查看: 813|回复: 2
[IAR] 讨论IAR EWARM IDE下支持的芯片列表很少有startup_devices_iar.s为什么呢?
发表于 2025-9-27 09:44:44 | 显示全部楼层 |阅读模式
在IAR开发环境可以找到连接,仿真和flashloader文件, 但大多数设备无启动文件。
很多时候需要找芯片原厂或自己修改启动文件。
如果把汇编的启动文件改成C文件来编译有什么缺点?
这是中微MCU的一个汇编启动文件startup_cms32m5xxx_iar.s
;* Copyright (C) 2019 China Micro Semiconductor Limited Company. All Rights Reserved.
;* This software is owned and published by:
;* CMS LLC, No 2609-10, Taurus Plaza, TaoyuanRoad, NanshanDistrict, Shenzhen, China.
;* BY DOWNLOADING, INSTALLING OR USING THIS SOFTWARE, YOU AGREE TO BE BOUND
;* BY ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
;* This software contains source code for use with CMS
;* components. This software is licensed by CMS to be adapted only
;* for use in systems utilizing cms components. CMS shall not be
;* responsible for misuse or illegal use of this software for devices not
;* supported herein. CMS is providing this software "AS IS" and will
;* not be responsible for issues arising from incorrect user implementation
;* of the software.
;* This software may be replicated in part or whole for the licensed use,
;* with the restriction that this Disclaimer and Copyright notice must be
;* included with each copy of this software, whether used in part or whole,
;* at all times.
;/*  Startup for IAR                                                          */
;/*  Version     V1.0                                                         */
;/*  Date        2018-04-15                                                   */
;/*  Target-mcu  M0+ Device                                                   */
                MODULE  ?cstartup
                ;; Forward declaration of sections.
                SECTION CSTACKATA:NOROOT(3)
                EXTERN  __iar_program_start
                EXTERN  SystemInit
                PUBLIC  __vector_table
                SECTION .intvec:CODE:ROOT(8)
                DATA
__vector_table  DCD     sfe(CSTACK)
                DCD     Reset_Handler
                DCD     NMI_Handler               ; NMI
                DCD     HardFault_Handler         ; Hard Fault
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     SVC_Handler               ; SVCall
                DCD     0                         ; Debug Monitor
                DCD     0                         ; Reserved
                DCD     PendSV_Handler            ; PendSV
                DCD     SysTick_Handler           ; SysTick
; Numbered IRQ handler vectors
; Note: renaming to device dependent ISR function names are done in
                DCD     GPIO0_IRQHandler        ;  0: GPIO P0 interrupt
                DCD     GPIO1_IRQHandler        ;  1: GPIO P1 interrupt
                DCD     GPIO2_IRQHandler        ;  2: GPIO P2 interrupt
                DCD     GPIO3_IRQHandler        ;  3: GPIO P3 interrupt
                DCD     GPIO4_IRQHandler               ;  4: GPIO P4 interrupt
                DCD     0                       ;  5: Reserved
                DCD     CCP_IRQHandler              ;  6: Capture/PWM interrupt
                DCD     ADC0_IRQHandler               ;  7: ADC 0 interrupt
                DCD     0                       ;  8: Reserved
                DCD     WWDT_IRQHandler         ;  9: WWDT interrupt
                DCD     EPWM_IRQHandler         ; 10: EPWM interrupt
                DCD     0                       ; 11: Reserved
                DCD     ADC1_IRQHandler         ; 12: ADC 1 interrupt
                DCD     ACMP_IRQHandler         ; 13: ACMP interrupt
                DCD     0                       ; 14: Reserved
                DCD     UART0_IRQHandler        ; 15: UART 0 interrupt
                DCD     UART1_IRQHandler        ; 16: UART 1 interrupt
                DCD     0                       ; 17: Reserved
                DCD     0                       ; 18: Reserved
                DCD     TMR0_IRQHandler             ; 19: TIMER 0 interrupt
                DCD     TMR1_IRQHandler         ; 20: TIMER 1 interrupt
                DCD     0                       ; 21: Reserved
                DCD     0                       ; 22: Reserved
                DCD     WDT_IRQHandler               ; 23: WDT  interrupt
                DCD     I2C_IRQHandler               ; 24: I2C  interrupt
                DCD     0                       ; 25: Reserved
                DCD     SPI_IRQHandler               ; 26: SPI interrupt
                DCD     0                       ; 27: Reserved
                DCD     0                       ; 28: Reserved
                DCD     0                       ; 29: Reserved
                DCD     0                       ; 30: Reserved
                DCD     LVD_IRQHandler               ; 31: LVD interrupt
                THUMB
                PUBWEAK Reset_Handler
                SECTION .text:CODE:NOROOT:REORDER(2)
Reset_Handler
                ;reset NVIC if in rom debug
                LDR     R0, =SystemInit
                BLX     R0
                LDR     R0, =__iar_program_start
                BX      R0
                PUBWEAK NMI_Handler
                SECTION .text:CODE:NOROOT:REORDER(1)
NMI_Handler
                B       NMI_Handler
                PUBWEAK HardFault_Handler
HardFault_Handler
                B       HardFault_Handler
                PUBWEAK SVC_Handler
SVC_Handler
                B       SVC_Handler
                PUBWEAK PendSV_Handler
PendSV_Handler
                B       PendSV_Handler
                PUBWEAK SysTick_Handler
SysTick_Handler
                B       SysTick_Handler
                PUBWEAK GPIO0_IRQHandler
GPIO0_IRQHandler
                B       GPIO0_IRQHandler
                PUBWEAK GPIO1_IRQHandler
GPIO1_IRQHandler
                B       GPIO1_IRQHandler
                PUBWEAK GPIO2_IRQHandler
GPIO2_IRQHandler
                B       GPIO2_IRQHandler
                PUBWEAK GPIO3_IRQHandler
GPIO3_IRQHandler
                B       GPIO3_IRQHandler
                PUBWEAK GPIO4_IRQHandler
GPIO4_IRQHandler
                B       GPIO4_IRQHandler
                PUBWEAK CCP_IRQHandler
CCP_IRQHandler
                B       CCP_IRQHandler
                PUBWEAK ADC0_IRQHandler
ADC0_IRQHandler
                B       ADC0_IRQHandler
                PUBWEAK WWDT_IRQHandler
WWDT_IRQHandler
                B       WWDT_IRQHandler
                PUBWEAK EPWM_IRQHandler
EPWM_IRQHandler
                B       EPWM_IRQHandler
                PUBWEAK ADC1_IRQHandler
ADC1_IRQHandler
                B       ADC1_IRQHandler
                PUBWEAK ACMP_IRQHandler
ACMP_IRQHandler
                B       ACMP_IRQHandler
                PUBWEAK UART0_IRQHandler
UART0_IRQHandler
                B       UART0_IRQHandler
                PUBWEAK UART1_IRQHandler
UART1_IRQHandler
                B       UART1_IRQHandler
                PUBWEAK TMR0_IRQHandler
TMR0_IRQHandler
                B       TMR0_IRQHandler
                PUBWEAK TMR1_IRQHandler
TMR1_IRQHandler
                B       TMR1_IRQHandler
                PUBWEAK WDT_IRQHandler
WDT_IRQHandler
                B       WDT_IRQHandler
                PUBWEAK I2C_IRQHandler
I2C_IRQHandler
                B       I2C_IRQHandler
                PUBWEAK SPI_IRQHandler
SPI_IRQHandler
                B       SPI_IRQHandler
                PUBWEAK LVD_IRQHandler
LVD_IRQHandler
                B       LVD_IRQHandler
                END
下面是我改C文件形式的启动文件startup_cms32m5xxx_iar.c,为什么很多情况下芯片厂商和软件公司不使用C替代汇编启动呢?在GCC开发中就有很多是C文件形式的启动文件。
#include <stdint.h>
#define __STACK_TOP  0x20002000   // 与 ICF 中保持一致
/* 外部符号声明 */
extern int main(void);
extern void SystemInit ( void );
extern void __iar_program_start(void);
/* 主启动函数 */
void Reset_Handler(void)
    SystemInit();
    // 调用库初始化
    __iar_program_start();
/* 弱定义默认中断处理 */
__attribute__((weak)) void NMI_Handler(void){ while(1); }
__attribute__((weak)) void HardFault_Handler(void){ while(1); }
__attribute__((weak)) void SVC_Handler(void){ while(1); }        /* -5 SVCall */
__attribute__((weak)) void PendSV_Handler(void){ while(1); }     /* -2 PendSV */
__attribute__((weak)) void SysTick_Handler(void){ while(1); }    /* -1 SysTick */
__attribute__((weak)) void GPIO0_IRQHandler(void){ while(1); }   /*  0: GPIO P0 interrupt */
__attribute__((weak)) void GPIO1_IRQHandler(void){ while(1); }   /*  1: GPIO P1 interrupt */
__attribute__((weak)) void GPIO2_IRQHandler(void){ while(1); }   /*  2: GPIO P2 interrupt */
__attribute__((weak)) void GPIO3_IRQHandler(void){ while(1); }   /*  3: GPIO P3 interrupt */
__attribute__((weak)) void GPIO4_IRQHandler(void){ while(1); }   /*  4: GPIO P4 interrupt */
__attribute__((weak)) void CCP_IRQHandler(void){ while(1); }     /*  6: Capture/PWM interrupt */
__attribute__((weak)) void ADC0_IRQHandler(void){ while(1); }    /*  7: ADC 0 interrupt */
__attribute__((weak)) void WWDT_IRQHandler(void){ while(1); }    /*  9: WWDT interrupt */
__attribute__((weak)) void EPWM_IRQHandler(void){ while(1); }    /* 10: EPWM interrupt */
__attribute__((weak)) void ADC1_IRQHandler(void){ while(1); }    /* 12: ADC 1 interrupt */
__attribute__((weak)) void ACMP_IRQHandler(void){ while(1); }    /* 13: ACMP interrupt */
__attribute__((weak)) void UART0_IRQHandler(void){ while(1); }   /* 15: UART 0 interrupt */
__attribute__((weak)) void UART1_IRQHandler(void){ while(1); }   /* 16: UART 1 interrupt */
__attribute__((weak)) void TMR0_IRQHandler(void){ while(1); }    /* 19: TIMER 0 interrupt */
__attribute__((weak)) void TMR1_IRQHandler(void){ while(1); }    /* 20: TIMER 1 interrupt */
__attribute__((weak)) void WDT_IRQHandler(void){ while(1); }     /* 23: WDT  interrupt */
__attribute__((weak)) void I2C_IRQHandler(void){ while(1); }     /* 24: I2C  interrupt */
__attribute__((weak)) void SPI_IRQHandler(void){ while(1); }     /* 26: SPI interrupt */
__attribute__((weak)) void LVD_IRQHandler(void){ while(1); }     /* 31: LVD interrupt */
/* 向量表定义 */
__attribute__((section(".intvec")))
__root const uint32_t __vector_table[] =
    (uint32_t)__STACK_TOP,   /* -16 初始栈指针 */
    (uint32_t) Reset_Handler,      /* -15 复位处理函数 */
    (uint32_t) NMI_Handler,        /* -14 NMI */
    (uint32_t) HardFault_Handler,  /* -13 Hard Fault */
    0,                             /* -12 Reserved */
    0,                             /* -11 Reserved */
    0,                             /* -10 Reserved */
    0,                             /* -9 Reserved */
    0,                             /* -8 Reserved */
    0,                             /* -7 Reserved */
    0,                             /* -6 Reserved */
    (uint32_t) SVC_Handler,        /* -5 SVCall */
    0,                             /* -4 Debug Monitor */
    0,                             /* -3 Reserved */
    (uint32_t) PendSV_Handler,     /* -2 PendSV */
    (uint32_t) SysTick_Handler,    /* -1 SysTick */
    (uint32_t) GPIO0_IRQHandler,   /*  0: GPIO P0 interrupt */
    (uint32_t) GPIO1_IRQHandler,   /*  1: GPIO P1 interrupt */
    (uint32_t) GPIO2_IRQHandler,   /*  2: GPIO P2 interrupt */
    (uint32_t) GPIO3_IRQHandler,   /*  3: GPIO P3 interrupt */
    (uint32_t) GPIO4_IRQHandler,   /*  4: GPIO P4 interrupt */
    0,                             /*  5: Reserved */
    (uint32_t) CCP_IRQHandler,     /*  6: Capture/PWM interrupt */
    (uint32_t) ADC0_IRQHandler,    /*  7: ADC 0 interrupt */
    0,                             /*  8: Reserved */
    (uint32_t) WWDT_IRQHandler,    /*  9: WWDT interrupt */
    (uint32_t) EPWM_IRQHandler,    /* 10: EPWM interrupt */
    0,                             /* 11: Reserved */
    (uint32_t) ADC1_IRQHandler,    /* 12: ADC 1 interrupt */
    (uint32_t) ACMP_IRQHandler,    /* 13: ACMP interrupt */
    0,                             /* 14: Reserved */
    (uint32_t) UART0_IRQHandler,   /* 15: UART 0 interrupt */
    (uint32_t) UART1_IRQHandler,   /* 16: UART 1 interrupt */
    0,                             /* 17: Reserved */
    0,                             /* 18: Reserved */
    (uint32_t) TMR0_IRQHandler,    /* 19: TIMER 0 interrupt */
    (uint32_t) TMR1_IRQHandler,    /* 20: TIMER 1 interrupt */
    0,                             /* 21: Reserved */
    0,                             /* 22: Reserved */
    (uint32_t) WDT_IRQHandler,     /* 23: WDT  interrupt */
    (uint32_t) I2C_IRQHandler,     /* 24: I2C  interrupt */
    0,                             /* 25: Reserved */
    (uint32_t) SPI_IRQHandler,     /* 26: SPI interrupt */
    0,                             /* 27: Reserved */
    0,                             /* 28: Reserved */
    0,                             /* 29: Reserved */
    0,                             /* 30: Reserved */
    (uint32_t) LVD_IRQHandler,     /* 31: LVD interrupt */
发表于 2025-9-27 10:59:54 | 显示全部楼层
CMSIS 6直接将启动文件统一成C了
https://github.com/ARM-software/ ... ce/startup_Device.c
 楼主| 发表于 2025-9-27 11:17:27 | 显示全部楼层
eric2013 发表于 2025-9-27 10:59
CMSIS 6直接将启动文件统一成C了
https://github.com/ARM-software/CMSIS_6/blob/main/CMSIS/Core/Templ ...
貌似现在芯片厂商适配的文件还是CMSIS V5或一下版本的启动文件。
GMT+8, 2026-11-24 08:02 , Processed in 1.257088 second(s), 24 queries .
