查看: 1127|回复: 3
[RTC] STM32 H7 RTC
发表于 2025-6-19 10:42:34 | 显示全部楼层 |阅读模式
佬们,我在配置STM32H750VBT6的RTC的时候,使能电源时钟__HAL_RCC_PWR_CLK_ENABLE();  报错显示没有这个函数是什么情况啊。打开声明显示没有这个函数的定义
发表于 2025-6-19 15:31:57 | 显示全部楼层
H7的HAL库没有这个。
  * @file    RTC/RTC_Alarm/Src/main.c
  * @author  MCD Application Team
  * @brief   This sample code shows how to use STM32H7xx RTC HAL API to configure
  *          Time and Date.
  * @attention
  * Copyright (c) 2017 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32H7xx_HAL_Examples
/** @addtogroup RTC_Alarm
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* RTC handler declaration */
RTC_HandleTypeDef RtcHandle;
/* Buffer used for displaying Time */
uint8_t aShowTime[50] = {0};
/* Private function prototypes -----------------------------------------------*/
static void MPU_Config(void);
static void SystemClock_Config(void);
static void RTC_AlarmConfig(void);
static void RTC_TimeShow(uint8_t* showtime);
static void CPU_CACHE_Enable(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
  /* Configure the MPU attributes */
  MPU_Config();
  /* Enable the CPU Cache */
  CPU_CACHE_Enable();
  /* STM32H7xx HAL library initialization:
       - Systick timer is configured by default as source of time base, but user
         can eventually implement his proper time base source (a general purpose
         timer for example or other time source), keeping in mind that Time base
         duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
         handled in milliseconds basis.
       - Set NVIC Group Priority to 4
       - Low Level Initialization
  HAL_Init();
  /* Configure the system clock to 400 MHz */
  SystemClock_Config();
  /* Configure LED1 and LED3 */
  BSP_LED_Init(LED1);
  BSP_LED_Init(LED3);
  /*##-1- Configure the RTC peripheral #######################################*/
  RtcHandle.Instance = RTC;
  /* Configure RTC prescaler and RTC data registers */
  /* RTC configured as follows:
      - Hour Format    = Format 24
      - Asynch Prediv  = Value according to source clock
      - Synch Prediv   = Value according to source clock
      - OutPut         = Output Disable
      - OutPutPolarity = High Polarity
      - OutPutType     = Open Drain */
  RtcHandle.Init.HourFormat     = RTC_HOURFORMAT_24;
  RtcHandle.Init.AsynchPrediv   = RTC_ASYNCH_PREDIV;
  RtcHandle.Init.SynchPrediv    = RTC_SYNCH_PREDIV;
  RtcHandle.Init.OutPut         = RTC_OUTPUT_DISABLE;
  RtcHandle.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  RtcHandle.Init.OutPutType     = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&RtcHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  /*##-2- Configure Alarm ####################################################*/
  /* Configure RTC Alarm */
  RTC_AlarmConfig();
  /* Infinite loop */
  while (1)
    /*##-3- Display the updated Time #########################################*/
    RTC_TimeShow(aShowTime);
  * @brief  Alarm callback
  * @param  hrtc : RTC handle
  * @retval None
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
  /* Turn LED1 on: Alarm generation */
  BSP_LED_On(LED1);
  * @brief  System Clock Configuration
  *         The system Clock is configured as follow :
  *            System Clock source            = PLL (HSE)
  *            SYSCLK(Hz)                     = 400000000 (CPU Clock)
  *            HCLK(Hz)                       = 200000000 (AXI and AHBs Clock)
  *            AHB Prescaler                  = 2
  *            D1 APB3 Prescaler              = 2 (APB3 Clock  100MHz)
  *            D2 APB1 Prescaler              = 2 (APB1 Clock  100MHz)
  *            D2 APB2 Prescaler              = 2 (APB2 Clock  100MHz)
  *            D3 APB4 Prescaler              = 2 (APB4 Clock  100MHz)
  *            HSE Frequency(Hz)              = 25000000
  *            PLL_M                          = 5
  *            PLL_N                          = 160
  *            PLL_P                          = 2
  *            PLL_Q                          = 4
  *            PLL_R                          = 2
  *            VDD(V)                         = 3.3
  *            Flash Latency(WS)              = 4
  * @param  None
  * @retval None
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  HAL_StatusTypeDef ret = HAL_OK;
  /*!< Supply configuration update enable */
  HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
  /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /* Enable HSE Oscillator and activate PLL with HSE as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
  RCC_OscInitStruct.CSIState = RCC_CSI_OFF;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 160;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
  if(ret != HAL_OK)
    Error_Handler();
/* Select PLL as system clock source and configure  bus clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_D1PCLK1 | RCC_CLOCKTYPE_PCLK1 | \
                                 RCC_CLOCKTYPE_PCLK2  | RCC_CLOCKTYPE_D3PCLK1);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4);
  if(ret != HAL_OK)
    Error_Handler();
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void Error_Handler(void)
  while (1)
    /* Toggle LED3 with a period of one second */
    BSP_LED_Toggle(LED3);
    HAL_Delay(1000);
  * @brief  Configure the current time and date.
  * @param  None
  * @retval None
  RTC_DateTypeDef  sdatestructure;
  RTC_TimeTypeDef  stimestructure;
  RTC_AlarmTypeDef salarmstructure;
  /*##-1- Configure the Date #################################################*/
  /* Set Date: Tuesday February 2nd 2017 */
  sdatestructure.Year = 0x17;
  sdatestructure.Month = RTC_MONTH_FEBRUARY;
  sdatestructure.Date = 0x2;
  sdatestructure.WeekDay = RTC_WEEKDAY_TUESDAY;
  if(HAL_RTC_SetDate(&RtcHandle,&sdatestructure,RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /*##-2- Configure the Time #################################################*/
  /* Set Time: 02:20:00 */
  stimestructure.Hours = 0x02;
  stimestructure.Minutes = 0x20;
  stimestructure.Seconds = 0x00;
  stimestructure.TimeFormat = RTC_HOURFORMAT12_AM;
  stimestructure.DayLightSaving = RTC_DAYLIGHTSAVING_NONE ;
  stimestructure.StoreOperation = RTC_STOREOPERATION_RESET;
  if(HAL_RTC_SetTime(&RtcHandle,&stimestructure,RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /*##-3- Configure the RTC Alarm peripheral #################################*/
  /* Set Alarm to 02:20:30
     RTC Alarm Generation: Alarm on Hours, Minutes and Seconds */
  salarmstructure.Alarm = RTC_ALARM_A;
  salarmstructure.AlarmDateWeekDay = RTC_WEEKDAY_MONDAY;
  salarmstructure.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_WEEKDAY;
  salarmstructure.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
  salarmstructure.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_NONE;
  salarmstructure.AlarmTime.TimeFormat = RTC_HOURFORMAT12_AM;
  salarmstructure.AlarmTime.Hours = 0x02;
  salarmstructure.AlarmTime.Minutes = 0x20;
  salarmstructure.AlarmTime.Seconds = 0x30;
  salarmstructure.AlarmTime.SubSeconds = 0xF9;
  if(HAL_RTC_SetAlarm_IT(&RtcHandle,&salarmstructure,RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  * @brief  Display the current time.
  * @param  showtime : pointer to buffer
  * @retval None
  RTC_DateTypeDef sdatestructureget;
  RTC_TimeTypeDef stimestructureget;
  /* Get the RTC current Time */
  HAL_RTC_GetTime(&RtcHandle, &stimestructureget, RTC_FORMAT_BIN);
  /* Get the RTC current Date */
  HAL_RTC_GetDate(&RtcHandle, &sdatestructureget, RTC_FORMAT_BIN);
  /* Display time Format : hh:mm:ss */
  sprintf((char*)showtime,"%02d:%02d:%02d",stimestructureget.Hours, stimestructureget.Minutes, stimestructureget.Seconds);
  * @brief  CPU L1-Cache enable.
  * @param  None
  * @retval None
  /* Enable I-Cache */
  SCB_EnableICache();
  /* Enable D-Cache */
  SCB_EnableDCache();
  * @brief  Configure the MPU attributes
  * @param  None
  * @retval None
  MPU_Region_InitTypeDef MPU_InitStruct;
  /* Disable the MPU */
  HAL_MPU_Disable();
  /* Configure the MPU as Strongly ordered for not defined regions */
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.BaseAddress = 0x00;
  MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.SubRegionDisable = 0x87;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  /* Enable the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
 楼主| 发表于 2025-6-19 16:19:47 | 显示全部楼层
eric2013 发表于 2025-6-19 15:31
H7的HAL库没有这个。
[mw_shl_code=c,true]/**
感谢硬汉哥,请问要实现掉电继续走时,除了给VBAT脚加电池外,软件上还需要怎么配置啊
发表于 2025-6-20 13:24:52 | 显示全部楼层
参考我们APP V1.X开发工程里面的bsp_cpu_rtc.c
GMT+8, 2026-10-24 14:35 , Processed in 0.138740 second(s), 24 queries .
