查看: 1245|回复: 5
[有问必答] DAC无输出波形
发表于 2025-6-17 20:17:45 | 显示全部楼层 |阅读模式
以下为gd32f103学习代码,为什么引脚无波形输出,求解答
#define TABLE_SIZE (100)
#define PI (3.14159265)
uint16_t sin_table[TABLE_SIZE];
//0-3.3V  amp = 0~4095
void sin_generation(unsigned short amp)
        for(uint16_t i=0; i<TABLE_SIZE; i++)
                sin_table[i] = (amp / 2)*(sin(2 * PI * i / TABLE_SIZE)+1);
void dac_config(void)
        rcu_periph_clock_enable(RCU_GPIOA); //使能GPIOA时钟
        rcu_periph_clock_enable(RCU_DAC); //DAC时钟
        gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
  dac_deinit(DAC0); //DAC外设复位
  dac_enable(DAC0, DAC_OUT0);
int main(void)
  /* configure systick */
  systick_config();
        sin_generation(4095);
        dac_config();
  while (1)
                        for(uint16_t i=0;i<TABLE_SIZE; i++)
                                dac_data_set(DAC0, DAC_OUT0, DAC_ALIGN_12B_R, sin_table[i]);
                                delay_1ms(1);
 楼主| 发表于 2025-6-17 22:37:36 | 显示全部楼层
为什么啊
发表于 2025-6-18 08:07:30 | 显示全部楼层
这种的官方软件包应该有例子的,使用官方的测试下
 楼主| 发表于 2025-6-19 20:53:16 | 显示全部楼层
#include "gd32f30x.h"
void rcu_config(void);
void gpio_config(void);
void dac_config(void);
void timer5_config(void);
int main(void)
    rcu_config();
    gpio_config();
    dac_config();
    timer5_config();
    while(1) {
    rcu_periph_clock_enable(RCU_TIMER5);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_50MHZ, GPIO_PIN_5);
    dac_deinit(DAC0);
    dac_trigger_source_config(DAC0, DAC_OUT1, DAC_TRIGGER_T5_TRGO);
    dac_trigger_enable(DAC0, DAC_OUT1);
    dac_wave_mode_config(DAC0, DAC_OUT1, DAC_WAVE_MODE_TRIANGLE);
    dac_triangle_noise_config(DAC0, DAC_OUT1, DAC_TRIANGLE_AMPLITUDE_2047);
    dac_enable(DAC0, DAC_OUT1);
    dac_data_set(DAC0, DAC_OUT1, DAC_ALIGN_12B_R, 0x7F0);
    timer_parameter_struct timer_initpara;
    timer_deinit(TIMER5);
    /* TIMER configuration */
    timer_struct_para_init(&timer_initpara);
    timer_initpara.prescaler         = 119;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER5, &timer_initpara);
    timer_master_output_trigger_source_select(TIMER5, TIMER_TRI_OUT_SRC_UPDATE);
    timer_enable(TIMER5);
}这个是官方的三角波示例,但是我烧录后示波器没有波形(一条线在示波器上上下快速移动),这是为什么,其他示波器可以观测吗
发表于 2025-6-19 23:04:50 | 显示全部楼层
上下快速移动?不会是时基 (Time/Div) 太小了吧,按个 Auto 试试呢
发表于 2025-6-20 13:00:34 | 显示全部楼层
从配来看,你的定时触发速度1K左右,调节下示波器采样率即可
GMT+8, 2026-11-22 13:35 , Processed in 0.316666 second(s), 24 queries .
