查看: 1355|回复: 5
[J-Scope] Jscope怎么缩放Y轴的坐标
发表于 2025-8-21 14:45:37 | 显示全部楼层 |阅读模式
请问,使用Jscope怎么缩放波形的Y轴坐标,让波形放大
发表于 2025-8-22 13:17:55 | 显示全部楼层
好像没有这个功能
发表于 2025-8-22 13:38:25 | 显示全部楼层
可以每个通道单独绽放,快捷键是小数字键盘的+-,上下偏移是CTRL++/-,具体见这里的官方帮助文档 https://kb.segger.com/UM08028_J-Scope
发表于 2025-8-22 13:38:59 | 显示全部楼层
New Project        CTRL + N
Open Project        CTRL + O
Save Project        CTRL + S
Export Data        CTRL + D
Export Raw        CTRL + R
Exit        ALT + X
User Guide        F1
About J-Scope        F12
Y-Offset up        CTRL + PLUS        Use with selected symbol in symbol table
Y-Offset down        CTRL + MINUS        Use with selected symbol in symbol table
Y-Res up        PLUS        Use with selected symbol in symbol table
Y-Res down        MINUS        Use with selected symbol in symbol table
Remove symbol        DELETE        Use with selected symbol in symbol table
Start sampling        F5
Stop sampling        F9
Zoom In        UP
Zoom out        DOWN
Move graph right        RIGHT
Move graph left        LEFT
Move graph to start        HOME
Move graph to end        END
 楼主| 发表于 2025-8-22 21:59:14 | 显示全部楼层
通过尝试发现,Jscope的y轴最小分辨率为1,无法向更小的值调整。所以最后使用的是freemaster来看的波形
发表于 2025-8-23 23:07:47 | 显示全部楼层
我现在用lksscope来看波形了,抄freemaster的
GMT+8, 2026-11-24 08:12 , Processed in 0.903018 second(s), 27 queries .
