查看: 1025|回复: 7
[emWin] GIF绘制卡顿
发表于 2025-8-14 17:23:09 | 显示全部楼层 |阅读模式
在绘制GIF时肉眼可见的卡顿,而且刷新时还能看到从上到下的刷新,请问有没有优化的办法?
void PowerOnDrawGif(void)
                        if (DrawGifCount < GifInfo.NumImages)
                                GUI_GIF_GetImageInfo(_acLogo2, sizeof(_acLogo2), &ImageInfo, DrawGifCount);
                                GUI_GIF_DrawSub(_acLogo2,
                                        sizeof(_acLogo2),
                                        (LCD_X_SIZE - GifInfo.xSize) / 2,
                                        (LCD_Y_SIZE - GifInfo.ySize) / 2,
                                        DrawGifCount);
                                DrawGifCount = 0;
void _cbPowerOnLogo(WM_MESSAGE * pMsg)
    PowerOnLogoData_t PowerOnLogoData;
        GUI_GIF_GetInfo(_acLogo2, sizeof(_acLogo2), &GifInfo);
    switch(pMsg->MsgId)
        case WM_SET_FOCUS:
            pMsg->Data.v = 0;
        case WM_CREATE:
                         // 初始化第一帧信息
            GUI_GIF_GetImageInfo(_acLogo2, sizeof(_acLogo2), &ImageInfo, 0);
            PowerOnLogoData.Tick = 0;
            //PowerOnLogoData.CurPos = 0;
            //PowerOnLogoData.LastPos = 0;
            PowerOnLogoData.hTimer = WM_CreateTimer(pMsg->hWin,TIMER_ID_LOGO_ROUND,ImageInfo.Delay * 10 / portTICK_PERIOD_MS,0);
            WM_SetUserData(pMsg->hWin,&PowerOnLogoData,sizeof(PowerOnLogoData));
                        DrawGifCount = 0;  // 重置帧计数器
        case WM_DELETE:
            UpdataDeviceNameToBt();
            do
                __disable_irq();
                if(NULL != g_ch1SelfTest)
                    g_ch1SelfTest->ExitTest();
                __enable_irq();
                GUI_X_Delay(LOGO_TIMER_MS / portTICK_PERIOD_MS);
            }while(NULL != g_ch1SelfTest);
        case WM_TIMER:
            SelftestError_t Error;
            uint32_t PercentCur = 0;
            uint32_t TimerId;
            TimerId = WM_GetTimerId(pMsg->Data.v);
            WM_GetUserData(pMsg->hWin,&PowerOnLogoData,sizeof(PowerOnLogoData));
            if(TIMER_ID_LOGO_ROUND == TimerId)
                WM_HWIN hWin;
                hWin = WM_SelectWindow(pMsg->hWin);
                WM_RestartTimer(pMsg->Data.v,ImageInfo.Delay * 15 / portTICK_PERIOD_MS);
                                PowerOnDrawGif();
                                DrawGifCount = (DrawGifCount + 1) % GifInfo.NumImages;
                WM_SelectWindow(hWin);
            WM_RestartTimer(pMsg->Data.v,LOGO_TIMER_MS / portTICK_PERIOD_MS);
            if(PowerOnLogoData.Tick < LOGO_EXIT_MS / LOGO_TIMER_MS)
                PowerOnLogoData.Tick++;
            Error.Error = 0;
                Error = g_ch1SelfTest->GetError();
            if(0 != Error.Error)
                GUI_RECT Rect;
                                GUI_SetFont(&GUI_DEFAULT_FONT);
                                WM_GetClientRect(&Rect);
                                GUI_SetColor(PWON_ERROR_COLOR1);
                    GUI_SetBkColor(PWON_ERROR_BKCOLOR1);
                    Rect.y1 = PWON_ERROR_INFO1_YSIZE - 1;
                                GUI_DispStringInRectFill_Buf(DEV_NAME_STRING,&Rect,GUI_TA_HCENTER | GUI_TA_VCENTER);
                                GUI_SetColor(PWON_ERROR_COLOR2);
                                GUI_SetBkColor(PWON_ERROR_BKCOLOR2);
                GetTestErrorMessage(Error,(char *)g_DispBuf,sizeof(g_DispBuf));
                                Rect.y0 = PWON_ERROR_INFO1_YSIZE;
                                Rect.y1 = Rect.y0 + PWON_ERROR_INFO2_YSIZE - 1;
                GUI_DrawFillRectEx(&Rect,PWON_ERROR_BKCOLOR2);
                GUI_DispStringInRect((char *)g_DispBuf,&Rect,GUI_TA_HCENTER | GUI_TA_VCENTER);
                                GUI_SetColor(PWON_ERROR_COLOR3);
                    GUI_SetBkColor(PWON_ERROR_BKCOLOR3);
                    Rect.y0 = PWON_ERROR_INFO1_YSIZE + PWON_ERROR_INFO2_YSIZE;
                    GUI_DispStringInRectFill_Buf(NET_ADR,&Rect,GUI_TA_RIGHT | GUI_TA_VCENTER);
                WM_DeleteTimer(pMsg->Data.v);
                WM_DeleteTimer(PowerOnLogoData.hTimer);
                SetSoundOutput(tSoundErr);
            PercentCur = 0;
                PercentCur = g_ch1SelfTest->GetProgress();
            if(PercentCur > PowerOnLogoData.Tick * (100 * LOGO_TIMER_MS / SELE_TEST_MIN_MS))
                PercentCur =  PowerOnLogoData.Tick * (100 * LOGO_TIMER_MS / SELE_TEST_MIN_MS);
            if(PowerOnLogoData.Percent != PercentCur)
                PowerOnLogoData.Percent = PercentCur;
                    if(eTest_ChkSucces != g_ch1SelfTest->GetCheckStatus())
                        if(PowerOnLogoData.Tick < LOGO_EXIT_MS / 200)
                        WM_DeleteWindow(pMsg->hWin);
            g_bReDrawID = TRUE;
            g_CurPageId.Page = PAGE_DESK;
            g_CurPageId.Id = ID_DESK_CH1_V;
            TurnToFocus();
                case WM_KEY:
                        #if 0
            if(((WM_KEY_INFO*)(pMsg->Data.p))->PressedCnt)
                if(KEY_LOK == ((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                                        RCC_ClearFlag();
                            g_bReDrawID = TRUE;
                            g_CurPageId.Id = ID_DESK_SHOWALL;
                            TurnToFocus();
            #endif
        case WM_PAINT:
            GUI_RECT Rect;
            GUI_DrawFillRectEx(&Rect,GUI_BLACK);
            PowerOnDrawGif();
        default:
            WM_DefaultProc(pMsg);
发表于 2025-8-15 09:18:24 | 显示全部楼层
gif分辨率多少?要是比较高的话边读取边解码是会比较慢的
如果gif的分辨率不高,总帧数量很少,且emwin可用内存空间够装下整个解码后的gif,那可以在显示前先把所有帧解码进memdev里,按一帧一个memdv这样子,然后根据gif的帧间隔去显示刷这些memdev,这样就很流畅了
发表于 2025-8-15 09:30:28 | 显示全部楼层
或者也可以大概测一下读取+刷新的时间,如果大于gif的帧间隔时间,可以把帧间的延时函数删掉,用读取+刷新的时间代替帧间延时
 楼主| 发表于 2025-8-15 10:06:39 | 显示全部楼层
如果gif的分辨率不高,总帧数量很少,且emwin可 ...
你好,gif分辨率是240×207,还没使用过memdev,使用的话是不是要占用额外的内存?内存本来就快满了,gif数据大概是37KB,总内存才64KB
发表于 2025-8-15 10:43:41 | 显示全部楼层
YISHUI 发表于 2025-8-15 10:06
你好,gif分辨率是240×207,还没使用过memdev,使用的话是不是要占用额外的内存?内存本来就快满了,gif数 ...
是的,这内存不够用memdev,可以试试我在上一楼说的方法,用读取+显示消耗的时间代替原本的帧间延时
或者如果你外部存储空间够的话,也可以试试先把gif转成位图序列再保存,直接显示位图序列能省掉解码时间
 楼主| 发表于 2025-8-15 11:40:43 | 显示全部楼层
或 ...
Flash应该是够用的,总共有512KB,目前用了有370KB这样,gif转成位图是用BmpCvt像转位图那样转成.c文件转吗?
发表于 2025-8-16 09:29:53 | 显示全部楼层
参考我此贴的图片浏览功能,非常到存储设备刷新,就是不知道你的动态内存够大不
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=17330
发表于 2025-8-18 10:09:28 | 显示全部楼层
YISHUI 发表于 2025-8-15 11:40
Flash应该是够用的,总共有512KB,目前用了有370KB这样,gif转成位图是用BmpCvt像转位图那样转成.c文件转 ...
gif转bmp序列需要ps或者gimp之类的软件处理一下,但是好像flash剩余空间不够
bmp是不压缩的,可以简单算一下,gif分辨率240x207,假设转换后是8bit色彩深度,有16帧,转换后总大小就是240x207x1x16=794KB,而flash剩余空间142KB只够装两帧
由于flash和ram的限制,以空间换时间的方法大概都用不了,估计只能去掉帧间延时函数了
GMT+8, 2026-11-24 17:08 , Processed in 1.010397 second(s), 24 queries .
