查看: 2878|回复: 26
[Cache] STM32H7 Cache缓存命中率
发表于 2025-6-24 10:00:28 | 显示全部楼层 |阅读模式
使用STM32H750VBT6,将其超频至600Mhz,项目开启了D-Cache和I-Cache,同时将D1域配置为WT,D2域配置为WBWA;
具体程序如下:
void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
  /** Initializes and configures the Region and the memory to be protected
    //TEX = 1, C = 1, B = 1,    //Write back, write and read allocate
    //TEX = 1, C = 0, B = x,    //no cacheable
    //TEX = 0, C = 1, B = 1,    //Write back, no write allocate
    //TEX = 0, C = 1, B = 0,    //Write through, no write allocate
    //最高性能
    MPU_InitStruct.Enable           = MPU_REGION_ENABLE;        //使能该保护区域
    MPU_InitStruct.BaseAddress      = 0x24000000;
    MPU_InitStruct.Size             = MPU_REGION_SIZE_512KB;    //设置保护区域大小
    MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;   //设置访问权限,
    MPU_InitStruct.IsBufferable     = MPU_ACCESS_NOT_BUFFERABLE;        //是否缓冲? B = 0
    MPU_InitStruct.IsCacheable      = MPU_ACCESS_CACHEABLE;     //是否cache?  C= 1
    MPU_InitStruct.IsShareable      = MPU_ACCESS_NOT_SHAREABLE;     //是否共用? S = 0
    MPU_InitStruct.Number           = MPU_REGION_NUMBER0;       //设置保护区域
    MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL0;           //设置类型扩展域为level0
    MPU_InitStruct.SubRegionDisable = 0x00;                 //禁止子区域
    MPU_InitStruct.DisableExec      = MPU_INSTRUCTION_ACCESS_ENABLE;        //允许指令访问(允许读取指令)
    HAL_MPU_ConfigRegion(&MPU_InitStruct);           //配置MPU
    MPU_InitStruct.BaseAddress      = 0x30000000;
    MPU_InitStruct.Size             = MPU_REGION_SIZE_64KB; //设置保护区域大小
    MPU_InitStruct.IsBufferable     = MPU_ACCESS_BUFFERABLE;        //是否缓冲? B = 1
    MPU_InitStruct.IsCacheable      = MPU_ACCESS_CACHEABLE;     //是否cache?  C=1
    MPU_InitStruct.Number           = MPU_REGION_NUMBER1;       //设置保护区域
    MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL1;           //设置类型扩展域为level1, TEX = 1
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
#define     CH_NUM          6       //DMA采样的通道数
#define FIFO_DBS_0      1000        //每个DMA的传输长度
ALIGN_32BYTES(__attribute__((section (".RAM_D2"))) uint8_t src_fifo[CH_NUM][FIFO_DBS_0]);       //DMA传输的目标地址
ALIGN_32BYTES(__attribute__((section (".RAM_D1"))) uint8_t fifo_data[CH_NUM * FIFO_DBS_0]);     //用于传输完成后的数据整合
uint8_t tc_flag = 0;    //DMA传输完成标志
uint32_t ca_cycles = 0;     //算法效率
*   函 数 名: Copy_Fifo
*   功能说明: 将DMA 6个通道的数据排序
*   形    参: 无
*   返 回 值: 无
void    Copy_Fifo(void)
    unsigned int inc = 0;
    if(tc_flag == 1)        //传输结束,可以处理数据
    //对DMA传输的内存数据做无效化处理
        SCB_InvalidateDCache_by_Addr((uint32_t *)src_fifo, FIFO_DBS_0 * CH_NUM);
        uint32_t start = DWT->CYCCNT;       //记录起始周期
        for(int i = 0; i < FIFO_DBS_0 ; i ++ )
            for(uint16_t j =0; j<6; j++)
                fifo_data[inc] = src_fifo[j];
                inc ++;
        tc_flag = 0;        //数据处理完成,开始下一次DMA传输
        uint32_t end = DWT->CYCCNT;     //记录结束周期
        ca_cycles = end - start;        //计算消耗周期数
        ca_cycles = ca_cycles / 600;    //换算成时间(单位:微秒),
项目配置只勾选了IRAM1
其中,数组src_fifo位于D2域,用于存放读取到的GPIO口的数据,数组fifo_data位于D1域,用于6组DMA数据按照顺序存放在main函数中执行Copy_Fifo()。在执行Copy_Fifo的时候,DMA这些是已经关闭了的,只有一个计时用的定时器在运行,在数据处理完毕后会在这个定时器的UPDATE中断中打开DMA,开始下一次的采样。
理论上,ca_cycles的值最差的情况下应该是40~50us左右,但是实际测量这个时间是139us;我尝试过将一下关键的代码放在ITCM中,效果也一样。
当我把Cache关闭之后,ca_cycles的值为250us左右,也就是说目前这个139us的时间是cache基本没命中导致的,为什么会到这么高的miss情况呢,要如何提高命中率?
发表于 2025-6-24 16:08:42 | 显示全部楼层
H750的DCache比较小,只有16KB.
 楼主| 发表于 2025-6-25 11:49:33 | 显示全部楼层
搬运的buffer是6K,所以没有超过DCache的大小吧
发表于 2025-6-26 09:44:17 | 显示全部楼层
不仅这里,你的Cache应该还缓冲其他位置数据了。
 楼主| 发表于 2025-6-30 16:32:01 | 显示全部楼层
请问,如何查找其他位置是否被Cache缓冲了呢
发表于 2025-7-1 08:53:36 | 显示全部楼层
这个看不到,
可以尝试让你的总RAM使用小于16KB,效果就出来了
发表于 2025-7-1 11:24:29 | 显示全部楼层
没开优化吧?两层for循环吃了太多时间了,改成while会好很多
发表于 2025-7-1 11:36:38 | 显示全部楼层
这个问题看起来是cache命中率问题,实际上是代码效率问题,两层for循环里面就只有两行代码,就算100%cache命中率,也有大量内核周期耗在for循环指令里了
你这个完全可以改成memcpy,比两层for循环一个个byte赋值快多啦
发表于 2025-7-1 12:00:42 | 显示全部楼层
DX3906 发表于 2025-7-1 11:36
这个问题看起来是cache命中率问题,实际上是代码效率问题,两层for循环里面就只有两行代码,就算100%ca ...
看错,这个不能用memcpy,不过也可以优化,下午我整理下
发表于 2025-7-1 14:31:38 | 显示全部楼层
在for循环前后反转io并用逻辑分析仪测量高电平时间可以知道代码耗时,下面是我测试的结果,不过我不是在stm32上跑的,不用管时间的绝对数值,只需要看相对比例就好
先看原代码,两层for循环一共耗时233.64u:
    if(tc_flag == 1)
        RGPIO_WritePinOutput(EXT_GPIO01_GPIO, EXT_GPIO01_GPIO_PIN, 1);
                fifo_data[inc] = src_fifo[j][i];
                inc++;
        RGPIO_WritePinOutput(EXT_GPIO01_GPIO, EXT_GPIO01_GPIO_PIN, 0);
        tc_flag = 0;
然后是改进的代码,把里面的for循环展开了,耗时64.46us:
    if(tc_flag == 1)
          fifo_data[inc++] = src_fifo[0][i];
          fifo_data[inc++] = src_fifo[1][i];
          fifo_data[inc++] = src_fifo[2][i];
          fifo_data[inc++] = src_fifo[3][i];
          fifo_data[inc++] = src_fifo[4][i];
          fifo_data[inc++] = src_fifo[5][i];
        tc_flag = 0;
以上测试均在关掉dcache的情况下跑的,编译器0级优化
可以看到,只需要把最里层的for循环展开,就能获得74%的性能提升,所以是双层for拖慢了整体效率
 楼主| 发表于 2025-7-3 10:33:55 | 显示全部楼层
DX3906 发表于 2025-7-1 14:31
在for循环前后反转io并用逻辑分析仪测量高电平时间可以知道代码耗时,下面是我测试的结果,不过我不是在stm ...
找到原因了,谢谢!谢谢
发表于 2025-7-3 15:17:44 来自手机 | 显示全部楼层
请问为啥双层循环会慢这么多?按理来说不应该差这么多啊?
发表于 2025-7-4 09:02:27 | 显示全部楼层
一个for循环等于几条赋值指令。可以用DWT时钟周期单测一下时间差异。
发表于 2025-7-7 09:16:22 | 显示全部楼层
这个其实跟代码和mcu内核都有关系
一是单独一行for(x;x;x)就会生成大于5条汇编指令,当最内层for只包含了很少的代码时,for本体就会占用大部分mcu周期。
另一个是mcu内核分支预测失败导致流水线被清空。mcu内部有分支预测单元,用于提前把后续代码填入指令流水线。
for循环里刚好有条件分支指令。当最后一次循环条件判断失败时,代码会走另一条分支,分支预测提前加载的指令就废掉了,需要清空整体指令流水线重新加载,这个清空重新加载的操作会消耗大量周期,且流水线越长耗时越长。双层for特别是内层循环次数很少时,就会出现大量清空流水线的操作。
展开内层循环后可以更好的用上分支预测单元和流水线,流水线级数越多收益越大。cortexm7是6级流水线,m4 m3是三级流水线,m7上由于双层for造成的性能损失比m4m3更大。
不过上面说的这些活,其实编译器都会自动帮我们搞定的,所以写双层for也没事,直接-ofast就完事
参与人数 1金币 +5 收起 理由
aina12138 + 5 赞一个!
发表于 2025-8-11 06:54:58 | 显示全部楼层
DX3906 发表于 2025-7-7 09:16
这个其实跟代码和mcu内核都有关系
一是单独一行for(x;x;x)就会生成大于5条汇编指令,当最内层for只包含 ...
感谢硬汉大佬和楼上的解答,不过我编译优化选项都是选择  -o1, 这个会优化内循环吗?
发表于 2025-8-11 09:45:15 | 显示全部楼层
优化有限,修改代码最好
发表于 2025-8-11 10:15:45 | 显示全部楼层
我一选这个-ofast优化,RAM就不够了,迫于无奈只能选择那个-os balanced, 我很奇怪的是,既然是fast,那么他的代码应该优化的更精简,怎么还变大了呢,导致我RAM都不够了
发表于 2025-8-11 15:13:52 | 显示全部楼层
coolaimcu 发表于 2025-8-11 10:15
我一选这个-ofast优化,RAM就不够了,迫于无奈只能选择那个-os balanced, 我很奇怪的是,既然是fast,那么 ...
我猜就是因为把一些内循环展开了吧,这样才能运行最快?
发表于 2025-8-11 16:33:00 | 显示全部楼层
可能是如果以效率优先的话,处理某些代码可能会使用空间换时间的策略。。你这就属于是即要又要了。
发表于 2025-8-13 16:33:59 | 显示全部楼层
没记错的话,o1好像不会展开内层,只是会优化循环内部变量值不改变的部分,更具体的优化内容我也不太清楚,可能得查arm的编译器手册了
发表于 2025-8-13 16:39:38 | 显示全部楼层
ofast虽然性能最强但也有代价,它会导致代码大小膨胀,算是以空间换时间吧,资源有限选obalance也行的,总好过没优化
发表于 2025-8-13 18:11:21 | 显示全部楼层
这个是多维数组吗,[6][1000]的二维数组,内层循环相当于每次要跨越1000个字节的地址过去读数据,如果6k个数据没有全部缓存到cache,那肯定会慢的吧
发表于 2025-8-13 18:45:20 | 显示全部楼层
eric2013 发表于 2025-8-11 09:45
优化有限,修改代码最好
问大佬一个问题,开启缓存的区域越小是不是缓存命中率就越大。
发表于 2025-8-14 09:04:13 | 显示全部楼层
arm_shiyue 发表于 2025-8-13 18:11
这个是多维数组吗,[6][1000]的二维数组,内层循环相当于每次要跨越1000个字节的地址过去读数据,如果6k个 ...
楼主的疑问我觉得更多是代码效率问题,你可以看看第10楼的测试,是全部关掉cache测试的
发表于 2025-8-14 09:15:13 | 显示全部楼层
其实大多数都是缓存区域越大命中率越高,区域大了有利于整体效率,但是也跟代码本身的效率有关系,优化代码比单纯堆缓存的提升大得多
你可以看第10楼的测试,是全部关掉cacahe测试的
发表于 2025-8-14 16:52:15 | 显示全部楼层
是的。楼主是将二维数组赋值到一维数组中,结果是一维数组中的数据为六个adc通道交替存储:{ch[0],ch[1],ch[2],ch[3],ch[4],ch[5],ch[0],ch[1].....},是不是可以直接初始化dma搬运的目标地址为一维数组缓冲区,dma搬运结束后使用memcpy提取数据
发表于 2025-8-15 08:51:58 | 显示全部楼层
arm_shiyue 发表于 2025-8-14 16:52
是的。楼主是将二维数组赋值到一维数组中,结果是一维数组中的数据为六个adc通道交替存储:{ch[0],ch[1], ...
好像是可以在dma传输的时候就直接搞成一维数组,他每个通道的传输长度是常量,后续通道的dma目标地址设为前一通道地址+长度偏移就行
不过不清楚他dma的源地址具体是怎么组织数据的,也不好说一定能这么搞
GMT+8, 2026-10-24 12:37 , Processed in 0.311535 second(s), 27 queries .
