查看: 615|回复: 1
[Flash] STM32H743写FLASH时间测试
发表于 2025-11-13 11:49:07 | 显示全部楼层 |阅读模式
FLASH读写驱动程序:
#include "flash_drive.h"
#include <string.h>
*        函 数 名: bsp_GetSector
*        功能说明: 根据地址计算扇区首地址
*        形    参: 无
*        返 回 值: 扇区号(0-7)
uint32_t bsp_GetSector(uint32_t Address)
    uint32_t sector = 0;
    if (((Address < ADDR_FLASH_SECTOR_1_BANK1) && (Address >= ADDR_FLASH_SECTOR_0_BANK1)) ||
        ((Address < ADDR_FLASH_SECTOR_1_BANK2) && (Address >= ADDR_FLASH_SECTOR_0_BANK2)))
        sector = FLASH_SECTOR_0;
    else if (((Address < ADDR_FLASH_SECTOR_2_BANK1) && (Address >= ADDR_FLASH_SECTOR_1_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_2_BANK2) && (Address >= ADDR_FLASH_SECTOR_1_BANK2)))
        sector = FLASH_SECTOR_1;
    else if (((Address < ADDR_FLASH_SECTOR_3_BANK1) && (Address >= ADDR_FLASH_SECTOR_2_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_3_BANK2) && (Address >= ADDR_FLASH_SECTOR_2_BANK2)))
        sector = FLASH_SECTOR_2;
    else if (((Address < ADDR_FLASH_SECTOR_4_BANK1) && (Address >= ADDR_FLASH_SECTOR_3_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_4_BANK2) && (Address >= ADDR_FLASH_SECTOR_3_BANK2)))
        sector = FLASH_SECTOR_3;
    else if (((Address < ADDR_FLASH_SECTOR_5_BANK1) && (Address >= ADDR_FLASH_SECTOR_4_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_5_BANK2) && (Address >= ADDR_FLASH_SECTOR_4_BANK2)))
        sector = FLASH_SECTOR_4;
    else if (((Address < ADDR_FLASH_SECTOR_6_BANK1) && (Address >= ADDR_FLASH_SECTOR_5_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_6_BANK2) && (Address >= ADDR_FLASH_SECTOR_5_BANK2)))
        sector = FLASH_SECTOR_5;
    else if (((Address < ADDR_FLASH_SECTOR_7_BANK1) && (Address >= ADDR_FLASH_SECTOR_6_BANK1)) ||
             ((Address < ADDR_FLASH_SECTOR_7_BANK2) && (Address >= ADDR_FLASH_SECTOR_6_BANK2)))
        sector = FLASH_SECTOR_6;
    else if (((Address < ADDR_FLASH_SECTOR_0_BANK2) && (Address >= ADDR_FLASH_SECTOR_7_BANK1)) ||
             ((Address < CPU_FLASH_END_ADDR) && (Address >= ADDR_FLASH_SECTOR_7_BANK2)))
        sector = FLASH_SECTOR_7;
    return sector;
*        函 数 名: bsp_ReadCpuFlash
*        功能说明: 读取CPU Flash的内容
*        形    参:  _ucpDst : 目标缓冲区
*                         _ulFlashAddr : 起始地址
*                         _ulSize : 数据大小(单位是字节)
*        返 回 值: 0=成功,1=失败
uint8_t bsp_ReadCpuFlash(uint32_t _ulFlashAddr, uint8_t *_ucpDst, uint32_t _ulSize)
    uint32_t i;
    if (_ulFlashAddr + _ulSize > CPU_FLASH_BASE_ADDR + CPU_FLASH_SIZE)
        return 1;
    /* 长度为0时不继续操作,否则起始地址为奇地址会出错 */
    if (_ulSize == 0)
        return 1;
    for (i = 0; i < _ulSize; i++)
        *_ucpDst++ = *(uint8_t *)_ulFlashAddr++;
    return 0;
*        函 数 名: bsp_CmpCpuFlash
*        功能说明: 比较Flash指定地址的数据.
*        形    参: _ulFlashAddr : Flash地址
*                         _ucpBuf : 数据缓冲区
*        返 回 值:
*                        FLASH_IS_EQU                0   Flash内容和待写入的数据相等,不需要擦除和写操作
*                        FLASH_REQ_WRITE                1        Flash不需要擦除,直接写
*                        FLASH_REQ_ERASE                2        Flash需要先擦除,再写
*                        FLASH_PARAM_ERR                3        函数参数错误
uint8_t bsp_CmpCpuFlash(uint32_t _ulFlashAddr, uint8_t *_ucpBuf, uint32_t _ulSize)
    uint32_t i;
    uint8_t  ucIsEqu; /* 相等标志 */
    uint8_t  ucByte;
    /* 如果偏移地址超过芯片容量,则不改写输出缓冲区 */
        return FLASH_PARAM_ERR; /* 函数参数错误 */
    /* 长度为0时返回正确 */
    if (_ulSize == 0)
        return FLASH_IS_EQU; /* Flash内容和待写入的数据相等 */
    ucIsEqu = 1; /* 先假设所有字节和待写入的数据相等,如果遇到任何一个不相等,则设置为 0 */
        ucByte = *(uint8_t *)_ulFlashAddr;
        if (ucByte != *_ucpBuf)
            if (ucByte != 0xFF)
                return FLASH_REQ_ERASE; /* 需要擦除后再写 */
                ucIsEqu = 0; /* 不相等,需要写 */
        _ulFlashAddr++;
        _ucpBuf++;
    if (ucIsEqu == 1)
        return FLASH_IS_EQU; /* Flash内容和待写入的数据相等,不需要擦除和写操作 */
        return FLASH_REQ_WRITE; /* Flash不需要擦除,直接写 */
*        函 数 名: bsp_EraseCpuFlash
*        功能说明: 擦除CPU FLASH一个扇区 (128KB)
*        形    参: _ulFlashAddr : Flash地址      _ulSize : Flash大小
*        返 回 值: 0 成功, 1 失败
*                          HAL_OK       = 0x00,
*                          HAL_ERROR    = 0x01,
*                          HAL_BUSY     = 0x02,
*                          HAL_TIMEOUT  = 0x03
uint8_t bsp_EraseCpuFlash(uint32_t _ulFlashAddr, uint32_t _ulSize)
    uint32_t               FirstSector = 0, NbOfSectors = 0, EndSector = 0;
    FLASH_EraseInitTypeDef EraseInitStruct;
    uint32_t               SECTORError = 0;
    uint8_t                re;
    /* 长度为0时不继续操作  */
    if (_ulSize == 0)
        return 0;
    /* 解锁 */
    HAL_FLASH_Unlock();
    /* 获取此地址所在的扇区 */
    FirstSector                  = bsp_GetSector(_ulFlashAddr);
    // 获取此地址结束所在的扇区
    EndSector                    = bsp_GetSector(_ulFlashAddr + _ulSize - 1);
    /* 擦除扇区数量 */
    NbOfSectors                  = EndSector - FirstSector + 1;
    /* 擦除扇区配置 */
    EraseInitStruct.TypeErase    = FLASH_TYPEERASE_SECTORS;
    EraseInitStruct.VoltageRange = FLASH_VOLTAGE_RANGE_3;
    if (_ulFlashAddr >= ADDR_FLASH_SECTOR_0_BANK2)
        EraseInitStruct.Banks = FLASH_BANK_2;
        EraseInitStruct.Banks = FLASH_BANK_1;
    EraseInitStruct.Sector    = FirstSector;
    EraseInitStruct.NbSectors = NbOfSectors;
    /* 扇区擦除 */
    re                        = HAL_FLASHEx_Erase(&EraseInitStruct, &SECTORError);
    /* 擦除完毕后,上锁 */
    HAL_FLASH_Lock();
    return re;
*        函 数 名: bsp_WriteCpuFlash
*        功能说明: 写数据到CPU 内部Flash。 必须按32字节整数倍写。不支持跨扇区。扇区大小128KB. \
*                          写之前需要擦除扇区. 长度不是32字节整数倍时,最后几个字节末尾补0写入.
*                         _ucpSrc : 数据缓冲区
*                         _ulSize : 数据大小(单位是字节, 必须是32字节整数倍)
*        返 回 值: 0-成功,1-数据长度或地址溢出,2-写Flash出错(估计Flash寿命到)
uint8_t bsp_WriteCpuFlash(uint32_t _ulFlashAddr, uint8_t *_ucpSrc, uint32_t _ulSize)
    uint32_t i;
    uint8_t  ucRet;
        return 1;
    /* 长度为0时不继续操作  */
    if (_ulSize == 0)
        return 0;
    ucRet = bsp_CmpCpuFlash(_ulFlashAddr, _ucpSrc, _ulSize);
    if (ucRet == FLASH_IS_EQU)
        return 0;
    __set_PRIMASK(1); /* 关中断 */
    //擦除扇区
    bsp_EraseCpuFlash(_ulFlashAddr, _ulSize);
    /* FLASH 解锁 */
    HAL_FLASH_Unlock();
    for (i = 0; i < _ulSize / 32; i++)
        uint64_t FlashWord[4];
        memcpy((char *)FlashWord, _ucpSrc, 32);
        _ucpSrc += 32;
        if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_FLASHWORD, _ulFlashAddr, (uint64_t)((uint32_t)FlashWord)) == HAL_OK)
            _ulFlashAddr = _ulFlashAddr + 32; /* 递增,操作下一个256bit */
            goto err;
    /* 长度不是32字节整数倍 */
    if (_ulSize % 32)
        FlashWord[0] = 0;
        FlashWord[1] = 0;
        FlashWord[2] = 0;
        FlashWord[3] = 0;
        memcpy((char *)FlashWord, _ucpSrc, _ulSize % 32);
            ; // _ulFlashAddr = _ulFlashAddr + 32;
            goto err;
    /* Flash 加锁,禁止写Flash控制寄存器 */
    HAL_FLASH_Lock();
    __set_PRIMASK(0); /* 开中断 */
    return 0;
err:
    HAL_FLASH_Lock();
    return 1;
写FLASH程序,只使用到一个扇区:
EEPROM_Write(ADDR_FLASH_SECTOR_4_BANK1, (uint8_t *)&holding_reg.sys_param, sizeof(sys_param_t));
使用IO测试FLASH擦除读写一个扇区时间居然差不多要1秒
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_2, GPIO_PIN_SET);
EEPROM_Write(0, (uint8_t *)&holding_reg.sys_param, sizeof(sys_param_t));
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_2, GPIO_PIN_RESET);
同时也使用到DWT测试程序运行时间的方法测试时间
uint32_t start_ticks, end_ticks, cycle_count;
float    time_us;
start_ticks                 = DWT->CYCCNT;
end_ticks = DWT->CYCCNT;
cycle_count = end_ticks - start_ticks;
time_us = ((float)cycle_count * 1000000.0f) / (float)SystemCoreClock;
测量的时间差不多
逻辑分析仪测量时间
逻辑分析仪测量时间
DWT测量时间
DWT测量时间
发表于 2025-11-13 15:02:32 | 显示全部楼层
差不多,基本1-4秒
GMT+8, 2026-10-24 11:03 , Processed in 0.156438 second(s), 28 queries .
