查看: 1520|回复: 8
[ADC] H743 TIM单次触发双ADC交替采集 采样点不够
发表于 2025-6-5 15:49:00 | 显示全部楼层 |阅读模式
我使用双ADC交替采集10kHz正弦电压信号。ADC1和ADC2综合采样频率均配置为4.5MHz(H7顶配)。当使用连续模式(不使用TIM)时,采样点数完全正确(一个周期内能采集900个点,且波形正确),而当配置为4MHz的TIM进行单次触发时,在相同条件下单周期仅能采集到400个样本点(理论上不应该是800个吗?),请问这是为什么?有没有有经验的大佬解答一下?
#ifdef USE_ADC
/* 头文件 */
#include "adc.h"
/* 全局变量 */
uint32_t WaveShape[BUFF_SIZE] = {0};
*	函 数 名: ADC_GPIO_Config
*	功能说明: 配置ADC的GPIO端口并使能
*	形    参: NONE
*	返 回 值: NONE
static void ADC12_GPIO_Config(void)
    /* GPIO配置 */
    LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
    GPIO_InitStruct.Pin = LL_GPIO_PIN_4;
    GPIO_InitStruct.Mode = LL_GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
    LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    /* GPIO时钟使能 */
    LL_AHB4_GRP1_EnableClock(LL_AHB4_GRP1_PERIPH_GPIOC);
*	函 数 名: ADC_CLK_Config
*	功能说明: 配置ADC的时钟源PLL2并使能
*	形    参: NONE
*	返 回 值: NONE
static void ADC12_CLK_Config(void)
    /* 将PLL2配置为ADC1的时钟源(综合采样频率满配4.5MHz) */
    LL_RCC_PLL2FRACN_Disable();
    LL_RCC_PLL2_SetM(25);
    LL_RCC_PLL2_SetN(504);
    LL_RCC_PLL2_SetP(7);
    LL_RCC_PLL2_SetQ(2);
    LL_RCC_PLL2_SetR(2);
    LL_RCC_PLL2_SetVCOInputRange(LL_RCC_PLLINPUTRANGE_2_4);
    LL_RCC_PLL2_SetVCOOutputRange(LL_RCC_PLLVCORANGE_WIDE);
    LL_RCC_PLL2_Enable();
    while(LL_RCC_PLL2_IsReady() != 1){}
    LL_RCC_SetADCClockSource(LL_RCC_ADC_CLKSOURCE_PLL2P);
    /* 使能ADC1\ADC2时钟 */
    LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_ADC12);
*	函 数 名: ADC1_Normal_Config
*	功能说明: 配置ADC1常规寄存器并使能
*	形    参: NONE
*	返 回 值: NONE
void ADC12_Normal_Config(void)
    /* 定义ADC配置结构体实例 */
    LL_ADC_InitTypeDef ADC_InitStruct = {0};
    LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
    LL_ADC_CommonInitTypeDef ADC_CommonInitStruct = {0};
    /* ADC常规配置 */
    LL_ADC_SetOverSamplingScope(ADC1, LL_ADC_OVS_DISABLE);
    LL_ADC_SetBoostMode(ADC1, LL_ADC_BOOST_MODE_20MHZ);
    LL_ADC_SetOverSamplingScope(ADC2, LL_ADC_OVS_DISABLE);
    LL_ADC_SetBoostMode(ADC2, LL_ADC_BOOST_MODE_20MHZ);
    /* 结构体1 */
    /*分辨率*/
    ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_12B;
    /*禁用左对齐*/
    ADC_InitStruct.LeftBitShift = LL_ADC_LEFT_BIT_SHIFT_NONE;
    /*禁用掉电模式*/
    ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
    /* 配置 */
    LL_ADC_Init(ADC1, &ADC_InitStruct);
    LL_ADC_Init(ADC2, &ADC_InitStruct);
    /* 结构体2 */
    /*TIM3 的TRGO触发*/
    ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_EXT_TIM3_TRGO;
    /*禁用扫描模式*/
    ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
    /*禁用队列*/
    ADC_REG_InitStruct.SequencerDiscont = LL_ADC_REG_SEQ_DISCONT_DISABLE;
    /*ADC单次触发模式*/
    ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_CONTINUOUS;
    /*转换后的数据->DR*/
    ADC_REG_InitStruct.DataTransferMode =  LL_ADC_REG_DR_TRANSFER ;
    /*数据溢出覆写*/
    ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_OVERWRITTEN;
    /*上升沿触发*/
    LL_ADC_REG_SetTriggerEdge(ADC1, LL_ADC_REG_TRIG_EXT_RISING);
    /* 配置 */
    LL_ADC_REG_Init(ADC1, &ADC_REG_InitStruct);
    LL_ADC_REG_Init(ADC2, &ADC_REG_InitStruct);
    /* 结构体3 */
    /*时钟1分频*/
    ADC_CommonInitStruct.CommonClock = LL_ADC_CLOCK_ASYNC_DIV1;
    /*单通道-双ADC交替采样*/
    ADC_CommonInitStruct.Multimode = LL_ADC_MULTI_DUAL_REG_INTERL;
    /*配置DMA32位-10位分辨率(直接影响CDR寄存器是否有值,哪怕不启用DMA内存搬运,也要写这行)*/
    ADC_CommonInitStruct.MultiDMATransfer = LL_ADC_MULTI_REG_DMA_RES_32_10B;
    /*采集时间延迟2.5个周期*/
    ADC_CommonInitStruct.MultiTwoSamplingDelay = LL_ADC_MULTI_TWOSMP_DELAY_2CYCLES_5;
    /* 配置 */
    LL_ADC_CommonInit(__LL_ADC_COMMON_INSTANCE(ADC1), &ADC_CommonInitStruct);
    /* ADC1电源配置 */
    LL_ADC_DisableDeepPowerDown(ADC1);
    LL_ADC_EnableInternalRegulator(ADC1);
    __IO uint32_t wait_loop_index;
    wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
    while(wait_loop_index != 0){wait_loop_index--;}
    /* ADC2电源配置 */
    LL_ADC_DisableDeepPowerDown(ADC2);
    LL_ADC_EnableInternalRegulator(ADC2);
    __IO uint32_t wait_loop_index2;
    wait_loop_index2 = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
    while(wait_loop_index2 != 0){wait_loop_index2--;}
    /* ADC1通道配置 */
    /*rank1, 通道4*/
    LL_ADC_REG_SetSequencerRanks(ADC1, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_4);
    /*采样时间1.5个周期*/
    LL_ADC_SetChannelSamplingTime(ADC1, LL_ADC_CHANNEL_4, LL_ADC_SAMPLINGTIME_1CYCLE_5);
    /*单端模式(禁用差分模式)*/
    LL_ADC_SetChannelSingleDiff(ADC1, LL_ADC_CHANNEL_4, LL_ADC_SINGLE_ENDED);
    /*预选通道4,非常关键*/
	ADC1->PCSEL |= (1UL << (__LL_ADC_CHANNEL_TO_DECIMAL_NB(LL_ADC_CHANNEL_4) & 0x1FUL));
    /* ADC2通道配置 */
    /*rank1, 通道4*/
    LL_ADC_REG_SetSequencerRanks(ADC2, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_4);
    /*采样时间1.5个周期*/
    LL_ADC_SetChannelSamplingTime(ADC2, LL_ADC_CHANNEL_4, LL_ADC_SAMPLINGTIME_1CYCLE_5);
    /*单端模式(禁用差分模式)*/
    LL_ADC_SetChannelSingleDiff(ADC2, LL_ADC_CHANNEL_4, LL_ADC_SINGLE_ENDED);
    /*预选通道4,非常关键*/
	ADC2->PCSEL |= (1UL << (__LL_ADC_CHANNEL_TO_DECIMAL_NB(LL_ADC_CHANNEL_4) & 0x1FUL));
    /* 校准 */
    LL_ADC_StartCalibration(ADC1, LL_ADC_SINGLE_ENDED, LL_ADC_SINGLE_ENDED);
    while(LL_ADC_IsCalibrationOnGoing(ADC1)){};
    /* 校准 */
    LL_ADC_StartCalibration(ADC2, LL_ADC_SINGLE_ENDED, LL_ADC_SINGLE_ENDED);
    while(LL_ADC_IsCalibrationOnGoing(ADC2)){};
	/* 使能 */
	LL_ADC_Enable(ADC1);
	while(LL_ADC_IsActiveFlag_ADRDY(ADC1) != SET){};
    /* 使能 */
	LL_ADC_Enable(ADC2);
	while(LL_ADC_IsActiveFlag_ADRDY(ADC2) != SET){};
*	函 数 名: Threshold_Beyond_Process
*	功能说明: 高频ADC中断时的阈值处理
*	形    参: NONE
*	返 回 值: NONE
void ADC12_NVIC_Config(void)
    NVIC_SetPriority(ADC_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),0, 0));
    NVIC_EnableIRQ(ADC_IRQn);
    /* 仅使能ADC2的中断 */
    LL_ADC_EnableIT_EOC(ADC2);
*	函 数 名: ADC_IRQHandler
*	功能说明: ADC1的中断服务函数;判断输入阈值并做出相应处理
*	形    参: NONE
*	返 回 值: NONE
void ADC_IRQHandler(void)
    /* 清除标志位 */
    if (LL_ADC_IsActiveFlag_EOC(ADC2))
        LL_ADC_ClearFlag_EOC(ADC2);
    /* 阈值超出时的执行逻辑 */
    if ((float)ADC2->DR*3.3/4096 >= 1.0 )
        /* 停止ADC的中断,但EOC仍在发送 */
        LL_ADC_DisableIT_EOC(ADC2);
        /* 局部变量计数指针 */
        uint16_t counter = 0;
        /* 将当前ADC寄存器中的值搬运到缓冲区.这建立在CPU中断处理速度大于ADC转换的速度之上 */
        while (counter<BUFF_SIZE)
            /* 轮询检查标志位等待下一次ADC12转换完成 */
            while (LL_ADC_IsActiveFlag_EOC(ADC1) != 1){ }
            /* 轮询通过则将当前寄存器的值搬运至缓冲区 */
            WaveShape[counter] = ADC12_COMMON->CDR;
            /* 清除标志位 */
            LL_ADC_ClearFlag_EOC(ADC1);
            /*自增1*/
            counter++;
        /* 重新使能EOC中断,恢复连续模式 */
        // 调试模式下先不重新使能ADC的中断,避免中断造成CPU的printf的阻塞
*	函 数 名: User_ADC_Init
*	功能说明: 调用各种配置函数
*	形    参: NONE
*	返 回 值: NONE
void User_ADC12_Init(void)
    ADC12_GPIO_Config();
    ADC12_CLK_Config();
    ADC12_NVIC_Config();
    ADC12_Normal_Config();
*	函 数 名: ADC1_Start
*	功能说明: 启动ADC1开始转换
*	形    参: NONE
*	返 回 值: NONE
void ADC1_Start(void)
    LL_ADC_REG_StartConversion(ADC1);
#endif
发表于 2025-6-6 08:28:24 | 显示全部楼层
这种的交错模式,使用定时器触发效果一般,因为根本原因是交错的间隔是固定的,而你的定时器触发也有一个间隔,他们两个无法做到动态的等间隔。
最后注意两个问题
1、V版硬件芯片的,ADC强制二分频的,这个特别注意。
2、然后就是不同封装的最高支持ADC速度是不同的
STM32H7中ADC功能被ST玩出花,现在分直接通道,快速通道和慢速通道,不同封装最高速不同, LQFP封装速度最低
https://forum.anfulai.cn/forum.php? ... 7343&fromuid=58
 楼主| 发表于 2025-6-6 10:26:57 | 显示全部楼层
但是如果TIM设定为4MHz、主从ADC均设定为4.5MHz/采样时间1.5周期/12位分辨率(6.5个周期),两个ADC之间的采样延迟设定为2.5个时钟周期,则每个可用数据点之间的时间间隔应该为0.55μs/0.58μs的交替(相当于TIM的触发造成了0.03μs的延迟),这样不是也大致能做到等间距吗?
 楼主| 发表于 2025-6-6 10:32:28 | 显示全部楼层
类似于这样
发表于 2025-6-7 07:26:15 | 显示全部楼层
wangzz 发表于 2025-6-6 10:26
但是如果TIM设定为4MHz、主从ADC均设定为4.5MHz/采样时间1.5周期/12位分辨率(6.5个周期),两个ADC之间的采 ...
如果你不需要动态定时触发的话,也行。
发表于 2025-12-25 19:41:20 | 显示全部楼层
eric2013 发表于 2025-6-6 08:28
这种的交错模式,使用定时器触发效果一般,因为根本原因是交错的间隔是固定的,而你的定时器触发也有一个间 ...
大佬,跟你探讨一个问题,我现在有一个需求是采集4路ADC数据,采样频率越快越好,开始我初步想用定时器触发双ADC模式,但是在这种情况下,就要考虑定时器和ADC采样时间配合的问题,一是比较麻烦,而是无法最大最快。
我突然有另外一个想法,就是两个ADC都是独立采集,每个ADC采集两路,用DMA搬移数据,ADC配置成重复连续采集,就是不停的采集数据,采集到新的数据就覆盖之前旧的数据。
然后我启用一个定时器,周期去取数据,这样首先ADC采集是最快的极限,我就不用考虑ADC采样时间的问题了。然后我周期的去取数据,取数据的频率我自己控制就好了,这样做是不是就能实现ADC采样速率的最快极限值了?
发表于 2025-12-26 10:54:51 | 显示全部楼层
czm_hyt@163.com 发表于 2025-12-25 19:41
大佬,跟你探讨一个问题,我现在有一个需求是采集4路ADC数据,采样频率越快越好,开始我初步想用定时器触 ...
不用定时器的软件触发连续转换是他的极限速度。你可以测试下单ADC两路采集1024个数据,需要多少时间
发表于 2025-12-26 14:55:54 | 显示全部楼层
是的,我测试了,不用定时器,只开启ADC自身的连续转换,转换时间接近手册里面写的数值。
我在别的帖子里面也跟你讨论了,很多用户都有一个定时器周期触发ADC,获取ADC数据,但是配置的时候,就必须要考虑定时器的触发周期,与ADC采集的需要的时间匹配的问题,稍微麻烦点,无法做到最快。
我的意思是,以后所有的这种需求,能不能转换成,不用定时器触发ADC,就让ADC自己连续采集,以最快速度采集,然后定时器周期触发去数据而已,这样能做到最快,也不容易出问题,我这样理解是否合理?哈哈
发表于 2025-12-27 10:28:18 | 显示全部楼层
我在别的帖子 ...
完全没问题,用定时器主要是定时器的时间是固定的,方便后期计算参数,
GMT+8, 2026-10-24 09:47 , Processed in 0.292897 second(s), 27 queries .
