查看: 1783|回复: 10
[有问必答] STM32F407ADC采样波形
发表于 2025-5-25 22:57:29 | 显示全部楼层 |阅读模式
大佬们为什么ADC采样波形会不连续啊,我降低采样率波形就不好看,我要采载波50k基波1k的AM波,IQ解调,我发现只要采集的波形断开一下,那解调出来的波形就会大幅变化一次
ADC代码如下#include "adc.h"
#include "stm32f4xx_rcc.h"
#include "stm32f4xx_gpio.h"
#include "stm32f4xx_adc.h"
#include "stm32f4xx_dma.h"
#include "misc.h"
#define ADC_DMA_BUFFER_SIZE  500   // ?????????4096
__align(32) volatile uint16_t adc_dma_buffer0[ADC_DMA_BUFFER_SIZE]; // 32??????Cache
__align(32) volatile uint16_t adc_dma_buffer1[ADC_DMA_BUFFER_SIZE];
volatile uint8_t adc_dma_ready = 0;                     // ??????
uint8_t current_buffer = 0;                    // ?????????(0?1)
void ADC_DMA_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    ADC_InitTypeDef ADC_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    // 1. ????
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_DMA2, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    // 2. ??GPIO(????)
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStruct);
    // 3. ??DMA(?????)
    DMA_DeInit(DMA2_Stream0);
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(ADC1->DR);  // ADC???????
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)adc_dma_buffer0; // ??????
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;            // ?????
    DMA_InitStructure.DMA_BufferSize = ADC_DMA_BUFFER_SIZE;            // ?????
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;   // ???????
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;             // ??????
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;         // ????
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; // ??(16?)
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;         // ??(16?)
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                        // ????(???)
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;                 // ????
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;  // ????
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;               // ??FIFO
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;    // FIFO??(??,?FIFO??)
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    DMA_DoubleBufferModeConfig(DMA2_Stream0, (uint32_t)adc_dma_buffer1,DMA_Memory_0);              // ?????Memory0
    DMA_DoubleBufferModeCmd(DMA2_Stream0, ENABLE);       // ???????
                DMA_Cmd(DMA2_Stream0, ENABLE);
    // ??DMA??(??????)
    // ??NVIC?????
    NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
                DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
    // 4. ??ADC????
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;          // ????
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; // ????
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;      // ??DMA????
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;       // ADC????(21MHz)
    ADC_CommonInit(&ADC_CommonInitStructure);
    // 5. ??ADC??
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;            // 12????
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;                     // ??????(???)
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;                // ??????(????)
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising; // ?????
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO;       // ???3??
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;             // ???
    ADC_InitStructure.ADC_NbrOfConversion = 1;                        // ????(???????)
    ADC_Init(ADC1, &ADC_InitStructure);
    // 6. ??ADC????
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_3Cycles);
    // 7. ??ADC?DMA
    ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);  // ?????????DMA
    ADC_DMACmd(ADC1, ENABLE);                         // ??ADC DMA??
    ADC_Cmd(ADC1, ENABLE);                             // ??ADC
                        // ??DMA
void TIM_ADC_Init(void)
    TIM_TimeBaseInitTypeDef TIM_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); // ?????3??
    TIM_InitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_InitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_InitStructure.TIM_Prescaler = 42 - 1;              // ???(84MHz / 7 = 12MHz)
    TIM_InitStructure.TIM_Period = 4- 1;                // ??(12MHz / 10 = 1.2MHz,???)
    TIM_InitStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM2, &TIM_InitStructure);
    // ?????????(TRGO)
    TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);  // ??????????
    TIM_Cmd(TIM2, ENABLE);                                 // ?????3
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
// DMA2 Stream0 ??????(??????)
void DMA2_Stream0_IRQHandler(void)
    if (DMA_GetITStatus(DMA2_Stream0, DMA_IT_TCIF0))
        DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
        current_buffer = (DMA_GetCurrentMemoryTarget(DMA2_Stream0) == 0) ? 1 : 0; // ???????
        adc_dma_ready = 1; // ??????
主函数如下
int main(void)
        float32_t DAC_OUT[BUFFER_SIZE];
        uint16_t i = 0;
        static float32_t adc[500];
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//ÉèÖÃϵͳÖжÏÓÅÏȼ¶·Ö×é2
        delay_init(168);    //³õʼ»¯ÑÓʱº¯Êý
        delay_ms(500);
        uart_init(115200);        //³õʼ»¯´®¿Ú²¨ÌØÂÊΪ115200
////         LCD_Init();
        NCO_Init(50000,500000);        //³õʼ»¯LCD½Ó¿Ú
        ADC_DMA_Init();//³õʼ»¯ADC
        TIM_ADC_Init();
        FIR_Init();
//        ADit();
//        FI9959_Init();
//        KEY_Init();
        DA1_Init();
//  TIM_Cmd(TIM3 , DISABLE);
//        DMA_Cmd(DMA2_Stream0, DISABLE);
        OLED_Init();
        OLED_ShowString(1,1,"HAFS",OLED_6X8);
        OLED_Update();
//        AD9959_Set_Fre(CH1, freq_ch1);        //ÉèÖÃͨµÀ0ƵÂÊ100000Hz
//        AD9959_Set_Fre(CH0, freq_ch0);
//        AD9959_Set_Amp(CH0, 1023);
//        AD9959_Set_Amp(CH1, 1023);
//        AD9959_Set_Phase(CH0, 0);
//        AD9959_Set_Phase(CH1, 0);
//        IO_Update();
//        Counter_TIM1_Init();
//        Timer_TIM4_Init();
        while(1)
                if(adc_dma_ready)
                        if(current_buffer == 1)
                                for(i = 0; i < 500; i++)
                                        adc[i] =((float32_t)adc_dma_buffer0[i]);
                                        adc[i] =((float32_t)adc_dma_buffer1[i]);
                        adc_dma_ready = 0;
                        AM_Demod_Process(adc, DAC_OUT, BUFFER_SIZE);
                for(i = 0; i<BUFFER_SIZE;i++)
                        DAC_actual[i]= (uint16_t)DAC_OUT[i];
//                //AD9959_Freq();
上面是采样波形,下面是解调后的波形
上面是采样波形,下面是解调后的波形
main.c
2.31 KB, 下载次数: 1
adc.c
5.81 KB, 下载次数: 1
adc.h
462 Bytes, 下载次数: 1
IQ.c
2.32 KB, 下载次数: 1
IQ.h
376 Bytes, 下载次数: 1
发表于 2025-5-26 08:37:21 | 显示全部楼层
当前是500k采样率,双缓冲模式,每每轮dms是500点。
这样的话,每次处理就是有1ms.的间隙,这个有必要看下你每次的处理可以在1ms内处理完毕不
 楼主| 发表于 2025-5-27 21:17:49 | 显示全部楼层
这样的话,每次处理就是有1ms.的间隙,这个有必要看 ...
谢谢佬,我降低过采样率,然后把对这个数组的操作改得时间短了点,但是感觉很难连贯,最后用硬件滤波稍微平滑了,我想知道这个的原因有哪些呢,方便后面处理的时候注意点
发表于 2025-5-28 11:05:19 | 显示全部楼层
梧桐风 发表于 2025-5-27 21:17
谢谢佬,我降低过采样率,然后把对这个数组的操作改得时间短了点,但是感觉很难连贯,最后用硬件滤波稍微 ...
确定一个问题,看看不连贯的地方是不是固定在缓冲交接的地方。
 楼主| 发表于 2025-5-29 07:46:05 | 显示全部楼层
#include "stm32f4xx.h"                  // Device header
#include "IQ.h"
#include "fir.h"
#include "FM_FIR.h"
#include "usart.h"
//#define NCO_TABLE_SIZE 256
#define BUFFER_SIZE 500
#define PI 3.14159265358979323846f
#define PHASE_UNWRAP_THRESHOLD  3.1415926f  // ??????(p)
#define SAMPLE_RATE           500000.0f  // ???500kHz
#define MAX_DEVIATION_HZ    50000.0f     // ????50kHz
#define DEEMPH_TIME_CONST   75e-6f       // ???????75&#181;s
#define OUTPUT_GAIN         (SAMPLE_RATE / (2 * PI * MAX_DEVIATION_HZ))
//#define BUFFER_SIZE 256
typedef struct {
    float32_t cos_table[NCO_TABLE_SIZE];  // ?????
    float32_t sin_table[NCO_TABLE_SIZE];  // ?????
    uint32_t phase_accum;    // ?????(32?)
    uint32_t phase_inc;       // ????
} NCO_State;
static NCO_State nco;
void NCO_Init(uint32_t freq_hz, uint32_t fs_hz)
        double  phase_inc = (double)freq_hz * (1ULL << 32) / fs_hz;
    nco.phase_inc = (uint32_t)(phase_inc + 0.5);
    // ???sin/cos?(?????)
    for (int i = 0; i < NCO_TABLE_SIZE; i++) {
        float32_t theta = 2 * PI * i / NCO_TABLE_SIZE;
        nco.cos_table[i] = arm_cos_f32(theta);
        nco.sin_table[i] = arm_sin_f32(theta);
    nco.phase_accum = 0;
void NCO_Generate(float32_t* I_out, float32_t* Q_out, uint32_t len)
  for (uint32_t i = 0; i < len; i++)
        uint8_t index = (nco.phase_accum >> 24) & 0xFF;
        I_out[i] = nco.cos_table[index];  // I?(??)
        Q_out[i] = nco.sin_table[index];  // Q?(??)
        nco.phase_accum += nco.phase_inc;
void AM_Demod_Process(float32_t* input, float32_t* output, uint32_t len)
                uint16_t i =0;
  static float32_t I_buf[BUFFER_SIZE], Q_buf[BUFFER_SIZE];
  float32_t mag_sq[BUFFER_SIZE];
        static  float32_t IMAX_buf[BUFFER_SIZE]={0}, QMAX_buf[BUFFER_SIZE]={0};
        float32_t Ifir_buf[BUFFER_SIZE]={0}, Qfir_buf[BUFFER_SIZE]={0};
    NCO_Generate(I_buf, Q_buf, len);
        arm_mult_f32(input, Q_buf, QMAX_buf, len);
    arm_mult_f32(input, I_buf, IMAX_buf, len);
    // FIR??(??IIR??)
    arm_fir_f32_lp_I(IMAX_buf, Ifir_buf);
    arm_fir_f32_lp_Q(QMAX_buf, Qfir_buf);
    float32_t sum_sq[BUFFER_SIZE];
    arm_mult_f32(Ifir_buf, Ifir_buf, sum_sq, len);
    arm_mult_f32(Qfir_buf, Qfir_buf, output, len);
    arm_add_f32(sum_sq, output, sum_sq, len);
        arm_sqrt_f32(sum_sq[i], &output[i]);      // output = sqrt(I^2 + Q^2)
//                for(i = 0;i<500;i++ )
//                        printf("%f,%f,%f\n", sum_sq[i], output[i],input[i]);
void FM_Demod_Process(float32_t* input, float32_t* output, uint32_t len)
        uint16_t i = 0;
        static float32_t FM_I_buf[BUFFER_SIZE], FM_Q_buf[BUFFER_SIZE];
        static float32_t FM_IMAX_buf[BUFFER_SIZE] = {0}, FM_QMAX_buf[BUFFER_SIZE] = {0};
        float32_t FM_Ifir_buf[BUFFER_SIZE] = {0}, FM_Qfir_buf[BUFFER_SIZE] = {0};
        static float32_t prev_phase = 0.0f;  // ??????
        static float32_t prev_unwrapped = 0.0f;  // ??????????
        float32_t current_phase, phase_diff, unwrapped_phase;
        static int32_t phase_jumps = 0; // ??????
        static float32_t prev_deemph = 0.0f;
  NCO_Generate(FM_I_buf, FM_Q_buf, len);
        arm_mult_f32(input, FM_Q_buf, FM_QMAX_buf, len);
  arm_mult_f32(input, FM_I_buf, FM_IMAX_buf, len);
//                        printf("%f,%f,%f\n",FM_I_buf[i],FM_Q_buf[i],FM_QMAX_buf[i]/800);
    // FIR??(??IIR??)
  FM_arm_fir_f32_lp_I(FM_IMAX_buf, FM_Ifir_buf);
  FM_arm_fir_f32_lp_Q(FM_QMAX_buf, FM_Qfir_buf);
        const float32_t DEEMPH_ALPHA = 0.9746f;
        for (i = 0; i < len; i++)
                current_phase = cordic_atan2(FM_Qfir_buf[i], FM_Ifir_buf[i]); //·&#180;&#213;&#253;&#199;&#208;
                phase_diff = current_phase - prev_phase;
                if (phase_diff > PI) {
                        phase_jumps--;
                                                phase_diff -= 2 * PI;
        } else if (phase_diff < -PI) {
                                        phase_jumps++;
                                        phase_diff += 2 * PI;
                                unwrapped_phase = current_phase + 2*PI*phase_jumps;
                                output[i] = (unwrapped_phase - prev_unwrapped) * OUTPUT_GAIN;
        output[i] = (1 - DEEMPH_ALPHA) * output[i] + DEEMPH_ALPHA * prev_deemph;
                                prev_deemph = output[i];
        prev_phase = current_phase;
        prev_unwrapped = unwrapped_phase;
                        printf("%f,%f,%f\n",output[i],input[i]/800,FM_QMAX_buf[i]/800);
float32_t cordic_atan2(float32_t y, float32_t x) {
    float32_t angle = 0.0f;
    int8_t sign = 1;
    // ??x=0?????
    if (x == 0.0f) return (y >= 0) ? PI/2 : -PI/2;
    if (x < 0) { x = -x; y = -y; angle = PI; }
    if (y < 0) { y = -y; sign = -1; }
    // ???????(????9/10)
    static const float32_t angles[20] = {
    0.7853981634f,   // arctan(1)        (i=0)
    0.4636476090f,   // arctan(1/2^1)   (i=1)
    0.2449786631f,   // arctan(1/2^2)   (i=2)
    0.1243549945f,   // arctan(1/2^3)   (i=3)
    0.0624188097f,   // arctan(1/2^4)   (i=4)
    0.0312398334f,   // arctan(1/2^5)   (i=5)
    0.0156237286f,   // arctan(1/2^6)   (i=6)
    0.0078123411f,   // arctan(1/2^7)   (i=7)
    0.0039062301f,   // arctan(1/2^8)   (i=8)
    0.0019531225f,   // arctan(1/2^9)   (i=9)
    0.0009765622f,   // arctan(1/2^10)  (i=10)
    0.0004882812f,   // arctan(1/2^11)  (i=11)
    0.0002441406f,   // arctan(1/2^12)  (i=12)
    0.0001220703f,   // arctan(1/2^13)  (i=13)
    0.0000610352f,   // arctan(1/2^14)  (i=14)
    0.0000305176f,   // arctan(1/2^15)  (i=15)
    0.0000152588f,   // arctan(1/2^16)  (i=16)
    0.0000076294f,   // arctan(1/2^17)  (i=17)
    0.0000038147f,   // arctan(1/2^18)  (i=18)
    0.0000019073f    // arctan(1/2^19)  (i=19)
    for(int i=0; i<20; i++) {
        float32_t factor = 1.0f/(1 << i);
        if(y > 0) {
            x += y * factor;
            y -= x * factor;
            angle += angles[i];
        } else {
            x -= y * factor;
            y += x * factor;
            angle -= angles[i];
    return sign * angle * 0.607252935f;
}我现在解调FM,一样的参数解不出来了,我发现我这个dsp库里
没有反正切
 楼主| 发表于 2025-5-29 07:48:08 | 显示全部楼层
111111111111111
发表于 2025-5-29 09:22:06 | 显示全部楼层
#include "IQ.h"
#include "fir.h"
这部分没太看懂楼主的意思,部分注释成乱码了。
 楼主| 发表于 2025-6-1 20:38:56 | 显示全部楼层
    float32_t FM_IMAX_buf[BUFFER_SIZE];  // I路滤波前信号
    float32_t FM_QMAX_buf[BUFFER_SIZE];  // Q路滤波前信号
    float32_t FM_Ifir_buf[BUFFER_SIZE];         // I路滤波后信号
    float32_t FM_Qfir_buf[BUFFER_SIZE];
发表于 2025-6-3 09:38:23 | 显示全部楼层
    float32_t FM_IMA ...
你前面说的那个反正切的函数,只能调用c库的,dsp库里面没有对应的api
然后截图解析出来的效果确实不好
 楼主| 发表于 2025-7-20 15:32:01 | 显示全部楼层
然后截图解析出来的效果确实不 ...
谢谢大佬了,这几天又重新写了一下,确实处理速度是个问题,后面把多余步骤省略了再加上出入队列作为缓冲处理速度就差不多可以了,FM,AM可以解载波60k的波形了,我把代码放着给大家参考参考
main.zip
1.61 KB, 下载次数: 7
发表于 2025-7-21 08:50:11 | 显示全部楼层
梧桐风 发表于 2025-7-20 15:32
谢谢大佬了,这几天又重新写了一下,确实处理速度是个问题,后面把多余步骤省略了再加上出入队列作为缓冲 ...
GMT+8, 2026-2-26 13:30 , Processed in 0.059578 second(s), 28 queries .
