算频率 = 249829.015625
信号频率 = 251828Hz,实际估算频率 = 251828.015625
信号频率 = 253827Hz,实际估算频率 = 253827.000000
信号频率 = 255826Hz,实际估算频率 = 255826.031250
信号频率 = 257825Hz,实际估算频率 = 257825.015625
信号频率 = 259824Hz,实际估算频率 = 259824.000000
信号频率 = 261823Hz,实际估算频率 = 261823.031250
信号频率 = 263822Hz,实际估算频率 = 263822.031250
信号频率 = 265821Hz,实际估算频率 = 265821.000000
信号频率 = 267820Hz,实际估算频率 = 267820.031250
信号频率 = 269819Hz,实际估算频率 = 269819.031250
信号频率 = 271818Hz,实际估算频率 = 271818.000000
信号频率 = 273817Hz,实际估算频率 = 273817.000000
信号频率 = 275816Hz,实际估算频率 = 275816.031250
信号频率 = 277815Hz,实际估算频率 = 277815.000000
信号频率 = 279814Hz,实际估算频率 = 279814.000000
信号频率 = 281813Hz,实际估算频率 = 281813.031250
信号频率 = 283812Hz,实际估算频率 = 283812.031250
信号频率 = 285811Hz,实际估算频率 = 285811.000000
信号频率 = 287810Hz,实际估算频率 = 287810.000000
信号频率 = 289809Hz,实际估算频率 = 289809.031250
信号频率 = 291808Hz,实际估算频率 = 291808.000000
信号频率 = 293807Hz,实际估算频率 = 293807.000000
信号频率 = 295806Hz,实际估算频率 = 295806.031250
信号频率 = 297805Hz,实际估算频率 = 297805.000000
信号频率 = 299804Hz,实际估算频率 = 299804.000000
信号频率 = 301803Hz,实际估算频率 = 301803.031250
信号频率 = 303802Hz,实际估算频率 = 303802.000000
信号频率 = 305801Hz,实际估算频率 = 305801.000000
信号频率 = 307800Hz,实际估算频率 = 307800.031250
信号频率 = 309799Hz,实际估算频率 = 309799.000000
信号频率 = 311798Hz,实际估算频率 = 311798.000000
信号频率 = 313797Hz,实际估算频率 = 313797.031250
信号频率 = 315796Hz,实际估算频率 = 315796.031250
信号频率 = 317795Hz,实际估算频率 = 317795.000000
信号频率 = 319794Hz,实际估算频率 = 319794.031250
信号频率 = 321793Hz,实际估算频率 = 321793.031250
信号频率 = 323792Hz,实际估算频率 = 323792.031250
信号频率 = 325791Hz,实际估算频率 = 325791.000000
信号频率 = 327790Hz,实际估算频率 = 327790.031250
信号频率 = 329789Hz,实际估算频率 = 329789.000000
信号频率 = 331788Hz,实际估算频率 = 331788.031250
信号频率 = 333787Hz,实际估算频率 = 333787.031250
信号频率 = 335786Hz,实际估算频率 = 335786.031250
信号频率 = 337785Hz,实际估算频率 = 337785.000000
信号频率 = 339784Hz,实际估算频率 = 339784.031250
信号频率 = 341783Hz,实际估算频率 = 341783.031250
信号频率 = 343782Hz,实际估算频率 = 343782.031250
信号频率 = 345781Hz,实际估算频率 = 345781.031250
信号频率 = 347780Hz,实际估算频率 = 347780.062500
信号频率 = 349779Hz,实际估算频率 = 349779.000000
信号频率 = 351778Hz,实际估算频率 = 351778.000000
信号频率 = 353777Hz,实际估算频率 = 353777.031250
信号频率 = 355776Hz,实际估算频率 = 355776.000000
信号频率 = 357775Hz,实际估算频率 = 357775.031250
信号频率 = 359774Hz,实际估算频率 = 359774.000000
信号频率 = 361773Hz,实际估算频率 = 361773.000000
信号频率 = 363772Hz,实际估算频率 = 363772.000000
信号频率 = 365771Hz,实际估算频率 = 365771.031250
信号频率 = 367770Hz,实际估算频率 = 367770.031250
信号频率 = 369769Hz,实际估算频率 = 369769.031250
信号频率 = 371768Hz,实际估算频率 = 371768.000000
信号频率 = 373767Hz,实际估算频率 = 373767.031250
信号频率 = 375766Hz,实际估算频率 = 375766.000000
信号频率 = 377765Hz,实际估算频率 = 377765.031250
信号频率 = 379764Hz,实际估算频率 = 379764.031250
信号频率 = 381763Hz,实际估算频率 = 381763.031250
信号频率 = 383762Hz,实际估算频率 = 383762.000000
信号频率 = 385761Hz,实际估算频率 = 385761.000000
信号频率 = 387760Hz,实际估算频率 = 387760.000000
信号频率 = 389759Hz,实际估算频率 = 389759.000000
信号频率 = 391758Hz,实际估算频率 = 391758.031250
信号频率 = 393757Hz,实际估算频率 = 393757.031250
信号频率 = 395756Hz,实际估算频率 = 395756.000000
信号频率 = 397755Hz,实际估算频率 = 397755.000000
信号频率 = 399754Hz,实际估算频率 = 399754.031250
信号频率 = 401753Hz,实际估算频率 = 401753.000000
信号频率 = 403752Hz,实际估算频率 = 403752.031250
信号频率 = 405751Hz,实际估算频率 = 405751.031250
信号频率 = 407750Hz,实际估算频率 = 407750.000000
信号频率 = 409749Hz,实际估算频率 = 409749.000000
信号频率 = 411748Hz,实际估算频率 = 411748.031250
信号频率 = 413747Hz,实际估算频率 = 413747.000000
信号频率 = 415746Hz,实际估算频率 = 415746.031250
信号频率 = 417745Hz,实际估算频率 = 417745.000000
信号频率 = 419744Hz,实际估算频率 = 419744.000000
信号频率 = 421743Hz,实际估算频率 = 421743.000000
信号频率 = 423742Hz,实际估算频率 = 423742.031250
信号频率 = 425741Hz,实际估算频率 = 425741.031250
信号频率 = 427740Hz,实际估算频率 = 427740.031250
信号频率 = 429739Hz,实际估算频率 = 429739.000000
信号频率 = 431738Hz,实际估算频率 = 431738.000000
信号频率 = 433737Hz,实际估算频率 = 433737.000000
信号频率 = 435736Hz,实际估算频率 = 435736.031250
信号频率 = 437735Hz,实际估算频率 = 437735.031250
信号频率 = 439734Hz,实际估算频率 = 439734.000000
信号频率 = 441733Hz,实际估算频率 = 441733.000000
信号频率 = 443732Hz,实际估算频率 = 443732.000000
信号频率 = 445731Hz,实际估算频率 = 445731.000000
信号频率 = 447730Hz,实际估算频率 = 447730.000000
信号频率 = 449729Hz,实际估算频率 = 449729.031250
信号频率 = 451728Hz,实际估算频率 = 451728.031250
信号频率 = 453727Hz,实际估算频率 = 453727.000000
信号频率 = 455726Hz,实际估算频率 = 455726.000000
信号频率 = 457725Hz,实际估算频率 = 457725.031250
信号频率 = 459724Hz,实际估算频率 = 459724.000000
信号频率 = 461723Hz,实际估算频率 = 461723.031250
信号频率 = 463722Hz,实际估算频率 = 463722.000000
信号频率 = 465721Hz,实际估算频率 = 465721.000000
信号频率 = 467720Hz,实际估算频率 = 467720.000000
信号频率 = 469719Hz,实际估算频率 = 469719.031250
信号频率 = 471718Hz,实际估算频率 = 471718.000000
信号频率 = 473717Hz,实际估算频率 = 473717.031250
信号频率 = 475716Hz,实际估算频率 = 475716.000000
信号频率 = 477715Hz,实际估算频率 = 477715.000000
信号频率 = 479714Hz,实际估算频率 = 479714.000000
信号频率 = 481713Hz,实际估算频率 = 481713.000000
信号频率 = 483712Hz,实际估算频率 = 483712.031250
信号频率 = 485711Hz,实际估算频率 = 485711.031250
信号频率 = 487710Hz,实际估算频率 = 487710.000000
信号频率 = 489709Hz,实际估算频率 = 489709.000000
信号频率 = 491708Hz,实际估算频率 = 491708.000000
信号频率 = 493707Hz,实际估算频率 = 493707.000000
信号频率 = 495706Hz,实际估算频率 = 495706.031250
信号频率 = 497705Hz,实际估算频率 = 497705.000000
信号频率 = 499704Hz,实际估算频率 = 499704.000000
信号频率 = 501703Hz,实际估算频率 = 501703.031250
信号频率 = 503702Hz,实际估算频率 = 503702.000000
信号频率 = 505701Hz,实际估算频率 = 505701.000000
信号频率 = 507700Hz,实际估算频率 = 507700.031250
信号频率 = 509699Hz,实际估算频率 = 509699.000000
信号频率 = 511698Hz,实际估算频率 = 511698.000000
信号频率 = 513697Hz,实际估算频率 = 513697.031250
信号频率 = 515696Hz,实际估算频率 = 515696.000000
信号频率 = 517695Hz,实际估算频率 = 517695.000000
信号频率 = 519694Hz,实际估算频率 = 519694.031250
信号频率 = 521693Hz,实际估算频率 = 521693.000000
信号频率 = 523692Hz,实际估算频率 = 523692.000000
信号频率 = 525691Hz,实际估算频率 = 525691.000000
信号频率 = 527690Hz,实际估算频率 = 527690.000000
信号频率 = 529689Hz,实际估算频率 = 529689.000000
信号频率 = 531688Hz,实际估算频率 = 531688.062500
信号频率 = 533687Hz,实际估算频率 = 533687.000000
信号频率 = 535686Hz,实际估算频率 = 535686.000000
信号频率 = 537685Hz,实际估算频率 = 537685.000000
信号频率 = 539684Hz,实际估算频率 = 539684.000000
信号频率 = 541683Hz,实际估算频率 = 541683.000000
信号频率 = 543682Hz,实际估算频率 = 543682.062500
信号频率 = 545681Hz,实际估算频率 = 545681.000000
信号频率 = 547680Hz,实际估算频率 = 547680.000000
信号频率 = 549679Hz,实际估算频率 = 549679.000000
信号频率 = 551678Hz,实际估算频率 = 551678.000000
信号频率 = 553677Hz,实际估算频率 = 553677.000000
信号频率 = 555676Hz,实际估算频率 = 555676.000000
信号频率 = 557675Hz,实际估算频率 = 557675.000000
信号频率 = 559674Hz,实际估算频率 = 559674.000000
信号频率 = 561673Hz,实际估算频率 = 561673.000000
信号频率 = 563672Hz,实际估算频率 = 563672.000000
信号频率 = 565671Hz,实际估算频率 = 565671.000000
信号频率 = 567670Hz,实际估算频率 = 567670.000000
信号频率 = 569669Hz,实际估算频率 = 569669.000000
信号频率 = 571668Hz,实际估算频率 = 571668.000000
信号频率 = 573667Hz,实际估算频率 = 573667.000000
信号频率 = 575666Hz,实际估算频率 = 575666.000000
信号频率 = 577665Hz,实际估算频率 = 577665.000000
信号频率 = 579664Hz,实际估算频率 = 579664.000000
信号频率 = 581663Hz,实际估算频率 = 581663.000000
信号频率 = 583662Hz,实际估算频率 = 583662.000000
信号频率 = 585661Hz,实际估算频率 = 585661.000000
信号频率 = 587660Hz,实际估算频率 = 587660.000000
信号频率 = 589659Hz,实际估算频率 = 589659.062500
信号频率 = 591658Hz,实际估算频率 = 591658.000000
信号频率 = 593657Hz,实际估算频率 = 593657.000000
信号频率 = 595656Hz,实际估算频率 = 595656.000000
信号频率 = 597655Hz,实际估算频率 = 597655.000000
信号频率 = 599654Hz,实际估算频率 = 599654.000000
信号频率 = 601653Hz,实际估算频率 = 601653.000000
信号频率 = 603652Hz,实际估算频率 = 603652.000000
信号频率 = 605651Hz,实际估算频率 = 605651.000000
信号频率 = 607650Hz,实际估算频率 = 607650.000000
信号频率 = 609649Hz,实际估算频率 = 609649.000000
信号频率 = 611648Hz,实际估算频率 = 611648.000000
信号频率 = 613647Hz,实际估算频率 = 613647.000000
信号频率 = 615646Hz,实际估算频率 = 615646.000000
信号频率 = 617645Hz,实际估算频率 = 617645.000000
信号频率 = 619644Hz,实际估算频率 = 619644.000000
信号频率 = 621643Hz,实际估算频率 = 621643.000000
信号频率 = 623642Hz,实际估算频率 = 623642.000000
信号频率 = 625641Hz,实际估算频率 = 625641.000000
信号频率 = 627640Hz,实际估算频率 = 627640.000000
信号频率 = 629639Hz,实际估算频率 = 629639.000000
信号频率 = 631638Hz,实际估算频率 = 631638.000000
信号频率 = 633637Hz,实际估算频率 = 633637.000000
信号频率 = 635636Hz,实际估算频率 = 635636.062500
信号频率 = 637635Hz,实际估算频率 = 637635.062500
信号频率 = 639634Hz,实际估算频率 = 639634.000000
信号频率 = 641633Hz,实际估算频率 = 641633.062500
信号频率 = 643632Hz,实际估算频率 = 643632.000000
信号频率 = 645631Hz,实际估算频率 = 645630.937500
信号频率 = 647630Hz,实际估算频率 = 647630.062500
信号频率 = 649629Hz,实际估算频率 = 649629.000000
信号频率 = 651628Hz,实际估算频率 = 651628.000000
信号频率 = 653627Hz,实际估算频率 = 653627.000000
信号频率 = 655626Hz,实际估算频率 = 655625.937500
信号频率 = 657625Hz,实际估算频率 = 657625.000000
信号频率 = 659624Hz,实际估算频率 = 659624.000000
信号频率 = 661623Hz,实际估算频率 = 661623.000000
信号频率 = 663622Hz,实际估算频率 = 663622.000000
信号频率 = 665621Hz,实际估算频率 = 665621.000000
信号频率 = 667620Hz,实际估算频率 = 667620.000000
信号频率 = 669619Hz,实际估算频率 = 669618.937500
信号频率 = 671618Hz,实际估算频率 = 671618.062500
信号频率 = 673617Hz,实际估算频率 = 673617.000000
信号频率 = 675616Hz,实际估算频率 = 675616.000000
信号频率 = 677615Hz,实际估算频率 = 677615.000000
信号频率 = 679614Hz,实际估算频率 = 679613.937500
信号频率 = 681613Hz,实际估算频率 = 681613.000000
信号频率 = 683612Hz,实际估算频率 = 683612.000000
信号频率 = 685611Hz,实际估算频率 = 685611.000000
信号频率 = 687610Hz,实际估算频率 = 687610.000000
信号频率 = 689609Hz,实际估算频率 = 689609.000000
信号频率 = 691608Hz,实际估算频率 = 691608.000000
信号频率 = 693607Hz,实际估算频率 = 693607.000000
信号频率 = 695606Hz,实际估算频率 = 695606.000000
信号频率 = 697605Hz,实际估算频率 = 697605.000000
信号频率 = 699604Hz,实际估算频率 = 699604.000000
信号频率 = 701603Hz,实际估算频率 = 701603.000000
信号频率 = 703602Hz,实际估算频率 = 703601.937500
信号频率 = 705601Hz,实际估算频率 = 705601.062500
信号频率 = 707600Hz,实际估算频率 = 707600.000000
信号频率 = 709599Hz,实际估算频率 = 709599.000000
信号频率 = 711598Hz,实际估算频率 = 711598.000000
信号频率 = 713597Hz,实际估算频率 = 713596.937500
信号频率 = 715596Hz,实际估算频率 = 715596.000000
信号频率 = 717595Hz,实际估算频率 = 717595.000000
信号频率 = 719594Hz,实际估算频率 = 719594.000000
信号频率 = 721593Hz,实际估算频率 = 721592.937500
信号频率 = 723592Hz,实际估算频率 = 723592.000000
信号频率 = 725591Hz,实际估算频率 = 725591.000000
信号频率 = 727590Hz,实际估算频率 = 727589.937500
信号频率 = 729589Hz,实际估算频率 = 729589.062500
信号频率 = 731588Hz,实际估算频率 = 731588.000000
信号频率 = 733587Hz,实际估算频率 = 733587.000000
信号频率 = 735586Hz,实际估算频率 = 735586.000000
信号频率 = 737585Hz,实际估算频率 = 737584.937500
信号频率 = 739584Hz,实际估算频率 = 739584.000000
信号频率 = 741583Hz,实际估算频率 = 741583.000000
信号频率 = 743582Hz,实际估算频率 = 743582.000000
信号频率 = 745581Hz,实际估算频率 = 745581.000000
信号频率 = 747580Hz,实际估算频率 = 747579.937500
信号频率 = 749579Hz,实际估算频率 = 749579.000000
信号频率 = 751578Hz,实际估算频率 = 751578.000000
信号频率 = 753577Hz,实际估算频率 = 753577.000000
信号频率 = 755576Hz,实际估算频率 = 755575.937500
信号频率 = 757575Hz,实际估算频率 = 757574.937500
信号频率 = 759574Hz,实际估算频率 = 759574.000000
信号频率 = 761573Hz,实际估算频率 = 761572.937500
信号频率 = 763572Hz,实际估算频率 = 763572.062500
信号频率 = 765571Hz,实际估算频率 = 765571.000000
信号频率 = 767570Hz,实际估算频率 = 767570.000000
信号频率 = 769569Hz,实际估算频率 = 769569.000000
信号频率 = 771568Hz,实际估算频率 = 771567.937500
信号频率 = 773567Hz,实际估算频率 = 773567.000000
信号频率 = 775566Hz,实际估算频率 = 775566.000000
信号频率 = 777565Hz,实际估算频率 = 777565.000000
信号频率 = 779564Hz,实际估算频率 = 779563.937500
信号频率 = 781563Hz,实际估算频率 = 781562.937500
信号频率 = 783562Hz,实际估算频率 = 783562.000000
信号频率 = 785561Hz,实际估算频率 = 785560.937500
信号频率 = 787560Hz,实际估算频率 = 787560.000000
信号频率 = 789559Hz,实际估算频率 = 789558.937500
信号频率 = 791558Hz,实际估算频率 = 791558.000000
信号频率 = 793557Hz,实际估算频率 = 793557.000000
信号频率 = 795556Hz,实际估算频率 = 795555.937500
信号频率 = 797555Hz,实际估算频率 = 797555.000000
信号频率 = 799554Hz,实际估算频率 = 799554.000000
信号频率 = 801553Hz,实际估算频率 = 801553.000000
信号频率 = 803552Hz,实际估算频率 = 803552.000000
信号频率 = 805551Hz,实际估算频率 = 805550.937500
信号频率 = 807550Hz,实际估算频率 = 807550.000000
信号频率 = 809549Hz,实际估算频率 = 809549.000000
信号频率 = 811548Hz,实际估算频率 = 811548.000000
信号频率 = 813547Hz,实际估算频率 = 813546.937500
信号频率 = 815546Hz,实际估算频率 = 815545.937500
信号频率 = 817545Hz,实际估算频率 = 817545.000000
信号频率 = 819544Hz,实际估算频率 = 819543.937500
信号频率 = 821543Hz,实际估算频率 = 821543.000000
信号频率 = 823542Hz,实际估算频率 = 823541.937500
信号频率 = 825541Hz,实际估算频率 = 825541.000000
信号频率 = 827540Hz,实际估算频率 = 827540.000000
信号频率 = 829539Hz,实际估算频率 = 829538.937500
信号频率 = 831538Hz,实际估算频率 = 831537.937500
信号频率 = 833537Hz,实际估算频率 = 833537.000000
信号频率 = 835536Hz,实际估算频率 = 835536.000000
信号频率 = 837535Hz,实际估算频率 = 837534.937500
信号频率 = 839534Hz,实际估算频率 = 839533.937500
信号频率 = 841533Hz,实际估算频率 = 841533.000000
信号频率 = 843532Hz,实际估算频率 = 843531.937500
信号频率 = 845531Hz,实际估算频率 = 845531.000000
信号频率 = 847530Hz,实际估算频率 = 847529.937500
信号频率 = 849529Hz,实际估算频率 = 849528.937500
信号频率 = 851528Hz,实际估算频率 = 851528.000000
信号频率 = 853527Hz,实际估算频率 = 853526.937500
信号频率 = 855526Hz,实际估算频率 = 855526.000000
信号频率 = 857525Hz,实际估算频率 = 857524.937500
信号频率 = 859524Hz,实际估算频率 = 859524.000000
信号频率 = 861523Hz,实际估算频率 = 861523.000000
信号频率 = 863522Hz,实际估算频率 = 863521.937500
信号频率 = 865521Hz,实际估算频率 = 865520.937500
信号频率 = 867520Hz,实际估算频率 = 867519.937500
信号频率 = 869519Hz,实际估算频率 = 869519.000000
信号频率 = 871518Hz,实际估算频率 = 871517.937500
信号频率 = 873517Hz,实际估算频率 = 873516.937500
信号频率 = 875516Hz,实际估算频率 = 875515.937500
信号频率 = 877515Hz,实际估算频率 = 877514.937500
信号频率 = 879514Hz,实际估算频率 = 879514.000000
信号频率 = 881513Hz,实际估算频率 = 881512.937500
信号频率 = 883512Hz,实际估算频率 = 883512.000000
信号频率 = 885511Hz,实际估算频率 = 885511.000000
信号频率 = 887510Hz,实际估算频率 = 887509.937500
信号频率 = 889509Hz,实际估算频率 = 889508.937500
信号频率 = 891508Hz,实际估算频率 = 891507.937500
信号频率 = 893507Hz,实际估算频率 = 893507.000000
信号频率 = 895506Hz,实际估算频率 = 895505.937500
信号频率 = 897505Hz,实际估算频率 = 897504.937500
信号频率 = 899504Hz,实际估算频率 = 899503.937500
信号频率 = 901503Hz,实际估算频率 = 901502.937500
信号频率 = 903502Hz,实际估算频率 = 903502.000000
信号频率 = 905501Hz,实际估算频率 = 905500.937500
信号频率 = 907500Hz,实际估算频率 = 907499.937500
信号频率 = 909499Hz,实际估算频率 = 909498.937500
信号频率 = 911498Hz,实际估算频率 = 911497.937500
信号频率 = 913497Hz,实际估算频率 = 913497.000000
信号频率 = 915496Hz,实际估算频率 = 915495.937500
信号频率 = 917495Hz,实际估算频率 = 917494.937500
信号频率 = 919494Hz,实际估算频率 = 919494.000000
信号频率 = 921493Hz,实际估算频率 = 921492.937500
信号频率 = 923492Hz,实际估算频率 = 923491.937500
信号频率 = 925491Hz,实际估算频率 = 925490.937500
信号频率 = 927490Hz,实际估算频率 = 927490.000000
信号频率 = 929489Hz,实际估算频率 = 929488.937500
信号频率 = 931488Hz,实际估算频率 = 931487.937500
信号频率 = 933487Hz,实际估算频率 = 933486.937500
信号频率 = 935486Hz,实际估算频率 = 935485.875000
信号频率 = 937485Hz,实际估算频率 = 937485.000000
信号频率 = 939484Hz,实际估算频率 = 939483.937500
信号频率 = 941483Hz,实际估算频率 = 941482.875000
信号频率 = 943482Hz,实际估算频率 = 943481.937500
信号频率 = 945481Hz,实际估算频率 = 945480.875000
信号频率 = 947480Hz,实际估算频率 = 947479.937500
信号频率 = 949479Hz,实际估算频率 = 949478.937500
信号频率 = 951478Hz,实际估算频率 = 951477.937500
信号频率 = 953477Hz,实际估算频率 = 953476.875000
信号频率 = 955476Hz,实际估算频率 = 955475.937500
信号频率 = 957475Hz,实际估算频率 = 957474.937500
信号频率 = 959474Hz,实际估算频率 = 959473.937500
信号频率 = 961473Hz,实际估算频率 = 961472.937500
信号频率 = 963472Hz,实际估算频率 = 963471.875000
信号频率 = 965471Hz,实际估算频率 = 965470.937500
信号频率 = 967470Hz,实际估算频率 = 967469.937500
信号频率 = 969469Hz,实际估算频率 = 969468.875000
信号频率 = 971468Hz,实际估算频率 = 971467.937500
信号频率 = 973467Hz,实际估算频率 = 973466.937500
信号频率 = 975466Hz,实际估算频率 = 975465.937500
信号频率 = 977465Hz,实际估算频率 = 977464.937500
信号频率 = 979464Hz,实际估算频率 = 979463.937500
信号频率 = 981463Hz,实际估算频率 = 981463.000000
信号频率 = 983462Hz,实际估算频率 = 983462.062500
信号频率 = 985461Hz,实际估算频率 = 985461.125000
信号频率 = 987460Hz,实际估算频率 = 987460.250000
信号频率 = 989459Hz,实际估算频率 = 989459.500000
信号频率 = 991458Hz,实际估算频率 = 991459.250000
信号频率 = 993457Hz,实际估算频率 = 993459.812500
信号频率 = 995456Hz,实际估算频率 = 997070.312500
信号频率 = 997455Hz,实际估算频率 = 999023.437500
信号频率 = 999454Hz,实际估算频率 = 999023.437500
发表于 2025-12-19 07:14:07 | 显示全部楼层
计算频率也是采用FFT算法算出来的吗,最后3个频率点误差相对来说比较大,而且997455Hz怎么跟999454Hz测出来一样,是不是弄错了。
 楼主| 发表于 2025-12-19 10:14:12 | 显示全部楼层
gnail092 发表于 2025-12-19 07:14
计算频率也是采用FFT算法算出来的吗,最后3个频率点误差相对来说比较大,而且997455Hz怎么跟999454Hz测出来 ...
这里完全没问题,2M采样率采集接近1M频率波形,估算意义已经不大了,一个周期才两个点,采集的波形已经严重畸形了
此时提升示波器采样率,设置为5M采样即可。
新版的算法我搞了个混合估算实现。
设置到5M后,这几个值的估算
信号频率 = 983462Hz,实际估算频率 = 983462.062500Hz
信号频率 = 985461Hz,实际估算频率 = 985461.000000Hz
信号频率 = 987460Hz,实际估算频率 = 987460.062500Hz
信号频率 = 989459Hz,实际估算频率 = 989459.062500Hz
信号频率 = 991458Hz,实际估算频率 = 991458.062500Hz
信号频率 = 993457Hz,实际估算频率 = 993457.062500Hz
信号频率 = 995456Hz,实际估算频率 = 995456.062500Hz
信号频率 = 997455Hz,实际估算频率 = 997455.062500Hz
信号频率 = 999454Hz,实际估算频率 = 999454.125000Hz
发表于 2025-12-19 14:21:16 | 显示全部楼层
可以分享下频率估算算法吗?
 楼主| 发表于 2025-12-20 09:50:02 | 显示全部楼层
flair0626 发表于 2025-12-19 14:21
可以分享下频率估算算法吗?
DSP教程的FFT章节可以看下,就是精度一般,可以参考。
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=94547
发表于 2025-12-20 15:38:36 | 显示全部楼层
期待成品早日发布
GMT+8, 2026-10-25 11:05 , Processed in 0.448052 second(s), 28 queries .
