查看: 1066|回复: 9
[IAR] IAR8.40如何将数据存放在flash上
发表于 2025-9-26 14:54:31 | 显示全部楼层 |阅读模式
有一个静态全局结构体变量,想将它放在flash的某个固定地址上。
变量定义如下:
__attribute__((section(".my_data")))
static my_struct_t temp_data  = 0xAA;
icf文件如下:
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x08000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x08008000;
define symbol __ICFEDIT_region_ROM_end__   = 0x0807FFFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x20000000;
define symbol __ICFEDIT_region_RAM_end__   = 0x2001FFFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x400;
define symbol __ICFEDIT_size_heap__   = 0x200;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
define region ROM_region      = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__];
define region RAM_region      = mem:[from __ICFEDIT_region_RAM_start__   to __ICFEDIT_region_RAM_end__];
define region MY_region       = mem:[from 0x08007000  to 0x08008000];
define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };
define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };
define block MY_DATA   with alignment = 4 {section .my_data};
initialize by copy { readwrite };
do not initialize  { section .noinit };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };
place in ROM_region   { readonly };
place in RAM_region   { readwrite,
                        block CSTACK, block HEAP };
place in MY_region   { block MY_DATA  };
生成的map文件中,temp_data 显示在0x800'7000的位置,但是hex文件中0x800'7000的地址没有数据。请问是什么原因?感觉还是我的icf写的有问题
发表于 2025-9-26 16:56:38 | 显示全部楼层
IAR的话,不设置ICF
直接  #pragma location=地址, 试试
 楼主| 发表于 2025-9-26 17:16:09 | 显示全部楼层
改成这样还是不行。。
#pragma location = 0x08008000
发表于 2025-9-26 17:19:38 | 显示全部楼层
fenglang 发表于 2025-9-26 17:16
改成这样还是不行。。
const my_struct_t temp_data  = 0xAA;
 楼主| 发表于 2025-9-26 17:31:20 | 显示全部楼层
这个变量只能是const的才行吗?
发表于 2025-9-26 18:04:59 | 显示全部楼层
fenglang 发表于 2025-9-26 17:31
这个变量只能是const的才行吗?
内部Flash使用,要加的
发表于 2025-9-26 22:50:13 | 显示全部楼层
#pragma location=0x08004426
__root const char __Firmware_Version[10] = "V0.0.1.3";
变量少的话就用#pragma location
const  加上才会被放到flash中
__root 是为了防止变量未使用被编译器优化掉
发表于 2025-9-27 09:10:53 | 显示全部楼层
还可以这样,直接在C文件定义,不用修改连接脚本
#if defined ( __ICCARM__ )
__root const char datestr[]  @FLASH_START_ADDR) = __DATE__;
__root const char ver[] @(DATA_FLASH_START_ADDR + 20) = "MODE NAME V1.0";
#endif
 楼主| 发表于 2025-9-29 08:47:04 | 显示全部楼层
eric2013 发表于 2025-9-26 18:04
内部Flash使用,要加的
这个变量后面还要被修改加了const就不能被修改了吧?
发表于 2025-9-29 10:04:43 | 显示全部楼层
对,除非你做内部Flash模拟EEPROM功能。
GMT+8, 2026-11-24 07:46 , Processed in 0.426100 second(s), 24 queries .
