查看: 342|回复: 1
[ThreadX全家桶] USBX PIMA MTP
发表于 2025-10-21 17:53:28 | 显示全部楼层 |阅读模式
使用USBX PIMA MTP ,PC端可以发现单片机的盘符。
通过以下代码只能发现默认目录下面的文件
/* Get the first directory entry in the default directory with full information */
  status = fx_directory_first_full_entry_find(&mmc_disk, file_name, &attributes, &size,
                                              &year, &month, &day, &hour, &minute, &second);
  while (status == FX_SUCCESS)
    if ((attributes == FX_DIRECTORY) || (attributes == FX_ARCHIVE ))
      /* Increment total object number counter */
      object_handles_counter += 1;
      /* Set handle info */
      Object_SetHandleInfo(&object_handle_index_num, file_name, size);
      /* Reset file name array */
      _fx_utility_memory_set((UCHAR*)file_name, 0, FX_MAX_LONG_NAME_LEN);
    /* Get the next directory entry in the default directory with full information */
    status = fx_directory_next_full_entry_find(&mmc_disk, file_name, &attributes, &size,
PC端怎么发现盘符下的所有文件,文件夹等信息
发表于 2025-10-22 12:21:17 | 显示全部楼层
帮顶,这个没有研究过
GMT+8, 2026-1-12 14:34 , Processed in 0.039674 second(s), 24 queries .
