查看: 885|回复: 0
[技术讨论] nRF54L15初始化ADC
发表于 2025-8-29 14:38:19 | 显示全部楼层 |阅读模式
说明
如下nRF54L15 使用 Zephyr API 和 nrfx 驱动初始化 ADC 采集电压
需要注意的地方
  • IO需要芯片指定的AIN引脚
  • 最大分辨率是14bit(采样率:31.25 ksps)
  • nRF54L15 的 ADC 内部参考电压(ADC_REF_INTERNAL)为 0.9 V
  • 如需采集电压,由于分压电阻不同,需要调整 ADC_ACQ_TIME_DEFAULT
一、 Zephyr API 方式
1.1 prj.conf配置prj.conf 配置1.2 overlay 配置(如:nrf54l15dk_nrf54l15_cpuapp.overlay)&adc {        #address-cells = <1>;        #size-cells = <0>;        status = "okay";        channel@0 {                reg = <0>;                zephyr,gain = "ADC_GAIN_1_4";                zephyr,reference = "ADC_REF_INTERNAL";                zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;                zephyr,input-positive = <NRF_SAADC_AIN4>; /* P1.11 for the nRF54L15 DK */                zephyr,resolution = <14>;        };};1.3 代码示例#include <zephyr/drivers/adc.h>static const struct adc_dt_spec adc_channel = ADC_DT_SPEC_GET(DT_PATH(zephyr_user));void main(void){        int err;        int16_t buf;        struct adc_sequence sequence = {                .buffer = &buf,                .buffer_size = sizeof(buf),        };        if (!adc_is_ready_dt(&adc_channel)) {                printk("ADC not ready\n");                return;        }        err = adc_channel_setup_dt(&adc_channel);        if (err < 0) {                printk("ADC channel setup failed: %d\n", err);                return;        }        err = adc_sequence_init_dt(&adc_channel, &sequence);        if (err < 0) {                printk("ADC sequence init failed: %d\n", err);                return;        }        while (1) {                err = adc_read(adc_channel.dev, &sequence);                if (err < 0) {                        printk("ADC read failed: %d\n", err);                } else {                        printk("ADC raw value: %d\n", buf);                }                k_msleep(1000);        }}二、NRFX库方式2.1 prj.conf配置CONFIG_NRFX_SAADC=y2.2 代码示例#include <nrfx_saadc.h>#define NRF_SAADC_INPUT_AIN4 NRF_PIN_PORT_TO_PIN_NUMBER(11U, 1)#define SAADC_INPUT_PIN NRF_SAADC_INPUT_AIN4static nrfx_saadc_channel_t channel = NRFX_SAADC_DEFAULT_CHANNEL_SE(SAADC_INPUT_PIN, 0);static int16_t sample;void main(void){        nrfx_err_t err;        err = nrfx_saadc_init(1); // 1为优先级,可根据实际调整        if (err != NRFX_SUCCESS) {                printk("SAADC init error: %08x\n", err);                return;        }        channel.channel_config.gain = NRF_SAADC_GAIN1_4;        err = nrfx_saadc_channels_config(&channel, 1);        if (err != NRFX_SUCCESS) {                printk("SAADC channel config error: %08x\n", err);                return;        }        while (1) {                err = nrfx_saadc_buffer_set(&sample, 1);                if (err != NRFX_SUCCESS) {                        printk("SAADC buffer set error: %08x\n", err);                        return;                }                err = nrfx_saadc_mode_trigger();                if (err != NRFX_SUCCESS) {                        printk("SAADC trigger error: %08x\n", err);                        return;                }                printk("SAADC sample: %d\n", sample);                k_msleep(1000);        }}
如需采集电压值(单位 mV),可用如下公式换算
int battery_voltage = ((900*4) * sample) / ((1<<12)); // 12位分辨率
GMT+8, 2026-11-22 13:04 , Processed in 1.097896 second(s), 22 queries .
