查看: 1832|回复: 1
[FreeRTOS] STM32F103加上FreeRTOS系统后固件无法写入
发表于 2025-7-16 17:46:02 | 显示全部楼层 |阅读模式
为什么我用裸机固件能写入芯片中,加上FreeRTOS后就固件地址就错误了
发表于 2025-7-17 03:11:58 | 显示全部楼层
Hi,
Please try to verify the following:
1-Incorrect Linker Script / Flash Address
2- Startup File Misconfiguration
3- Incorrect Clock Configuration
4- FreeRTOS Stack Overflow / Heap Issues
5- Wrong Flashing Settings
How to Debug:
Try flashing your FreeRTOS firmware with a debugger attached.
Put a breakpoint in main() or the first task you create.
If it doesn’t hit, it's likely not starting—indicating either vector table issues or wrong address.
Check .map file to see where Reset_Handler and main() are placed.
GMT+8, 2026-11-24 15:14 , Processed in 0.898947 second(s), 22 queries .
