查看: 627|回复: 1
[其它] 汇顶科技gt917s的触摸屏驱动芯片配置怎么写
发表于 2025-10-29 11:19:32 | 显示全部楼层 |阅读模式
uint8_t CTP_CFG_GT917S[] ={
  0x97,0x20,0x03,0xE0,0x01,0x0A,0x35,0x04,0x00,0x69,
  0x09,0x0F,0x50,0x32,0x33,0x11,0x00,0x32,0x11,0x11,
  0x28,0x8C,0xAA,0xDC,0x58,0x04,0x00,0x00,0x1E,0x3C,
  0x00,0x00,0x00,0x31,0x00,0x00,0x00,0x00,0x00,0x40,
  0x32,0x00,0x00,0x50,0x38,0x00,0x8D,0x20,0x16,0x4E,
  0x4C,0x7C,0x05,0x28,0x3E,0x28,0x0D,0x43,0x24,0x00,
  0x01,0x39,0x6B,0xC0,0x94,0x84,0x2D,0x00,0x54,0xB0,
  0x41,0x9D,0x49,0x8D,0x52,0x7F,0x5A,0x75,0x62,0x6C,
  0x42,0x50,0x14,0x00,0x00,0x00,0x00,0xF0,0x50,0x3C,
  0x88,0x88,0x27,0x50,0x3C,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x00,0x02,0x78,
  0x0A,0x50,0xFF,0xE4,0x04,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x3C,0xB0,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x56,0xA2,0x07,0x50,0x1E,
  0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,
  0x0F,0x10,0x12,0x15,0x16,0x17,0x18,0x19,0x1A,0x1B,
  0x1D,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  0xFF,0xFF,0x1F,0x1E,0x1D,0x1C,0x1B,0x1A,0x19,0x18,
  0x17,0x15,0x14,0x13,0x12,0xFF,0xFF,0xFF,0xFF,0xFF,
  0xFF,0xFF,0xFF,0xFF,0x00,0x30,0x7F,0x7F,0x7F,0xFF,
  0x54,0x64,0x00,0x80,0x46,0x07,0x50,0x3C,0x32,0x14,
  0x0A,0x64,0x32,0x00,0x00,0x00,0x00,0x11,0x02,0x62,
  0x32,0x03,0x14,0x50,0x0C,0xE2,0x14,0x50,0x00,0x54,
  0x10,0x00,0x32,0xA2,0x07,0x64,0xA4,0xB6,0x01
};这是网上找的例程上面的数组,手册上说A4B6 是配置位的校验求和,我怎么都求不出这个结果,想该一下这个配置都改不了
发表于 2025-10-29 12:12:16 | 显示全部楼层
帮顶,只配置过GT811的寄存器,后来到GT911直接用现成的了,没有再配置了。
GMT+8, 2026-10-24 12:14 , Processed in 0.141199 second(s), 25 queries .
