查看: 4764|回复: 38
我的高级现实人形机器人项目
发表于 2025-8-22 02:58:19 | 显示全部楼层 |阅读模式
Project Goal: I'm working on making a series of humanoid robots. The goal is for these robots to have a musculoskeletal system inspired by the human body, advanced artificial intelligence, and to look human, at least to a casual observer from a distance. I want to use them as home assistants, doing chores and making things.
Here's a CAD image of my Abel robot showing the small BLDC motors I chose for each muscle replacement and mounted wherever space allowed in the CAD.
I don't speak Chinese, I speak English and am using a translation app
参与人数 2金币 +110 收起 理由
天际公民1087 + 10
eric2013 + 100 很给力!
发表于 2025-8-27 08:56:14 | 显示全部楼层
This is a huge project.
 楼主| 发表于 2025-8-28 05:22:33 | 显示全部楼层
电机会使指关节收缩,但手镯绳会再次将其伸直。  为了创建这种手镯绳连接,我在手镯绳带的每一端打一个结,然后将尼龙线绑在手镯绳结内的手镯绳上。手链两端的绳结充当终点挡块。到目前为止似乎效果很好,并且比我之前提出的方法减少了材料。
 楼主| 发表于 2025-9-4 04:40:18 | 显示全部楼层
好的,手镯绳很快就会自动解开,所以我要回到之前用钓鱼压接套将手镯绳两端绑起来的方法。
当尝试用我的迷你斜切锯将钓鱼卷曲袖切成两半时,我注意到这是一个困难的过程并且并不理想。所以我想出了一个更简单的方法,它更快、更干净、安装和拆卸更少、不需要去毛刺等等!
方法是将打捞压接套筒放在平坦的表面上,将精确的刀片垂直于其顶部排列,然后施加适度的向下压力以在金属上刻痕,然后小心地前后滑动刀,形成完美的刻痕线,每次通过时刻痕线都会加深。经过几次之后,钓鱼压接套筒的两半干净地分开了!该方法使用与管道中使用的铜管切割机类似的原理。
 楼主| 发表于 2025-9-7 01:32:12 | 显示全部楼层
I installed two tensioners for the robot and they were seriously successful overall in testing. So much so that I am now confident enough in the entire pulley system to move onto the custom mini BLDC motor controller to get the motor to run motorized tests of finger movements next. Well after a couple very minor tweaks that is.
So the first tensioner I installed on the extension part of the index finger joint we are working on. I used the bracelet cord folded in half and fishing crimp sleeved then sewn into the bone fabric. It seems just about perfect except for one thing: I want to keep it under mild constant tension but the bone fabric creeps/moves slowly when put under constant tension like this because it is taped into place on the bone after all. The tape is allowing the movement. This means it does not stay put and my anchor points move over time so I can't set a tension and rely on it staying at that tension long term. To resolve this I need a mechanical connection at the tension point anchoring location.
To mechanically connect my anchor point, I have decided to use tiny self tapping screws. I have avoided screwing into the bones till now but I'm making an exception here. The screws won't be going that deep and the finger bones are unlikely to break anyways IMO. So I feel comfortable with this. Here's the screws I ordered for this from Amazon:
Next, I created a tensioner for the middlemost archimedes pulley. That pulley was creating significant drag and slowing down the finger extension during testing due to rope friction. So adding a tensioner line to pull it back down toward the fingers during extension was my solution for this. It worked amazingly well. To make this, first I tied off a fishing hook eye to the bottom of the radius bone just above where my TPFE guide tubing entrance is. Then I glued a 7cm piece of bracelet cord to a piece of 6lb test .08mm braided pe fishing line with 401 glue. I secured the top of the bracelet cord to the top of the archimedes pulley system and then threaded the other end through the fishing hook eye and back up and to the bottom of the archimedes pulley where I tied it off. So it ties off at top, comes down to bottom, goes through the fishing eye then comes back up and connects to my pulley. It creates just enough downward pull to delete the rope drag slowing down that pulley from coming down and this enables the system to unwind and extend back to its starting point after each time I contracts/pulls upward to cause finger contraction. This means the finger extension now happens swiftly with no hangups and the whole archimedes pulley system is now under constant tension at all times which keeps things neat and prevents tangling issues pre-emptively. This rig was a massive success and took up hardly ANY space at all.  I put the post it notes behind the archimedes pulley tensioner so you can see it. It's hard to see otherwise without a contrasting backdrop. It works amazingly well.
 楼主| 发表于 2025-9-11 01:21:46 | 显示全部楼层
Back to electronics again. I've been reviewing my BLDC motor schematic and making some minor adjustments. Here's the updated schematic. It combines many other schematics I found online with some help from ChatGPT. Level 1 is complete cluelessness, and level 10 is an absolute expert at BLDC motor schematics. I think I'm probably a level 5. So, please take my design with a grain of salt. It'll be interesting to see if it works. Notice that I've included some schematics from Electronoobs, an excellent YouTuber, on the left for reference and learning material. My schematic is the large one on the right. Electronoobs' video series on BLDC motor controllers was very helpful in helping me develop a basic understanding of these things.
 楼主| 发表于 2025-9-20 02:01:07 | 显示全部楼层
我开始对 BLDC 电机控制器的某些部分进行一些测试,遇到了一些问题并学到了一些东西。我正在与 chatgpt 合作解决每个问题,并一直在更新我的原理图以反映我所做的大量更改。我了解到的一件事是,对于高侧开关,从栅极到源极的电压必须比漏极电压高 10-12v,因为一旦开关打开,漏极电压就会与源极电压相同。然后,从栅极到源极的电压必须以电机输入电压 + 12 开始,同时仍符合数据表规定的从栅极到源极最大允许电压的范围,或者必须随着源极电压上升而动态上升,使得当源极电压上升成为漏极电压时,从栅极到源极的电压比源极电压高 12。
幸运的是,我可以为这个 2430 电机使用前者,因为我可以使用 6-8.4v 为电机供电,并且从栅极到源极的电压最大值为 20v。这意味着我可以使用从栅极到源极的 20V 电​​压,当 MOSFET 首次开启时,不会烧坏 MOSFET,但当源极上升到 8.4V 时,20V-8.4V 仍然是 11.6V,这足够高,使 MOSFET 能够在没有任何动态设置的情况下仍然保持开启状态。如果我想稍后在一些较大的电机上使用 12V 电机电源,我将需要一个自举电路来为高端 MOSFET 提供从栅极到源极的动态电压,该电压在源极电压上升时上升。所以我添加了该示意图以及一个选项。我也可以为此使用 MOSFET 驱动器,但希望通过仅使用分立元件而不是 IC 来降低成本和增加的体积。
不管怎样,为了在测试中进一步分解,我决定使用一对实验室电源来测试打开和关闭单个高边 MOSFET,一个提供 20v,另一个提供 8.4v。为了打开电源,我将栅极和源极连接到 20v 实验室电源,并将 8.4v 实验室电源的红色鳄鱼夹连接到漏极,然后从源极到 8.4v 电源的黑色引线进行测量,并在该测试中验证 8v 是否有效,证明 MOSFET 实际上已开启。然后,我从电源上取下 20V 实验室电源的黑色鳄鱼夹,并将源极与栅极短路,以耗尽 MOSFET 内部的内部电容器,然后从源极到黑色 8.4V 夹子进行测试,果然它接近 0V,因此关闭。但根据 chatgpt 的说法,由于电容耦合和泄漏,栅极到源极的短路被消除后,电压确实逐渐回升至 8.4V。因此,我需要在栅极和源极引脚之间添加一个 10k 欧姆电阻器,以自动将其短路,并在应该关闭时保持其完全排空和完全关闭。
因此,我计划逐步添加组件,并在添加每个组件后进行测试,以确保在每次微小更改后它仍然可以正常工作,并通过这种方式逐渐构建电路,证明每个组件都可以正常工作。这是因为事情有所有这些陷阱,“哦,你不知道这个小细节吗?”不断出现并证明它比我想象的更复杂。所以我必须边走边证明每一件小事。在构建整个组件之后尝试找出问题所在,比在添加单个组件并且在添加该组件之前该组件正常工作时找出问题所在要困难得多。这样我就能以最好的方式克服这一挑战。
注意:提醒:我正在构建一个定制的 BLDC 电机控制器,因为现成的控制器没有足够的小型化来适应我必须处理的狭小空间限制。此外,构建我自己的软件可以让我的软件更精确地控制旋转磁场的每一个微小的进步,同时我将能够对这些进步进行脉宽调制,使它们更平滑、噪音更小,并且还具有扭矩控制,这意味着手指可以根据需要粗暴而快速地运动,或者缓慢而柔和、精致或缓慢但有力等。我还可以创建与人类手指关节加速度相匹配的加速度曲线,以使运动看起来非常自然,就像人类的运动一样,这对我来说非常重要。当我感觉这是我自己的电路时,很多精细的精度是可能的。虽然现成的产品可能具有其中一些功能,但价格往往反映了这一点,因此价格令人望而却步。但无论如何,在这种水平的控制下,没有什么是现成的,并且能够如此精细地调整其外形尺寸和体积包络,以满足我在每个电机的空间中的确切需求。
 楼主| 发表于 2025-10-21 23:06:56 | 显示全部楼层
好吧,在现实生活中大约一个月的绕道之后,我终于回到了电子产品上。各种各样的事情减慢了我这次会议的进度。但我还是完成了一些工作。0603 LED 到 0805 电阻器和一些镍带引线脱落。经过测试并正常工作。这将是指示灯,当低压 mosfet 为定制 BLDC 电机控制器的一部分打开时。0603 LED 对于手工焊接来说非常小,而且它们也不易于焊接。我原本打算使用蓝色 LED,但 chatgpt 说这会通过硅胶皮肤发出不真实的颜色,所以橙色会更好,以提供更自然和更少的硅胶皮肤刺穿指示灯。不知怎么的,我用完了 470ohm 电阻器,所以我不得不订购更多,现在我改用 200ohm 的。它们有点太亮了。但是 chatgpt 说我可以用一团染成黑色的硅胶来漫射 LED,使其光线变暗并漫射,这对我来说是个好主意。我打算用绕线器将这个组件拆下来并绑在东西上。不知怎么的,仅仅是把这两个部件连接起来并进行测试就花了我将近 3 个小时。从研究原理图来刷新我的记忆,到想象放置选项,再到 LED 过热并烧坏,试图找到正确颜色的 LED,再到购买 470ohm 的替换电阻,研究并替换为 200ohm 的电阻,再到与 chatgpt 讨论 LED 颜色选项,再到弄清楚如何手工将 0603 LED 直接焊接到 0805 电阻上,再到不小心将一个部件从镍带引线上折断,不得不重新连接等等,这一切都让人难以忍受。有时候,对电子产品很难保持耐心,而且我经常以低效的方式做事。从耐心的角度来看,学习什么可以做和什么不可以做是很困难的。但我坚持反复试验和实验,这需要时间。我只需要养成每天坚持的习惯,直到完成。这一切都很复杂。接下来,我正在尝试弄清楚如何将它们全部电子隔离。考虑用层压塑料胶带将它们全部包起来,这样我仍然可以看见它们,并直观地排除故障。此外,我还在考虑如何使用吸锡线编织物作为每个MOSFET的热管,并将其连接到液体冷却系统。但它不导电。所以它可以导热,但不能导电。我正在尝试弄清楚是否要为此创建一个Micah屏障或仅使用导热硅胶,以及所需的布线。我还在考虑是否需要微型同轴屏蔽电缆来连接每个电缆,或者在从微控制器到MOSFET等的线路时是否只需要普通的绕线。我还在尝试弄清楚我是否需​​要霍尔效应传感器或反电动势读数或不需要反馈,但需要电位器,以及每个选项的含义。所有这些需要考虑的事情太多了。而且所有这些考虑也让我的工作进度更加慢了,因为我必须对所有事情做出决定。这真的让人不知所措。
 楼主| 发表于 2025-11-3 02:56:52 | 显示全部楼层
好的,所以我决定用30号绕线,把它缠绕到连接到LED灯组的镍条上,然后剪掉多余的镍条。我喜欢这种绕线的原因是它非常细,几乎不占空间,而且由于可以缠绕,我不需要加热,避免了不小心把SMD元件焊掉。我还喜欢它已经绝缘并带有颜色编码,这样我就不用担心镍条在连接处的整个过程中需要绝缘了。为了给整个LED装置绝缘,我用了包装胶带,这样既能清楚地看到所有元件,又能保证它们之间的电气隔离。我就像合上书一样,把包装胶带折叠起来盖住整个组件。
注:绕线完成后,我发现线缠得不够紧。因为我的绕线工具丢了,所以没用,只好用尖嘴镊子手动绕了几圈。为了拧紧,我用剥线钳的钳头(那种带齿的钳子)压紧了连接处。这样处理后,连接看起来非常牢固。
发表于 2025-11-3 15:07:55 | 显示全部楼层
楼主这个还在持续更新,支持下
发表于 2025-11-4 15:53:15 | 显示全部楼层
支持下,欢迎国际友人
 楼主| 发表于 2025-11-8 07:56:24 | 显示全部楼层
一些更新:一位观众用传统的常用格式重新绘制了我的无刷直流电机原理图,这种格式对大多数人来说更容易阅读和理解,因为他们更熟悉这种格式。所以我重新发布一下。原理图看起来基本准确,不过我后来在高侧 MOSFET 的栅极和源极之间加了一个 100nF 的陶瓷电容,以减少振铃问题。根据 chatgpt 的说法,这是标准做法。我还把 LED 的颜色改成了橙色,因为 chatgpt 说蓝色会透过硅胶外壳更明显,产生一种冷冷的内发光效果,而我们希望它看起来像真实的皮肤,所以不用蓝色。至于为什么高侧 MOSFET 需要 100nF 的陶瓷栅极电容而低侧没有,chatgpt 是这样解释的:高侧 MOSFET:它们的源极引脚会随着电机相位上下移动(它不是固定电位)。在开关过程中,漏极和源极都会快速移动,栅极电压必须精确地跟踪这种移动——任何振铃或感应噪声都可能导致 Vgs 瞬间过载。这就是为什么我们要在栅极和源极之间并联一个小电容:它可以抑制高频振铃,并有助于保持栅极相对于其移动的源极的稳定。- 低侧 MOSFET:它们的源极牢固地接地,因此栅极始终相对于一个固定的、稳定的参考电压摆动。它们不会经历同样的“浮动”栅极驱动或源极引脚上的大 dv/dt 变化。因此,栅极本身就更稳定,你不需要额外的 100 nF 栅极-源极电容。总之,这是观众提供的原理图:
以下是我根据上述修改后更新的原理图:
另外,我费力地把新的100nF陶瓷电容安装在了MOSFET的栅极和源极之间。由于它离10k欧姆的Vgs电阻和附近其他一些低温焊点很近,任何加热都肯定会导致这些焊点脱落,整个电路开始散架。所以我最后只好在100nF陶瓷电容(单独放在一旁)的两侧焊上镍条,然后用缝纫针尖在IRLR7843PBF MOSFET栅极和源极的镍条上涂抹少量导电银胶,再把陶瓷电容的镍条按压进去。我把它放在汞灯下烘烤了一个小时左右使其固化,然后在焊点上又涂了一层厚厚的导电银胶。之后我又把它放在汞灯下烘烤了7个小时。这张照片展示了最终效果。
看起来连接很牢固,我觉得在不能焊接的情况下,这是一种很棒的连接方式!从易用性的角度来看,在某些情况下它甚至可能比焊接更好,但这一点我还不能确定
 楼主| 发表于 2025-11-12 03:19:56 | 显示全部楼层
Okay, I've connected the LED and resistor to the front panel of the high-side MOSFET using 30-gauge wire. If problems arise later, I might apply conductive silver paste to the wire. However, I'm wondering if simply wrapping it tightly with electrical tape would be sufficient to prevent open circuits. We'll see.
I also completed the soldering of six braided copper solder wires, which will serve as heat sinks for my high-side MOSFETs. I'm still considering how to attach them to the back of the MOSFETs while ensuring both electrical isolation and thermal conductivity. I'm leaning towards using thermal tape.
 楼主| 发表于 2025-11-12 05:52:50 | 显示全部楼层
This is thermal tape for MOSFET heat dissipation that I bought from Amazon.
发表于 2025-11-12 10:58:04 | 显示全部楼层
Thank you for sharing the project—I’m following it closely!
I do need to point out something: while browsing, I noticed some images weren’t displaying, so I looked into it.
It appears your images weren’t uploaded to “this forum,” but are hosted on the image service of “another forum.”
Because internet controls in China are very strict, and that other forum seems to include some adult content, images served from there may be blocked from displaying.
发表于 2025-11-14 00:33:24 | 显示全部楼层
fantastic
 楼主| 发表于 2025-12-6 12:48:12 | 显示全部楼层
我刚刚测试了电机控制器中正向高侧开关部分,一切似乎都运行正常。图中用粗蓝色线条圈出的部分就是我刚刚成功测试过的部分,其中包含了所有相关组件。
输入端和接地线的焊点非常脆弱,稍微一动就会断裂。我考虑直接把所有元件都粘到 MOSFET 上,但我需要在这些元件下方安装散热片,所以我觉得不能直接粘上去。我需要一个底板或基板来固定这些元件(这正是电路板的作用)。这样可以显著减轻所有连接点的应力。看来我终于亲身体会到电路板的重要性了。如果没有一个平整的底板或基板,元件之间的连接点很容易弯曲和断裂。这让我很惊讶
为了进行测试,我使用了一个设置为 20V 的实验室电源和一个设置为 8.07V 的电源,并使用一块 18650 锂电池作为 4.12V 电源来模拟 Arduino 的输出引脚。我暂时用胶带仔细地将所有金属线路绝缘,以确保不会发生短路,然后用鳄鱼夹将实验室电源的引脚连接到正确的位置。最后,我将 4.12V 的 18650 锂电池连接到电路中,模拟 Arduino 开启 A09T MOSFET——我用两片镍片连接到电池上,并用钕磁铁固定。如果我手边有第三个可以输出 5V 的电源,我就会用它,但我当时没有,所以只能用电池代替。LED 灯亮了,我测试了连接到电机的输出线,确认电压确实是 8.07V。然后我断开了电池的正极,并验证了连接到电机的线路电压为 0V。确实是 0V——尽管如果我把万用表长时间连接在那条线上,我注意到电压会慢慢上升到大约 3.4V,但上次测试时也出现了类似的情况,ChatGPT 说这可能是万用表引起的寄生电容之类的,没什么好担心的。关键是,当我第一次连接时,电压会从 0V 开始,然后随着时间的推移在万用表屏幕上慢慢上升到 3V 左右,上次测试时这种现象也是正常的,所以应该没问题。我想一切都正常.
接下来该怎么做呢?嗯,我想我会先制作半桥的另一部分(低侧),然后测试整个半桥,确保它都能正常工作。我觉得这样我的设计就足够完善了,可以开始制作一些用于连接主功率MOSFET的柔性PCB板了.
 楼主| 发表于 2025-12-7 11:19:38 | 显示全部楼层
我成功制作了一个可用的柔性PCB
 楼主| 发表于 2025-12-8 04:24:34 | 显示全部楼层
好的,这是组装好的电路板。我用 5V 正极和地线进行了测试,LED 灯亮了,所以可以确定没有短路,并且电路是导通的,因此很可能一切正常。下一步测试将是完整的低侧开关电路,这块电路板将作为主 MOSFET 的驱动电路。验证成功后,我们就可以测试整个半桥电路(包括高侧和低侧开关)。如果测试通过,接下来的步骤就是重复上述过程,制作完整的电机控制器(总共需要三个半桥电路).
注:我暂时不想安装散热片,因为我想先验证一下第一个半桥电路,等电子测试没问题后,我再安装散热片,然后继续后续步骤.
 楼主| 发表于 2025-12-20 04:17:42 | 显示全部楼层
我有两项重大突破要宣布.
首先,我突然想到,我不需要先把图案打印到PCB转印纸上,然后再把图案转移到覆铜的Pyralux柔性电路板上,而是可以直接把覆铜的Pyralux柔性电路板贴到信封上,然后直接送入激光打印机进行打印。之前我在研究这个问题的时候排除了这种方法,因为我当时打算使用FR-4电路板,而FR-4电路板既不柔韧也不平整,无法直接送入打印机。但是,现在我使用的是平整且柔韧的空白电路板,据我所知,没有理由不能直接把它送入激光打印机。我还没有测试过这种方法,但如果可行,那将彻底改变一切。这将使DIY电路板的制作过程更加快速便捷!
接下来,关于如何将六根焊锡编织线连接到MOSFET的问题,我一直在苦苦思索各种方法,试图找到一种能够将它们牢固地夹在MOSFET漏极上,并在连接点处添加电绝缘层的方案。由于空间非常狭窄,需要一个非常小的夹紧机构,而且从大多数方向来看,任何我设想的夹具设计都会受到其他部件的阻碍。在我看来,这简直是个噩梦般的问题。然而,我今天想到的解决方案彻底改变了局面:我将直接把焊锡编织线焊接到MOSFET的漏极上!由于金属与金属直接接触,这将最大限度地提高漏极到编织线之间的导电性,并且完全无需任何夹具。不幸的是,这将使这些编织线带电,但我意识到这并不是什么大问题。我只需用玻璃纤维窗纱将它们包裹起来,这样既可以保证良好的空气流通和散热,从而有效地散发MOSFET漏极产生的热量,同时玻璃纤维窗纱还可以作为物理屏障,防止它们接触到其他带电的金属部件。在我看来,窗纱也是非导电的,并且具有良好的耐磨性。我预计这些短的编织线不会与任何东西发生太多接触,因为它们只是从电机连接到水冷管,而且支撑橡胶外壳的骨架网格会提供足够的间隙和缓冲,防止外部物体碰撞或接触。总而言之,我认为这在很大程度上是一个安全的解决方案,而且我们还会安装保险丝,以防止在低风险情况下,两组相邻的焊锡编织线从窗纱中脱落并相互接触,从而导致电路短路。我认为这种情况发生的可能性极低,但无论如何,保险丝都能提供保护.
综上所述,我们现在可以将电绝缘层设置在焊芯编织线末端与铜质液冷管的连接处。在这个连接点,我会在焊芯编织线和管道之间放置电绝缘导热胶带,并在连接处用电工胶带紧密缠绕固定。与在MOSFET漏极处进行同样的操作相比,这样做要简单得多。因此,我们将电绝缘和固定问题转移到了比MOSFET漏极连接点更下游的位置,从而使问题变得轻而易举.
注:ChatGPT建议我给编织铜焊芯镀锡,以防止其氧化,因为氧化可能会降低其导热性。我不太确定这个说法是否正确,但为了保险起见,我可能会这样做,到时候再看吧。我会使用MG Chemicals的液态锡来完成这项工作,我手头正好有这种产品,之前是用来给电路板镀锡的.
 楼主| 发表于 2025-12-23 12:44:24 | 显示全部楼层
今天我用我的巨型Weller W100P烙铁将六根焊锡吸线焊接到高侧MOSFET的背面,焊接过程非常顺利,瞬间就焊好了。我在两者的接触面上都涂抹了大量的低温焊锡膏,然后用左手将它们压在一起,同时用美工刀的刀尖从背面压住焊锡吸线。接着我用这把巨大的烙铁进行焊接,尽管涉及的金属量很大,但它在短短一秒钟内就熔化了焊锡,因为它储存了大量的热能,可以快速释放。这比用普通的小尖头烙铁进行大型焊接任务要轻松得多,用小烙铁经常会导致虚焊等问题。而且,由于焊锡熔化速度很快,附近的元件都没有脱焊,这真是一个巨大的优势
接下来:将焊锡吸线添加到镍片的底部,以降低电阻,然后对这个高侧开关组件进行绝缘处理,并将其安装到电机上,开始最终确定布线方案。之后,我可以对低侧开关组件重复相同的步骤。这样,我就完成了电机控制器三个半桥中的一个.
 楼主| 发表于 2026-1-4 05:45:21 | 显示全部楼层
我成功地在高端MOSFET电路的镍片上加了一层编织焊锡线,并用折叠的红色电工胶带进行了绝缘。我还对其他大部​​分可见部件也进行了绝缘处理。由于原来的控制电路损坏了,我重新制作了一个扁平柔性PCB式的电路,这样应该会更耐用。我还为主MOSFET栅极引脚的20V输入线添加了一根黄色30号线。我还准备好了玻璃纤维窗纱网,用于绝缘充当散热器的焊锡线。现在这个装置已经接近可以安装的状态了,但我还是想再次测试一下,以确保在进行了这么多重大改动和反复调试之后,它仍然能够正常工作.
另外,我注意到将 0.1mm x 4mm x 100mm 的镍带和编织焊锡线叠放在一起以降低电阻并提高导电性,会导致线路比我预期的要粗一些,尤其是在贴上胶带之后。因此,为了解决这个问题,我决定使用手工切割的 0.2mm x 6mm x 100mm 纯铜片。我之前并不知道有这种选择,但在亚马逊上找到了可以用于此用途的卷装 0.2mm 厚度的铜片。由于铜的厚度更大且电阻远低于镍,我应该能够以低于 1W 的热损耗通过 30A 的电流,这非常棒。而且,这样做最终的线路厚度仍然比我第一次尝试的方案要薄得多,同时由于完全去除了用于大电流部分的镍带(除了我计划保留的分流电阻镍带),电阻也更低.
 楼主| 发表于 2026-1-17 13:24:15 | 显示全部楼层
我最近一直在和ChatGPT聊天,聊到我最近一直在为我的机器人制作无刷直流电机控制器,感觉很费力。ChatGPT随机提到集成式半桥功率模块,说我可以利用这种模块来减轻制作电机控制器的工作量。这立刻引起了我的注意,因为我以前从未听说过这种东西,而且它听起来很有意思。我之前一直在自己搭建低侧开关和高侧开关,它们共同构成一个半桥。这需要大量的焊接连接和许多分立元件。而集成式半桥的概念——意味着两个大功率MOSFET以及所有驱动电路都集成在一个芯片上——这将大大减小尺寸并减少元件数量。所以我研究了一下是否有能够满足我的2430无刷直流电机8V 30A需求的集成式半桥模块。结果发现确实有一些这样的产品。起初我考虑的是德州仪器(TI)的CSD95377Q4M半桥驱动器(30A),它可以提供30A的持续电流,非常适合我的需求。但是,我不想被某个特定供应商的芯片所限制,因为这种芯片有一天可能会停产。我更喜欢那种有很多竞争对手生产的、可以在速卖通上买到的通用型产品。这样可以确保我的设计具有前瞻性,不必担心某个制造商停产我使用的零件,导致价格飙升或零件根本买不到。所以,经过一番深入研究,我在速卖通上找到了CSD95481RWJ QFN芯片组,有好几家供应商在销售,而且价格不到1美元一个。也就是说,它相当于两个功率MOSFET加上每个功率MOSFET的所有驱动电路,而价格却不到1美元。这款芯片的持续电流额定值为60A。它的尺寸只有5毫米 x 6毫米,这简直太不可思议了。它比我之前使用的方案小得多,但功率却一样强大。它们通常用于小型降压转换器,并直接用于显卡PCB、服务器、汽车PCB等等。总之,使用三个这样的半桥芯片就可以驱动一个无刷直流电机。将这么多元件集成到如此小的封装中,真是让我大开眼界。所以我订购了 60 个这种芯片——足够驱动 20 个无刷直流电机。如果使用这些芯片比使用我之前用的分立元件更容易,我倾向于将它们用于所有电机控制器。我认为使用它们成本更低——不过我还需要计算一下具体成本。它们甚至内置了温度传感器,我们可以读取温度,这是一个额外的优势。它们的内置电流传感功能不适用于无刷直流电机,所以我仍然需要使用外部的分流电阻电流传感电路,但这没关系。总而言之,这些芯片似乎可以彻底改变现状,减少元件数量,从而减少潜在的故障点,还可以缩小电路板尺寸,使我的电子设备更加小型化,这对我们来说非常有利。我现在还需要研究如何设计相应的 PCB 电路以及需要哪些外部分立元件来支持它。它采用顶部散热方式,这一点也很有意思。我设想使用硅胶导热胶将一个铜垫粘到芯片上,铜垫上已经焊好了编织焊芯线。这些焊芯线会将热量传导到我的水冷管道系统中.
我有点惊讶,似乎没人用这些器件来控制无刷直流电机。它们看起来非常适合这个用途。也许我会引领一股潮流。前提是我不会以惨痛的教训发现为什么没人用它们来做这件事!
注:完整产品名称为:“(5个)100%原装全新 CSD95481RWJ 95481RWJ CSD59950RWJ 59950RWJ QFN 芯片组
注:在我之前的无刷直流电机控制器设计中,我需要使用 6 个数字 I/O 引脚来驱动单个无刷直流电机控制器的 6 个功率 MOSFET 及其控制电路。但对于使用 3 个 CSD95481RWJ H 桥芯片的无刷直流电机控制器设计,我只需要使用微控制器上的 3 个数字 I/O 引脚。这些 CSD95481RWJ H 桥芯片使用一个三态 PWM 引脚——您可以从微控制器向其发送高电平、低电平或浮空信号。数字输出高电平和低电平是常见的数字输出模式,而浮空模式则可以通过在代码中将引脚配置为数字输入引脚来实现。这三种状态输入到芯片后,芯片会输出 V+、V- 或处于关闭/浮空状态。这与我们之前使用分立元件的微控制器设计中使用的标准 H 桥的三种状态完美对应。因此,微控制器上数字 I/O 引脚使用量的减少意味着理论上每个微控制器可以驱动更多电机,这非常棒.
 楼主| 发表于 2026-1-21 03:42:50 | 显示全部楼层
好的,我现在想到,每个半桥都只是一个微型集成电路,而不是一对笨重的功率MOSFET,这样一来,我的整个无刷直流电机控制器所占用的空间大约只有3厘米 x 1厘米 x 2毫米,对于一个8V电压下可提供30A连续电流的电机控制器来说,这简直小得令人难以置信!这个发现让我重新思考,我是否还需要像最初设计那样,把整个电机控制器像马鞍一样安装在无刷直流电机的侧面——我最初的离散元件设计方案就是这么做的。但我现在意识到,由于元件尺寸变得如此之小,我可以简单地为每一相构建一个半桥,并将其作为内嵌元件集成到连接到无刷直流电机各相线的电缆中。因此,我不再需要为每个电机控制器预留专门的位置,而只需要在从无刷直流电机引出的相线上看到一个轻微的凸起,这个凸起内部就包含了处理该相线的半桥。所有元件都内嵌在电缆中。我认为这是最简单、最简洁的实现方式。这也意味着整个电机控制器将“悬空”在空中,实际上不会安装到任何电机或其他任何东西上。它只是线束的一部分,内嵌在其中。在我看来,这是一种非常激进的方法。之所以可行,完全是因为我们将设计尺寸缩小到了令人难以置信的程度
之前的电路图版本设计成可以像马鞍一样安装在电机侧面,呈L形,输入端从下方接入,输出端则从左侧引出,连接到电机相线。这些L形半桥电路会并排堆叠在一起。而在新版本中,所有元件都呈直线排列,输入端从右侧接入,输出端从左侧引出,连接到电机.
这是更新后的内联式电路图(不再像以前那样是L形布局).
 楼主| 发表于 2026-2-16 04:34:16 | 显示全部楼层
我在为我的集成半桥IC芯片制作DIY柔性PCB时遇到了一些问题。这款芯片的引脚间距非常小,只有0.4mm,所以PCB的精度必须极高。我之前用分立元件制作的BLDC电机控制器,可以制作出更粗糙、精度要求更低的柔性PCB,也能正常工作。但这次的柔性PCB必须非常精细,执行精度也必须非常高。这可不是开玩笑。第一个问题是,我的激光打印机无法很好地粘附在我从亚马逊买的PCB转印纸上。打印出来的图案会镜像出现在转印纸上大约一英寸远的地方.
这意味着墨水没有充分附着在转印纸上,而是沾到了定影辊或其他部件上,导致定影辊损坏。随着时间的推移,这会严重影响打印机的性能,甚至导致所有打印件定影不全,即使是正常的办公用途也不例外。这意味着我打印在信封上的地址会在邮寄过程中晕染,导致信封在邮件系统中丢失。这非常非常糟糕。所以我不得不放弃使用这种转印纸.
幸好 chatgpt 推荐使用光面杂志纸,所以我试了一下。我用的是《今日心理学》杂志的纸,打印效果完美。我使用了 600 dpi 的分辨率,纸张厚度设置为普通纸。我先用 400 目砂纸打磨了我的铜箔柔性电路板(Pyralux),然后用酒精棉片擦拭。接下来,我用覆膜机将打印好的光面杂志纸覆膜到铜箔柔性电路板(Pyralux)上,覆膜了几遍。然后,我将杂志和柔性电路板“三明治”浸泡在 110 华氏度(约 43 摄氏度)的水中约 30 分钟,使光面杂志纸变得软烂。之后,我用手指从外边缘开始反复摩擦纸张,慢慢地、轻轻地将其撕下来。纸张分两层撕了下来。焊盘上会残留一些纸浆,但这没关系,不会影响后续的蚀刻过程,可以不用管它。用这种方法,我得到了有史以来最清晰的痕迹.
但是,当我准备蚀刻这块涂有碳粉的干净PCB板时,问题又出现了。我用的是室温水,也就是过硫酸铵晶体和水的混合液。水温是68华氏度(约20摄氏度)。我没有充分搅拌蚀刻液。蚀刻过程竟然花了2.5到3个小时!这蚀刻速度简直糟糕透了。较大的铜层蒸发得很慢,而较细的线路则出现了严重的侧蚀,导致碳粉下方的整块铜都被蚀刻掉并蒸发,碳粉也因为没有附着点而脱落,部分铜层甚至完全丢失。正常的蚀刻时间应该不超过5到15分钟。3个小时完全无法接受。后来我在chatgpt论坛上了解到,蚀刻时间过长的原因是我没有将蚀刻液加热到110到120华氏度(约43到49摄氏度),也没有充分搅拌混合物(搅拌、振动或其他任何方法都有帮助)。我还从 chatgpt 那里了解到,蚀刻剂温度每升高 10 华氏度,蚀刻时间就会减半。所以,如果温度升高到 110 华氏度,并且我充分搅拌,蚀刻时间很可能就会缩短到 5 分钟左右。蚀刻剂晶体容器上的说明说室温下无需搅拌即可。他们肯定错了.
为了完善蚀刻工艺,我计划使用我现有的带温度调节功能的交流电热板——那种用来加热锅具或水壶的。我还确定最简单的搅拌方法是将蚀刻液和PCB板放入一个小容器中,并制作一个装置,以有节奏的方式升降容器的一侧,使蚀刻液在PCB板上来回摇晃。下图是我设计的简易装置。这种方法的优点是,只要你拥有所需的少量零件,它就是免费的。我可以用实验室的电源为其供电。N20齿轮电机大约1美元。制作起来非常简单。可以轻松承受15克蚀刻液的晃动。制作简单。没有任何东西会进入酸液内部,从而避免了旋转并撞击PCB板可能造成的损坏。我们希望每个PCB板的蚀刻液用量都尽可能少,所以即使是带磁铁的旋转搅拌棒也会撞击PCB板,使其剧烈晃动等等。我不想这样,也不想让酸液接触到PCB板,然后还要费力地把它捞出来清洗。我们希望除了PCB板本身之外,没有任何东西接触到酸液。因此,摇晃整个容器是合理的,可以解决这个问题.
该摇臂装置由一个N20齿轮电机(速卖通售价1美元)、一个小轮子(纸和强力胶复合轮)、一根细绳以及一个小木块组成,该木块用于将电机抬高到高于蚀刻液容器的位置。当N20齿轮电机旋转时,它会带动细绳向上移动,从而抬起蚀刻液容器的一端。当电机旋转到180度(6点钟方向)时,蚀刻液容器就会落回原位。如此循环往复地升降容器,使蚀刻液在PCB板上来回晃动,从而提高化学蚀刻反应的速率,并更有效地将铜离子从待蚀刻的PCB表面带走。我认为不需要PWM电机控制器,因为可以通过改变实验室电源的电压设置和/或改变旋转轮的半径来改变摇臂的转速.
 楼主| 发表于 2026-3-12 08:57:36 | 显示全部楼层
我把温度传感器、电热板、玻璃容器和水准备好,然后摸索出电热板温度旋钮应该调到哪个位置才能达到理想的水温。接着,我用标签纸贴上标记,并在上面写上118华氏度,这是旋钮上那个位置的平均温度。我觉得大概有15华氏度的误差。差不多就行了
接下来,我用邮政秤精确称量了水和PCB蚀刻剂(过硫酸铵晶体和水的混合物)的比例。我把混合物倒入一个湿巾盒底部三分之一处,总共0.8盎司。然后,我把蚀刻剂混合物浸入装有温水的玻璃盆中,使其升温。我注意到装有蚀刻剂的湿巾盒有倾倒的趋势,于是用透明胶带将湿巾盒的四个方向固定在玻璃盆上,并稍微浸入水中,以便最大限度地将外部较热的水温传递到蚀刻剂盒内,从而更有效地加热蚀刻剂。我没有使用自动搅拌器,而是选择用热熔胶棒手动搅拌混合物
总的来说,蚀刻时间在5到8分钟之间,而且我觉得温度接近130华氏度时蚀刻速度更快——接近5分钟,甚至可能4分钟(我没有计时)。与室温蚀刻剂相比,速度简直快得惊人,室温蚀刻剂蚀刻一块板子需要2到3个小时。所以,说明书上说室温蚀刻就可以了,这确实是错的。那样只会导致底切
总之,搅拌和温暖的环境显著改善了我的成果,几乎每块电路板都能用了。我一共做了八九块,足够至少组装两个电机,还能组装第三个电机的一部分。所以目前够用了。细小的线路上仍然有一点点缺口,但很少会破坏线路的连续性。我会在 Photoshop 中稍微加宽线路,以便下次打印时使用。预计大约 15% 的外边缘会被切掉,所以我们需要打印得更宽一些来补偿,这样最终得到的宽度就能达到我们最初想要的,因为缺口的影响已经显现出来了。这样一来,缺口问题就能得到解决,不会造成损害。这就是我计划的解决方法
如果焊盘或走线中心出现罕见的针孔,或者细走线上出现微小的开路,我相信在这些区域涂上一层焊锡就能解决问题。这些小孔之类的缺陷非常小,因此很容易根据需要进行焊接桥接。我认为我的电路板大部分都能直接使用。我相信随着我不断调整和改进技术,我的方法会越来越好——但我们已经能够以如此精细的细节和微型化程度制造出可用的电路,这本身就非常令人鼓舞。在我看来,任何进一步的改进都只是锦上添花
[color=rgba(0, 0, 0, 0.87)]196
[url=][/url]
Translation results[backcolor=var(--gm3-sys-color-surface-container,#f0f4f9)]Translation result
[backcolor=var(--gm3-sys-color-surface-container,#f0f4f9)]下一步我将按照视频中的方法焊接半桥集成电路芯片——我认为这种方法看起来非常出色且可靠,希望在我这边复制起来也不会太难: https://www.youtube.com/shorts/r-HaRjBvWgU
 楼主| 发表于 2026-4-4 16:59:01 | 显示全部楼层
好的,我用美工刀的刀尖小心地挑取了一些低温焊膏,随后仔细地将其拖焊(drag solder)涂覆在我想要进行预上锡处理的关键区域上。目前看来似乎没有发生短路,而且我觉得每个焊盘和走线上的焊锡量也相当合适。我之前忘了用酒精擦拭布进行清理,不过在拍下这张照片之后,我已经补做了这一步.
接下来的步骤是,我必须小心地对那条从 IC 芯片下方穿过的微细走线进行 UV 固化阻焊处理。如果不这么做,我估计肯定会导致焊盘与其他部位发生短路。涂抹时必须非常薄,以免妨碍 IC 芯片平整贴合,从而影响后续的焊接效果.
 楼主| 发表于 2026-4-29 05:40:22 | 显示全部楼层
关于我为连接至IC芯片底部焊盘的主导线所构思的散热方案,我决定绘制一幅图解来加以说明。该方案将采用分层结构。首先,我们将芯片放置在底部,使其底面朝上,从而使焊盘向上裸露。接着,在第一层连接层上,我将从铜片材料中切割出形状与焊盘相匹配的铜板,并使用低温焊锡膏配合烙铁将其焊接固定。从理论上讲,这第一层连接的主要作用是将焊盘向上延伸,使其高度超出我们此前制作的DIY PCB板上的“观察窗口”;这样一来,我们现有的DIY PCB板与这第一层铜板便共同构成了整个散热结构的“第一层”。理想情况下,我认为这层铜板的高度应略高于下方的PCB板面。这层直接焊接在IC焊盘上的铜板,负责将电流与热量传导至第二层,且无需借助过孔(vias)来实现。在工业化生产的多层PCB中,通常是通过过孔将热量和电流传导至板子的第二层;而在此方案中,我们改用实心铜板来替代过孔。这种做法理论上效果更佳,因为实心铜板提供了比过孔孔壁大得多的散热表面积。接下来是第二层。在这一层上,我们可以制作一块面积大得多的铜板,使其向外延伸,远远超出芯片的范围。这块向外延伸的部分将充当一个“接线端子”,供我们焊接V-电源线。同时,它也可用作焊接散热鳍片(即我们准备好的6股吸锡带铜丝)的基座。此外,第二层还包含一块负责将V+电源信号引至第三层的铜板。至于第三层,我们只需附接一块大型铜板;这块铜板同样向外大幅延伸,形成一个接线端子,供我们焊接V+电源线以及作为散热鳍片的吸锡带铜丝.
 楼主| 发表于 2026-6-3 16:16:06 | 显示全部楼层
好了,我订购的 Relife RL-UVH902 UV 快固化阻焊漆已经到货了;同时到达的还有我订购的 Relife UV 固化灯,用来快速、高效地固化这款阻焊漆。所以现在,我只需要用阻焊漆覆盖住那条从半桥 IC 芯片下方穿过的小走线就可以了.
 楼主| 发表于 2026-6-8 05:37:42 | 显示全部楼层
今天我成功涂抹了UV阻焊油,过程看起来相当顺利。我用一根细缝衣针的针尖将油涂抹在走线上,为了保险起见,还用UV灯照射了10秒钟。我使用的是透明UV阻焊油,所以透过它仍能看到走线,只是视觉上看起来有些朦胧或浑浊。我用美工刀尖在阻焊层上轻轻划了几下,既是为了凭手感测试厚度,也是为了检验其耐刮擦性能,同时确认它已完全固化。固化后的涂层非常坚硬耐用,而且涂得也相当薄。现在的问题是:如果要在其上方焊接芯片,这层阻焊油会不会太厚,导致芯片位置被垫高?这可是个关键问题。因为如果阻焊层把芯片从PCB表面稍微垫高了一点,焊料可能就无法连接IC引脚焊盘与PCB焊盘,导致无法形成有效连接。这是我最担心的地方。如果因此出了问题,我就不得不重新布线,让走线绕开障碍物,而不是像现在这样走最短路径。目前的走线路径穿过了IC下方,所以我才需要做阻焊处理。这种额外的工序确实有点麻烦。我真有点后悔当初没把走线绕得远一点,避开这些区域;那样的话,根本就不需要用UV阻焊油了。也许在未来的电路板改版中我会做这个改进,但还得看情况。眼下我已经制作了好几块板子,打算继续使用它们,毕竟全部重做的工作量太大了
 楼主| 发表于 2026-6-16 17:55:47 | 显示全部楼层
我尝试焊接这颗芯片,但多次以失败告终。尽管我预先在PCB焊盘上上了锡,但在两次尝试中,当焊料熔化时,芯片并没有像预期的那样自动对中并固定到位,而是发生了明显的位移。第一次尝试后,我以为问题出在电路板左侧的那个大焊盘(或汇流排)上——因为那里的焊料量比板子其他边缘的焊盘都要多,导致芯片受力不均而滑离中心。然而,即便我把电路板的那一部分完全切除并再次尝试,芯片在回流焊接过程中依然发生了位移。目前我还不清楚问题的具体原因。我在PCB上涂了AMTECH的粘性助焊剂(虽然已于2022年过期),尽可能将芯片居中放置,然后把它放在一个用于烹饪或烧咖啡壶的交流电加热板上加热,并将温度调到了最高档。第一次尝试时,我让电路板从加热一开始就放在板上,看着助焊剂蒸汽逐渐挥发,直到焊料熔化;虽然我随后关掉了加热板,但这已无济于事,因为芯片已经偏离中心5毫米了。第二次尝试时,为了减少加热过程中的助焊剂过度烧蚀,我等到加热板温度很高时才把板子放上去。在焊料熔化期间,我又加了一些助焊剂,结果芯片还是发生了位移。也许这就是我犯错的地方?不太确定。无论如何,在第二次尝试失败后,我彻底清理了现场,决定改用手工焊接。这次效果似乎好多了。具体操作如下:由于芯片和PCB都已完全上锡,且据我所知没有短路,我先在显微镜最高放大倍率下尽可能精确地对齐引脚;在按住芯片固定的同时,我将烙铁头压在靠近引脚的走线上,持续加热5到6秒,使焊料充分受热,并希望热量能传导至整段走线乃至IC下方的焊盘。我逐一处理了每一条走线。最后为了修整焊点(因为此时可能存在冷焊问题),我涂抹了助焊剂,并沿着芯片四周的所有边缘进行了拖焊处理。这一步整理了外观,并确保所有助焊剂都正确地附着在电路走线上——此前助焊剂有些移位,看起来既凌乱又糟糕。我不想在最初的对齐和初步固定阶段就使用助焊剂,因为一旦涂上它,助焊剂就会遮挡视线,让我无法从侧面看清对齐情况。其实,即便没有助焊剂,要看清走线与芯片引脚的对齐状况也并非易事。问题的关键在于,这颗芯片并没有传统的引脚;它的底部和侧壁上分布着焊盘。我必须利用侧壁焊盘来确认它们与PCB上的焊盘是否对齐,而任何阻挡视线的助焊剂都会妨碍这一观察,即便我戴着放大倍率最高的头戴式放大镜也无济于事
 楼主| 发表于 2026-7-23 02:13:30 | 显示全部楼层
我原本想用万用表检查这块电路板是否存在短路,并测试各条线路的导通情况,但觉得万用表自带的表笔对于这种微型电路板来说太大了。于是我想到一个办法:利用鳄鱼夹跳线将缝衣针连接到万用表表笔上,把缝衣针当作新的探针来使用。这样一来,我就能触及极细微的部位并进行所需的测试了。效果相当不错!现在我已经对电路板各处进行了彻底检查,一切似乎都运行正常:既没有短路现象,所有该导通的地方也都导通良好[backcolor=rgba(214, 218, 240, 0.8)].
[backcolor=rgba(214, 218, 240, 0.8)]接下来,我可以着手连接飞线、焊接各种电阻和电容,然后进行电气功能测试。测试时,我打算用跳线连接 VIN、Vout 和 GND 端子。如果测试通过,我就可以安装大型总线线路了——这道工序相对复杂一些.
 楼主| 发表于 2026-7-24 05:57:39 | 显示全部楼层
我焊好了其余的贴片(SMD)元件。不过我发现PCB的一个角落从芯片上翘起来了,所以我打算用聚酰亚胺胶带(Kapton tape)把除那个角落以外的区域都遮盖起来,再用几个鳄鱼夹将PCB紧紧夹在芯片上以防移位,最后用热风枪对那个角落进行加热回流,使其重新贴合到PCB上
完成后,我会将跳线连接到那6个输入/输出端,以便利用实验室电源和万用表对整个电路进行全面、规范的测试.
 楼主| 发表于 2026-8-5 16:20:43 | 显示全部楼层
关于PCB上那个从芯片处翘起的角落,我决定不使用热风枪来处理——现阶段我对使用热风枪还不太有把握。取而代之,我选择拆掉碍事的电容,然后直接用手工焊接的方式把芯片装回去。过程很顺利,问题就这样解决了.
话虽如此,我当时设想用热镊子夹住电容两侧将其取下。我在网上搜了一下,发现确实有这种工具,于是就买了一把!它非常好用。虽然价格稍贵(一百多美元),但物有所值。我特别喜欢用它,因为它不仅能拆卸电容,还能一次性完成电容的重新焊接!等我熟练掌握了这把热镊子,我想以后无论是焊接还是拆焊,我都会一直用它.
另外,我在上一篇帖子中展示的那根飞线,其中一端焊锡用得太多,导致与附近的走线形成了短路桥接。所以我不得不将其拆下,取下那里的电容,清理掉多余焊锡,然后再重新焊接。这过程相当麻烦,但好在解决了短路问题,目前看来那部分一切正常.
接下来,为了防止柔性电路板(FPC)再次从IC芯片上脱落,我决定用一团紫外光固化阻焊油墨作为粘合剂,将电路板固定在芯片上,从而加固结构并避免再次发生意外。如图所示,我在两侧都进行了这种加固处理;此外,我还利用阻焊油墨将之前在排查故障时拆下的另一半电路板重新粘合了回去。至此,整块电路板终于恢复了完整!进展真的很不错.
接下来要将跨接线连接到这6个输入/输出端,以进行全面且规范的测试.
 楼主| 发表于 2026-8-10 05:54:30 | 显示全部楼层
为了测试这块PCB,我焊接了30号(30AWG)绕线。正面的三根线分别连接微控制器的5V+(用于将IC置于“开启”模式)、地线(GND)以及PWM信号线;背面的两根线则连接电池的+8V和0V/GND。焊接这些线的过程出奇地困难,因为元件实在太小了。每当我焊接+8V端时,0V端的焊点就会脱落,因为芯片背面的两个焊盘受热后会同时熔化。最后我不得不先用UV固化阻焊胶(绿油)把其中一根线固定住,再去焊另一根;这样即使焊点熔化,未操作的那根线也能保持固定,不至于因为焊料液化而脱落。这过程真让人恼火。而且我很讨厌用UV阻焊胶把线“粘”死,毕竟这些线只是为了快速测试功能而临时接上去的……总之,现在焊好了,没有短路,看起来可以开始测试了。我没怎么费心做颜色区分,因为这只是为了确认功能是否正常的临时性快速测试.
注:这应该是我首次展示 PCB 的背面,透过我在 PCB 底部切出的观察窗口,可以看到并触及主要的裸露电源焊盘。这些焊盘将用于连接主电源汇流排。我将使用从纯铜板卷上裁剪下来的厚铜条,通过手工焊接的方式安装这些汇流排。这些厚实的汇流排也将构成导热路径的起点,负责将芯片产生的热量导出。由于电路需承受 20A 的持续电流,会产生大量热量,因此必须有效地将其散发出去.
 楼主| 发表于 2026-8-21 19:36:46 | 显示全部楼层
我测试了那块PCB,结果发现它彻底“挂”了——完全无法工作。更糟糕的是,我根本无从排查故障根源。是静电放电导致IC损坏了吗?是某个焊盘与IC的连接处存在肉眼不可见的断路吗?还是在某个环节出现了隐蔽的短路或断路?我实在无法检测或定位这个问题。这让我不禁想到……也许采用尺寸稍大一点的集成IC芯片会更好:这种芯片的引脚连接清晰可见,不会像微型芯片那样把连接点藏在芯片与PCB之间导致无法检查,也不存在难以触及的底部隐藏焊盘等问题。我以前见过类似的较大尺寸半桥集成IC芯片,于是决定研究一下这种替代方案,而不是推倒重来,或者在毫无头绪的情况下无休止地排查这块已报废的PCB...
在一番搜寻之后,我找到了 BTS7960 集成半桥 IC 芯片. https://www.infineon.com/assets/ ... 945006d5d&ack=t 它采用 TO-263 封装,这意味着芯片本身带有引脚,而不像我上一篇帖子中提到的 CSD59950RWJ(QFN 封装)芯片那样,必须尝试焊接微小的焊盘。这意味着我们可以轻松直观地检查焊点,走线间距相对宽敞清晰,几乎不会发生短路,也不再需要显微镜级别的焊接精度或复杂的 DIY 蚀刻工艺;同时,也不需要在 PCB 底部切开窗口以便手动焊接铜排,因为现在完全兼容单层板设计,无需再费劲搞什么“山寨”多层板方案。实际上,现在的 PCB 蚀刻工艺可以做得非常粗糙,甚至连打印电路图并转印到覆铜板上的步骤都完全省去了。由于元件尺寸大且结构简单,我们甚至可以直接用油性记号笔画出电路布局,或者用电磨(Dremel)手工切割出走线和焊盘,根本不需要高精度操作。这种方式让一切都变得简单。那么,这是否意味着我们要做出什么妥协或牺牲呢?据我看来,并没有。这些芯片的尺寸为长 14mm(含引脚)x 宽 9mm x 高 4.4mm。我把它和我的 2430 无刷直流(BLDC)电机放在一起比对过,三个芯片完全可以并排安放在电机外壳上,就像我之前为 QFN 芯片规划的那样。况且,QFN 芯片加上转接板(breakout board)后的总尺寸与这种大芯片相差无几,所以并没有节省多少空间。只有在确实存在空间限制时,节省空间才有意义。如果这些大芯片能满足我的空间要求,那么它们仅仅因为体积稍大并不会成为负担或缺点。制造步骤、复杂度和难度的降低,使得使用起来更加轻松快捷。它仍能提供 40A 的持续电流,性能非常出色,对于我的电机而言绰绰有余。此外,单价仅为 1.20 美元,价格也差不多。算下来每个电机驱动芯片只要 3.60 美元,我觉得这价格很不错。虽然这款芯片已经停产了,但我并不介意;我相信能找到采用 TO-263 封装且性能相当、价格也差不多的替代芯片,所以这不成问题。以后如果有需要,我可以转用那些替代方案,而无需对设计做重大改动,因此对我来说这完全没问题
这是否意味着我放弃了?并非如此。我只是意识到,尽管我已竭尽全力,在操作上做到极其细致严谨,但在测试初期却依然遭遇了难以排查的彻底故障;而且,在自制PCB上使用这种QFN封装的元件,对DIY玩家来说并不友好,甚至已接近了实际操作的可行性极限。即便勉强能做,其成功率也难以保证,且极其耗时费力;除非别无选择,或者没有更简单快捷的替代方案能达到同样的效果,否则这并不值得投入额外的精力。如今,我找到了一个更快、更简单的方案,它能带来同样的效果,且没有任何实质性的妥协或不利影响.
所以我先在 AliExpress 上订购了 25 颗这种芯片,同时又在亚马逊上买了 4 颗,以便在等待 AliExpress 慢速物流期间先用着。亚马逊买的那 4 颗明天就能送到,正好填补等待大批量订单送达期间的空档。我经常这么做:在等待价格更优惠的大批量订单(通常物流较慢)送达时,先花高一点的价钱在亚马逊上买少量现货,这样就能避免因等待发货而导致工作停滞.
对了,还有一件事:我正在考虑完全放弃 PCB,改用“死虫式”(deadbug)接法。既然这颗芯片体积很大且易于连接,它本身其实就可以充当 PCB 的角色了。我打算直接把导线焊在芯片引脚上,省去制作 PCB 的麻烦。原本使用 PCB 主要是为了引出引脚并提供足够大的焊盘以便连接导线,但鉴于这颗芯片尺寸很大,我觉得没必要再用转接板(breakout board)来引出信号了,直接把导线连到引脚上就行。控制线路可以用 30AWG 的绕线(wire-wrap)导线缠绕在引脚上,而功率级线路则可以直接焊接较粗的导线。另外,我可能也会改用非贴片(non-SMD)封装的去耦电容和电阻.
注:我买的这些亚马逊芯片原本是作为 H 桥有刷直流电机驱动模块板的一部分。我的打算是把芯片从板子上拆下来用于自己的项目,因为那块板子对于人形机器人中的实际应用来说实在太大了——我们真正需要的只是板子上的那两颗芯片.
 楼主| 发表于 2026-8-24 07:44:47 | 显示全部楼层
有人向我推荐了一款体积极小但额定电流极高的电调(ESC),从占用空间的角度来看确实很合适;不过,它连运费要48美元,这实在太贵了,毕竟我自己动手做个电机控制器,元件成本才4美元。后来我在亚马逊上搜了一下这款电调,发现了一款​​非常相似的产品:尺寸相当,但产自中国,没有美国中间商赚差价,而且支持亚马逊Prime低价配送,算上运费每个只要11美元左右。从价格和尺寸来看,这下确实可行了——当然,也只是“勉强”可行,因为这价格仍是我上一篇帖子提到的自制控制器成本的3倍左右。我最终在亚马逊上下单买了一个4个装的套装。退一步讲,即便不用在原本的项目上,我也可以用它们来控制其他项目的无刷直流(BLDC)电机;而且,光是拆解它们、研究内部元件、制造工艺和做工质量等,本身就很有价值。只要戴上放大镜面罩近距离仔细观察,我就能学到很多东西.
这款设备支持 7.4V 到 22.2V 的电压,非常适合我的 2430 无刷直流(BLDC)电机(额定 8V、24A)。它能承受高达 45A 的电流,对于我的 24A 电机来说绰绰有余,留有充足的余量。它的尺寸非常小巧(高 5mm、长 28mm、宽 13mm),可以直接安装在电机侧面。这能省去大量焊接和折腾自制控制器的麻烦。但问题在于:它的固件是为无人机设计的。这意味着它不具备“移动到指定位置并保持”的功能;它无法实现“移动到指定位置后,以 50% 油门脉冲驱动该相(使手指更具柔性)”或“以 100% 油门脉冲驱动(使手指在保持位置时达到最大刚度)”这类操作。这一点让我有些顾虑,觉得它可能不太适用。我不太想依赖第三方固件,然后寄希望于它能实现某种近似我们需求的功能。所以我更倾向于使用功率级模块,由我的微控制器直接控制换向的每一个阶段。话虽如此,考虑到这个价位,它确实不容忽视。我可以自己设计并制造类似的模块,也可以尝试破解它——让微控制器绕过板载芯片和固件,直接控制功率级;或者尝试编写新固件覆盖原有固件;甚至可能在现有固件中找到某些指令,实现类似“移动到指定位置并保持”的功能?也许我能通过软件手段让它按我们的预期运行——尽管 ChatGPT 认为可能性不大,但万一能行呢?我读到过关于“制动(braking)”指令的资料,也许可以用它来替代“移动到指定位置并保持”的指令?虽然 ChatGPT 不看好这种方案,但在如此诱人的价格、尺寸和简洁性面前,依我看,至少值得一试。如果能奇迹般地让它按预期工作,这可能会成为一个很棒的替代方案。这或许能带来某种程度的变革。退一步讲,它至少为我们的“工具箱”增添了又一​​项工具、一种选择或一种新方法,这很有帮助。掌握的方法越多,我们就越能针对拥有300多个电机的机器人,根据具体情况为每个电机选用最适宜的方案.
 楼主| 发表于 2026-8-25 13:13:52 | 显示全部楼层
经过深思熟虑,我认定对那款由大公司开发、包含20个文件且多达6000行汇编代码的庞大固件进行大幅修改,并非明智之举。我需要确保自己能在未来数年内持续进行微调与改进,并维护这段代码。ESC(电子调速器)的固件至关重要,因为它直接决定了最终人形机器人的性能表现——无论是动作的流畅度与速度,还是力量与加速度,都受其影响。这简直是重中之重。然而,汇编语言并非我的强项,我在这方面经验匮乏。因此,我正式决定彻底放弃原有的固件,转而使用C语言从零开始编写一套新固件。目前这项工作进展顺利。不过值得一提的是,Keil PK51开发套件(用于将C代码转换为微控制器所需的.hex文件)通常是评估版,而评估版对代码大小有2KB的限制,这显然无法满足需求。若要获取完整版并解除限制,必须在厂商官网(silabs.com)填写申请表;收到邮件发送的激活码后,即可解锁软件的全部功能。我已经完成了这一步骤,工具方面已准备就绪。在开启这段漫长开发之旅的同时,我还在研究如何实现Arduino“飞控”与ESC上的8051 Busy Bee微控制器之间的单线双向通信。我决定从底层构建一套自定义通信协议,并将其应用于机器人全身微控制器网络中各单元间的通信。敲定这套协议的细节也是我近期面临的一项挑战。但在ChatGPT的协助下,我正稳步推进,并已制定出完善的总体方案。一切都在顺利进行中.
大王
发表于 4 小时前 | 显示全部楼层
nice guys,amazed work
GMT+8, 2026-10-30 19:52 , Processed in 2.046225 second(s), 30 queries .
