查看: 1047|回复: 9
[ADC] STM32H743IIT6 + SDRAM + AD9226 Oscilloscope
发表于 2025-10-14 05:07:48 | 显示全部楼层 |阅读模式
Hello.
My name is Bogdan, I am from Romania.
I searched on internet for a simple yet powerful oscilloscope that I can embed in one of the products we use at our company.
We need to read and store 6 channels at >=40MHz, and store 32MB samples for each channel.
All the acquisition must start simultaneous by an external trigger.
I had try to use STM32H743IIT6 + SDRAM (FANKE Board) and an ADC AD9226, to create a simple oscilloscope, but I can not manage to make it work.
If someone have a sollution for this please contact me at nbogdan.contact@gmail.com
 楼主| 发表于 2025-10-14 05:12:59 | 显示全部楼层
Here is what I am trying to do by now. But even if the nodes of the MDMA are configured and the DCMI get the HSYNC/VSYNC, the acquisition never starts.
The MDMA does not get triggered by the DCMI.
In the last ST HAL, on the MDMA, there is no MDMD_REQUEST_DCMI???
Can someone please point me in the right direction, how I can read continous DCMI data and store to SDRAM, what is
a good approach?
Read first in a buffer using DMA, and move the buffer to SDRAM using MDMA???
main.c
39.84 KB, 下载次数: 4
发表于 2025-10-14 09:16:57 | 显示全部楼层
可以考虑使用STM32H72X或者STM32H73x跟更合适。
STM32H730/H725带的高速并行同步接口PSSI可玩性很高,可以支持高达110MHz的数据采集
https://forum.anfulai.cn/forum.p ... 4656&fromuid=58
 楼主| 发表于 2025-10-14 16:04:06 | 显示全部楼层
STM32H730/H725带的高速并行同步接口PSSI可玩性很高,可 ...
Thank you for pointing me PSSI. I did see that you sell an oscilloscope. Can your module be chained to get 6 channels. I need 40MHz minimum acquisition speed. We are building a device that need to sample simultaneously 6 signals, as much as possible data (50Hz signal, minimum 4 full periods at 40Msamples/sec, 12 bit or 14 bit).
 楼主| 发表于 2025-10-15 05:25:21 | 显示全部楼层
I did purchase from Aliexpress few STM32H723ZGT6 and few W9825G6KH-6I SDRAM. I will make a PCB, and start testing. I will post the PCB here when ready.
Can you please tell me something more regarding data acquisition using PSSI. I don't need DE and RDY for AD9226. Did you test using this ADC???
Some user in this forum say that he has encounter data corruption:
https://forum.anfulai.cn/forum.php?mod=redirect&goto=findpost&ptid=104656&pid=307445&fromuid=95246
Xie Xie!
发表于 2025-10-15 10:06:22 | 显示全部楼层
12358132134 发表于 2025-10-15 05:25
I did purchase from Aliexpress few STM32H723ZGT6 and few W9825G6KH-6I SDRAM. I will make a PCB, and  ...
暂时我们这边没有这方面的代码应用。
 楼主| 发表于 2025-10-24 04:21:11 | 显示全部楼层
Can you please send me the pdf from:
https://bbs.21ic.com/icview-3433070-1-1.html
From my country I can not make an account.
Thank you!
发表于 2025-10-24 15:53:04 | 显示全部楼层
不看国家,还以为是大鹅家的王牌飞行员博格丹呢。我发给你吧
发表于 2025-10-24 15:53:48 | 显示全部楼层
我帮你下了
慧勤智远STM32H723ZGT6 V10.pdf
815.17 KB, 下载次数: 27
 楼主| 发表于 2025-10-28 04:50:43 | 显示全部楼层
Thank you for your effort!
Any further advancement I make, I will post all schematics and code, here!
GMT+8, 2026-10-24 11:30 , Processed in 0.348642 second(s), 27 queries .
