查看: 1039|回复: 3
[UART] 串口接收
发表于 2025-6-30 11:39:40 | 显示全部楼层 |阅读模式
void R232_USART1_Init(void)
  huart1.Instance = USART1;
  huart1.Init.BaudRate =115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&huart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&huart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&huart1) != HAL_OK)
    Error_Handler();
   HAL_UART_Receive_IT(&huart1,&Res,1);
}void         HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
         if(huart ->Instance==USART1)
//                   HAL_UART_Receive_IT(&huart1,APP_BUF,10);
使用   HAL_UART_Receive_IT(&huart1,&Res,1);        每接收一个字节的数据触发一次中断,上位机那边发5A f5 11 01 02 03 04 0A 5F A5这10个字节的字符串,串口接收中断,在接收到第二个字节也就是f5 后,就没有进入中断了,而使用 HAL_UART_Receive_IT(&huart1,&Res_buf,10)这个语句可以正常接收10个字节数据,感觉不像是速度的原因,平台为stm32ZIT6,时钟配置如下
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Supply configuration update enable
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
        RCC_HSE_ON为外置晶振模式,高速外部 (HSE) 时钟可以使用一个 4 到 48 MHz 的晶振 / 陶瓷谐振振荡器产生;
        RCC_HSE_BYPASS为旁路模式,用户直接提供4-50MHz的时钟源即可,可以使用有源晶振或者FPGA提供时钟等方式
        本项目开发板HSE直接由外接8MHz晶振提供,应选 RCC_HSE_ON
        学习过程中开发板H755、H723等由ST-LINK芯片发生的时钟源提供,应选 RCC_HSE_BYPASS
                //此处HSE_VALUE=8MHz
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 200;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_0;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;//选择PLLCLK为时钟接口,此处由有源晶振分频下来为HSE_VALUE(8MHz)*PLLN(200)/[PLLM*PLLP(8*2)]=100MHz
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV2;//系统时钟二分频  HCLK*4=SYSCLK*2=100MHz
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;//HCLK二分频
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;//APB1二分频
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;//APB2=25MHz
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
发表于 2025-6-30 16:27:39 | 显示全部楼层
使用这个函数HAL_UART_Receive_IT(&huart1,&Res,1);  你的程序端怎么做到每接收一次后,快速启动第2次接收得。
 楼主| 发表于 2025-6-30 17:04:02 | 显示全部楼层
eric2013 发表于 2025-6-30 16:27
使用这个函数HAL_UART_Receive_IT(&huart1,&Res,1);  你的程序端怎么做到每接收一次后,快速启动第2次接收 ...
{HAL_UART_Receive_IT(&huart1,&Res,1);}在回调函数中,再次调用
发表于 2025-7-1 08:59:15 | 显示全部楼层
{HAL_UART_Receive_IT(&huart1,&Res ...
这样处理效率太低,改进下,参考我们的bsp_uart_fifo,c试试
GMT+8, 2026-10-24 12:14 , Processed in 0.153411 second(s), 24 queries .
