查看: 641|回复: 2
[技术讨论] STM32L431,PWM与输入捕获的问题
发表于 2025-10-10 17:35:00 | 显示全部楼层 |阅读模式
如果发送两次会出现图片问题,并且输入捕获,捕获不到频率
        Send12Pulses_SingleCh(TIM_CHANNEL_1);
        bsp_DelayUS(70);
#include "bsp.h"
TIM_HandleTypeDef htim1;
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim6;
/*PWM控制参数*/
// 目标脉冲数量
#define TARGET_PULSES 12
// 脉冲发送状态
uint8_t pulse_sending = 0;
/*输入捕获参数*/
__IO uint16_t IC2Value = 0;
__IO uint16_t IC1Value = 0;
__IO float DutyCycle = 0;
__IO float Frequency = 0;
/* TIM1 init function */
void MX_TIM1_Init(void)
  /* USER CODE BEGIN TIM1_Init 0 */
  /* USER CODE END TIM1_Init 0 */
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  TIM_OC_InitTypeDef sConfigOC = {0};
  TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  /* USER CODE BEGIN TIM1_Init 1 */
  /* USER CODE END TIM1_Init 1 */
  htim1.Instance = TIM1;
  htim1.Init.Prescaler = 0;
  htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim1.Init.Period = 399;
  htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim1.Init.RepetitionCounter = 0;
  htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
  if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
    Error_Handler();
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 80;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
    Error_Handler();
//  sConfigOC.Pulse = 3;
  if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
//  sConfigOC.Pulse = 2;
  if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
    Error_Handler();
  sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  sBreakDeadTimeConfig.DeadTime = 0;
  sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  sBreakDeadTimeConfig.BreakFilter = 0;
  sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
  sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
  sBreakDeadTimeConfig.Break2Filter = 0;
  sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM1_Init 2 */
  //使能更新中断
//  __HAL_TIM_ENABLE_IT(&htim1, TIM_IT_UPDATE);
  /* USER CODE END TIM1_Init 2 */
  HAL_TIM_MspPostInit(&htim1);
/* TIM2 init function */
void MX_TIM2_Init(void)
  /* USER CODE BEGIN TIM2_Init 0 */
  /* USER CODE END TIM2_Init 0 */
  TIM_SlaveConfigTypeDef sSlaveConfig = {0};
  TIM_IC_InitTypeDef sConfigIC = {0};
  /* USER CODE BEGIN TIM2_Init 1 */
  /* USER CODE END TIM2_Init 1 */
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 0;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 65535;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_IC_Init(&htim2) != HAL_OK)
    Error_Handler();
  sSlaveConfig.SlaveMode = TIM_SLAVEMODE_RESET;
  sSlaveConfig.InputTrigger = TIM_TS_TI1FP1;
  sSlaveConfig.TriggerPolarity = TIM_INPUTCHANNELPOLARITY_RISING;
  sSlaveConfig.TriggerFilter = 0;
  if (HAL_TIM_SlaveConfigSynchro(&htim2, &sSlaveConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
  sConfigIC.ICPolarity = TIM_INPUTCHANNELPOLARITY_RISING;
  sConfigIC.ICSelection = TIM_ICSELECTION_DIRECTTI;
  sConfigIC.ICPrescaler = TIM_ICPSC_DIV1;
  sConfigIC.ICFilter = 0;
  if (HAL_TIM_IC_ConfigChannel(&htim2, &sConfigIC, TIM_CHANNEL_1) != HAL_OK)
    Error_Handler();
  sConfigIC.ICPolarity = TIM_INPUTCHANNELPOLARITY_FALLING;
  sConfigIC.ICSelection = TIM_ICSELECTION_INDIRECTTI;
  if (HAL_TIM_IC_ConfigChannel(&htim2, &sConfigIC, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM2_Init 2 */
  /* USER CODE END TIM2_Init 2 */
/* TIM6 init function:周期=12个PWM脉冲总时间,仅中断1次 */
void MX_TIM6_Init(void)
  /* USER CODE BEGIN TIM6_Init 1 */
  // 关键配置依据:
  // TIM1单个PWM周期 = (399+1)/160e6 = 2.5μs
  // TIM6目标周期 = 12 × 2.5μs = 30μs
  // TIM6计数值 = 30μs × 160e6 = 4800 → Period = 4800 - 1 = 4799
  /* USER CODE END TIM6_Init 1 */
  htim6.Instance = TIM6;
  htim6.Init.Prescaler = 0;                  // 与TIM1一致,避免时钟偏差
  htim6.Init.CounterMode = TIM_COUNTERMODE_UP;// 向上计数
  htim6.Init.Period = 4799;                  // 核心:周期=30μs(12个PWM总时间)
  htim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE; // 使能自动重装
  if (HAL_TIM_Base_Init(&htim6) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; // 禁用触发输出(无需同步)
  if (HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM6_Init 2 */
  __HAL_TIM_ENABLE_IT(&htim6, TIM_IT_UPDATE); // 使能TIM6更新中断(仅1次触发)
  /* USER CODE END TIM6_Init 2 */
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* tim_baseHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(tim_baseHandle->Instance==TIM1)
  /* USER CODE BEGIN TIM1_MspInit 0 */
  /* USER CODE END TIM1_MspInit 0 */
    /* TIM1 clock enable */
    __HAL_RCC_TIM1_CLK_ENABLE();
    /* TIM1 interrupt Init */
    HAL_NVIC_SetPriority(TIM1_UP_TIM16_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(TIM1_UP_TIM16_IRQn);
  /* USER CODE BEGIN TIM1_MspInit 1 */
  /* USER CODE END TIM1_MspInit 1 */
  else if(tim_baseHandle->Instance==TIM2)
  /* USER CODE BEGIN TIM2_MspInit 0 */
  /* USER CODE END TIM2_MspInit 0 */
    /* TIM2 clock enable */
    __HAL_RCC_TIM2_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /**TIM2 GPIO Configuration
    PA0     ------> TIM2_CH1
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Alternate = GPIO_AF1_TIM2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* TIM2 interrupt Init */
    HAL_NVIC_SetPriority(TIM2_IRQn, 2, 0);
    HAL_NVIC_EnableIRQ(TIM2_IRQn);
  /* USER CODE BEGIN TIM2_MspInit 1 */
  /* USER CODE END TIM2_MspInit 1 */
         else if(tim_baseHandle->Instance==TIM6)
    // TIM6(APB1)时钟使能(与TIM2同源,时钟=160MHz)
    __HAL_RCC_TIM6_CLK_ENABLE();
    // TIM6中断优先级低于TIM2(确保捕获不被干扰)
    HAL_NVIC_SetPriority(TIM6_DAC_IRQn, 3, 0);
    HAL_NVIC_EnableIRQ(TIM6_DAC_IRQn);
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* timHandle)
  if(timHandle->Instance==TIM1)
  /* USER CODE BEGIN TIM1_MspPostInit 0 */
  /* USER CODE END TIM1_MspPostInit 0 */
    /**TIM1 GPIO Configuration
    PA8     ------> TIM1_CH1
    PA9     ------> TIM1_CH2
    PA10     ------> TIM1_CH3
    PA11     ------> TIM1_CH4
    GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11;
    GPIO_InitStruct.Alternate = GPIO_AF1_TIM1;
  /* USER CODE BEGIN TIM1_MspPostInit 1 */
  /* USER CODE END TIM1_MspPostInit 1 */
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* tim_baseHandle)
  /* USER CODE BEGIN TIM1_MspDeInit 0 */
  /* USER CODE END TIM1_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_TIM1_CLK_DISABLE();
    /* TIM1 interrupt Deinit */
    HAL_NVIC_DisableIRQ(TIM1_UP_TIM16_IRQn);
  /* USER CODE BEGIN TIM1_MspDeInit 1 */
  /* USER CODE END TIM1_MspDeInit 1 */
  /* USER CODE BEGIN TIM2_MspDeInit 0 */
  /* USER CODE END TIM2_MspDeInit 0 */
    __HAL_RCC_TIM2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0);
    /* TIM2 interrupt Deinit */
    HAL_NVIC_DisableIRQ(TIM2_IRQn);
  /* USER CODE BEGIN TIM2_MspDeInit 1 */
  /* USER CODE END TIM2_MspDeInit 1 */
/* USER CODE BEGIN 1 */
void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
    if (htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)
      /* 获取输入捕获值 */
      IC1Value = HAL_TIM_ReadCapturedValue(&htim2,TIM_CHANNEL_1);
      IC2Value = HAL_TIM_ReadCapturedValue(&htim2,TIM_CHANNEL_2);
      if (IC1Value != 0)
                                /* 占空比计算:(高电平时间/周期)×100%
                                        注:+1是因为计数器从0开始计数(实际周期为计数值+1个时钟周期) */
                                DutyCycle = (float)(IC2Value + 1) / (IC1Value + 1) * 100;
                                /* 频率计算:定时器时钟频率 / 周期计数值
                                         配置中Prescaler=0,假设TIM2时钟为160MHz(需根据实际系统时钟调整) */
                                // 定时器时钟频率 = 系统时钟相关配置(例如APB1=80MHz时,TIM2时钟=160MHz)
                                Frequency = 80000000.0f / (IC1Value + 1);  // 单位:Hz
      DutyCycle = 0;
      Frequency = 0;
  * @brief  打印输入捕获的相关信息(周期、高电平时间、占空比、频率)
  * @param  None
  * @retval None
void Print_IC_Info(void)
//    HAL_Delay(5000);  // 延迟5秒
    // 打印捕获值
    printf("IC1Value = %d  IC2Value = %d ", IC1Value, IC2Value);
    // 打印占空比和频率
    printf("duty cycle=%0.2f%%   frequency=%0.2fHz\n", DutyCycle, Frequency);
  * @brief  所有通道输出12个PWM脉冲(TIM6一次中断即完成)
  * @retval None
void Send12Pulses(void)
  // 若正在发送,先停止(避免重复触发)
  if (pulse_sending)
    HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_1);
    HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_2);
    HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_3);
    HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_4);
    HAL_TIM_Base_Stop_IT(&htim6);
    pulse_sending = 0;
  // 标记为发送中
  pulse_sending = 1;
  // 修复第一个脉冲异常:CNT设为TIM1周期值,确保初始输出低电平
  TIM1->CNT = htim1.Init.Period;
  // 启动TIM6(仅1次中断,对应12个脉冲总时间)
  HAL_TIM_Base_Start_IT(&htim6);
  // 启动所有通道PWM输出
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
  HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3);
  HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_4); // 按需开启/关闭通道
  * @brief  单通道输出12个PWM脉冲(TIM6一次中断即完成)
  * @param  channel:目标通道(TIM_CHANNEL_1~4)
  * @retval None
void Send12Pulses_SingleCh(uint32_t channel)
  // 停止当前发送(避免冲突)
  if (pulse_sending)
    // 停止所有PWM通道
    for (uint32_t ch = TIM_CHANNEL_1; ch <= TIM_CHANNEL_4; ch++)
      HAL_TIM_PWM_Stop(&htim1, ch);
    pulse_sending = 0;
  // 标记发送状态
  pulse_sending = 1;
  // 修复第一个脉冲异常
  // 启动TIM6(1次中断=12个脉冲总时间)
  // 仅启动目标通道PWM
  HAL_TIM_PWM_Start(&htim1, channel);
  * @brief  定时器更新中断回调(仅处理TIM6,1次中断=12个脉冲)
  * @param  htim:定时器句柄
  * @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  // 仅响应TIM6的中断(1次中断对应12个脉冲总时间)
  if (htim->Instance == TIM6 && pulse_sending)
    // 1. 停止所有TIM1 PWM通道
    // 2. 停止TIM6(避免重复中断)
    // 3. 重置发送状态(方便下次调用)
    pulse_sending = 0;
    // (可选)添加发送完成后的回调逻辑(如置位标志、通知其他模块)
    // User_Callback_PulseSentComplete();
/* USER CODE END 1 */
 楼主| 发表于 2025-10-10 17:36:10 | 显示全部楼层
只发送一次  Send12Pulses_SingleCh(TIM_CHANNEL_1);
波形和输入捕获都没有问题
发表于 2025-10-11 09:53:56 | 显示全部楼层
波形和输入捕获都没有问题
改进下,使用DeInit函数做个复位,然后重新初始化试试正常不,
GMT+8, 2026-11-22 12:53 , Processed in 0.202920 second(s), 27 queries .
