查看: 945|回复: 2
[SAI/I2S] I2S 缓存地址不一样,播放效果有差异
发表于 2025-6-4 16:53:25 | 显示全部楼层 |阅读模式
定义两个缓存数组,分别指定地址在SRAM1(0x30000000)和SRAM4(0x38000000)
u32 audio_i2sbuf1[WAV_I2S_TX_DMA_BUFSIZE] __attribute__((at(0x30000000+I2SBUF1ADDR)));
u32 audio_i2sbuf2[WAV_I2S_TX_DMA_BUFSIZE] __attribute__((at(0x30000000+I2SBUF2ADDR)));
u32 audio_i2sbuf1[WAV_I2S_TX_DMA_BUFSIZE] __attribute__((at(0x38000000+I2SBUF1ADDR)));
u32 audio_i2sbuf2[WAV_I2S_TX_DMA_BUFSIZE] __attribute__((at(0x38000000+I2SBUF2ADDR)));
MPU配置如下
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
	MPU_InitStruct.Enable           = MPU_REGION_ENABLE;
	MPU_InitStruct.BaseAddress      = 0x24000000;
	MPU_InitStruct.Size             = MPU_REGION_SIZE_512KB;
	MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
	MPU_InitStruct.IsBufferable     = MPU_ACCESS_BUFFERABLE;
	MPU_InitStruct.IsCacheable      = MPU_ACCESS_CACHEABLE;
	MPU_InitStruct.IsShareable      = MPU_ACCESS_NOT_SHAREABLE;
	MPU_InitStruct.Number           = MPU_REGION_NUMBER0;
	MPU_InitStruct.TypeExtField     = MPU_TEX_LEVEL1;
	MPU_InitStruct.SubRegionDisable = 0x00;
	MPU_InitStruct.DisableExec      = MPU_INSTRUCTION_ACCESS_ENABLE;
	HAL_MPU_ConfigRegion(&MPU_InitStruct);
	MPU_InitStruct.BaseAddress	 = 0x30000000;
	MPU_InitStruct.Size			 = ARM_MPU_REGION_SIZE_128KB;
	MPU_InitStruct.IsBufferable	 = MPU_ACCESS_NOT_BUFFERABLE;
	MPU_InitStruct.Number 		 = MPU_REGION_NUMBER1;
	MPU_InitStruct.TypeExtField	 = MPU_TEX_LEVEL0;
    MPU_InitStruct.BaseAddress     = 0x30020000;
    MPU_InitStruct.Number          = MPU_REGION_NUMBER3;
  /** Initializes and configures the Region and the memory to be protected
  MPU_InitStruct.BaseAddress = 0x30040000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
  MPU_InitStruct.SubRegionDisable = 0x0;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.BaseAddress = 0x30044000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
	MPU_InitStruct.BaseAddress      = 0x38000000;
	MPU_InitStruct.Size             = MPU_REGION_SIZE_64KB;
	MPU_InitStruct.Number           = MPU_REGION_NUMBER2;
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
其他I2S配置及应用程序完全一样,实测输出波形有差异,正常应该持续输出1kHz正弦波,但指定在SRAM1时有畸变,为什么缓存地址不一样有这种差异
SRAM4
SRAM4
发表于 2025-6-5 08:12:14 | 显示全部楼层
你的程序里面两个地址的此参数配置是不同的
分别被配置为MPU_TEX_LEVEL0和MPU_TEX_LEVEL1了
 楼主| 发表于 2025-6-5 15:35:46 | 显示全部楼层
还真没注意这个点,解决了,感谢大佬
GMT+8, 2026-10-24 15:11 , Processed in 0.710450 second(s), 27 queries .
