查看: 2253|回复: 2
[CMSIS-RTOS简易教程] keil 5.42 RTX5 编译不过
发表于 2025-7-9 13:01:16 | 显示全部楼层 |阅读模式
armclang: error: Your installation could be misconfigured or corrupted.
armclang: note: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
http://www.keil.com/support/man/ ... ense_management.htm
If you need further help, provide this complete error message to your supplier or to Arm via https://services.arm.com/support/s/contactsupport
- ARMLMD_LICENSE_FILE: unset
- LM_LICENSE_FILE: unset
- ARM_PRODUCT_DEF: unset
- ARM_PRODUCT_PATH: unset
- ARM_TOOL_VARIANT: 'ARM'
- Product location: product not found
- Toolchain location: C:\Users\TP\AppData\Local\Keil_v5\ARM\ARMCLANG\Bin
- Selected tool variant: ARM
Product: unknown
Component: Arm Compiler for Embedded 6.23
Tool: armclang [5f103000]
compiling task_HMI.c...
Product: unknown
assembling startup_stm32h743xx.s...
Product: unknown
compiling rtx_task.c...
Product: unknown
发表于 2025-7-9 15:26:19 | 显示全部楼层
这个提示是你的MDK没注册
发表于 2025-7-14 16:50:11 | 显示全部楼层
Keil没破解。
GMT+8, 2026-11-16 08:54 , Processed in 0.202942 second(s), 28 queries .
