查看: 698|回复: 1
[有问必答] 关于stm32vet6的奇怪的问题
发表于 2025-7-26 16:16:35 | 显示全部楼层 |阅读模式
#define LED1_ON                 GPIO_ResetBits(GPIOE , GPIO_Pin_12)
#define LED2_ON                 GPIO_ResetBits(GPIOE , GPIO_Pin_13)
#define LED1_OFF                 GPIO_SetBits(GPIOE , GPIO_Pin_12)
#define LED2_OFF                 GPIO_SetBits(GPIOE , GPIO_Pin_13)
void LED_GPIO_Config(void);
int main(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        delay_init(168);
        uart_init(115200);
        LED_GPIO_Config();
        LED1_ON;
        while(1)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_12 | GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        LED1_OFF;
        LED2_OFF;
          程式只有这些.两个LED不能同时都点亮.只能点亮其中一颗.如果设两颗同时点亮.则两颗都熄灭.是我的芯片有问题吗
发表于 2025-7-27 11:18:39 | 显示全部楼层
看看是不是把高电平点亮还是低电平点亮搞反了
GMT+8, 2026-4-12 22:56 , Processed in 1.904559 second(s), 25 queries .
