查看: 602|回复: 0
[RTOS] RTX5的任务栈最大使用情况使用函数osThreadGetStackSpace获取
发表于 2025-10-12 10:19:56 | 显示全部楼层 |阅读模式
当前使用情况需要手动判断,最大使用情况,使用这个函数即可
osThreadGetStackSpace最终是调用的函数svcRtxThreadGetStackSpace
/// Get available stack space of a thread based on stack watermark recording during execution.
/// \note API identical to osThreadGetStackSpace
static uint32_t svcRtxThreadGetStackSpace (osThreadId_t thread_id) {
  os_thread_t    *thread = osRtxThreadId(thread_id);
  const uint32_t *stack;
        uint32_t  space;
  // Check parameters
  if ((thread == NULL) || (thread->id != osRtxIdThread)) {
    EvrRtxThreadGetStackSpace(thread, 0U);
    //lint -e{904} "Return statement before end of function" [MISRA Note 1]
    return 0U;
  // Check if stack watermark is not enabled
  if ((osRtxConfig.flags & osRtxConfigStackWatermark) == 0U) {
    return 0U;
  //lint -e{9079} "conversion from pointer to void to pointer to other type"
  stack = thread->stack_mem;
  if (*stack++ == osRtxStackMagicWord) {
    for (space = 4U; space < thread->stack_size; space += 4U) {
      if (*stack++ != osRtxStackFillPattern) {
  } else {
    space = 0U;
  EvrRtxThreadGetStackSpace(thread, space);
  return space;
GMT+8, 2026-10-24 11:32 , Processed in 0.224464 second(s), 24 queries .
